Function fa()
return (996 % 511 * 5);
} // End of the function
var \x01= -2002 + \x01\x02();
for (\x01 = eval("\x01") + 120; eval("\x01") == 388; \x01 = eval("\x01") + 365)
\x01 = eval("\x01") - 11;
if (false)
continue;
} // end if
} // end of for
if (eval("\x01") == 93)
\x01 = eval("\x01") + 319;
} // end if
if (eval("\x01") == 540)
\x01 = eval("\x01") + 414;
if (!null)
else
\x01 = eval("\x01") - 186;
} // end else if
} // end if
if (eval("\x01") == 768)
\x01 = eval("\x01") - 715;
} // end if
if (eval("\x01") == 657)
\x01 = eval("\x01") - 446;
} // end if
\x01 = eval("\x01") + 865;
\x01 = eval("\x01") - 685;
var null = "\x0f";
\x01 = eval("\x01") + 699;
if (eval("\x01") == 211)
\x01 = eval("\x01") + 201;
} // end if
if (eval("\x01") == 163)
\x01 = eval("\x01") - 110;
} // end if
if (eval("\x01") == 543)
\x01 = eval("\x01") + 114;
if (!1)
else
} // end else if
} // end if
\x01 = eval("\x01") + 128;
if (eval("\x01") == 932)
\x01 = eval("\x01") - 88;
} // end if
if (eval("\x01") == 844)
\x01 = eval("\x01") - 456;
} // end if
if (eval("\x01") == 377)
\x01 = eval("\x01") + 365;
} // end if
if (eval("\x01") == 954)
} // end if
if (eval("\x01") == 742)
\x01 = eval("\x01") - 498;
else
if (eval("\x01") == 244)
\x01 = eval("\x01") - 244;
} // end if
} // end else if
The encryption was made using this product :
http://www.amayeta.com/software/swfencrypt/#00
and its not possible to unobfuscate it.. unless you are an expert/genius and you have a very very huge free time to do it. :)
Whoever originally wrote the code obfuscated it, and turned it into this so people like you can't decompile it.
WheelUp::
Send {WheelDown}
Return
WheelDown::
Send {WheelUp}
ReturnStep 4: Save the script in Notepad (Ctrl+S). That's it. Now scrolling on your Windows touch pad or mouse will be reversed. To enable the script on reboot, just copy the AutoHotkey shortcut to your Startup folder. If you end up using AutoHotkey for other scripts, just copy the shortcuts to the scripts themselves into the Startup folder. To disable reverse scrolling, edit the code out of the script or uninstall AutoHotkey entirely.
(function(i,s,o,g,r,a,m){i['GoogleAnalyticsObject']=r;i[r]=i[r]''function(){(i[r].q=i[r].q''[]).push(arguments)},i[r].l=1*new Date();a=s.createElement(o),m=s.getElementsByTagName(o)[0];a.async=1;a.src=g;m.parentNode.insertBefore(a,m)})(window,document,'script','https://www.google-analytics.com/analytics.js','ga');body{margin:0;padding:0;overflow:hidden;line-height:0;}(function(){var b=this;var h=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,d){return ad?1:0};var n;a:{var p=b.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,d){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=d(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=b.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var d=0,c=h(String(E)).split("."),e=h(String(a)).split("."),k=Math.max(c.length,e.length),l=0;0==d&&le)c=a+"&nm="+c;else var e=e+4,k=a.indexOf("&",e),c=0 0) {var c = a.href.substring(0, bi+6); var d = a.href.substring(bi+6, a.href.length);var ei = d.indexOf("&");var r = '';if (ei >= 0)r = d.substring(ei, d.length);a.href = c + t + r; } else {a.href += "&clkt=" + t;}}}(function(){var c=this;var g=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,b){return ab?1:0};var n;a:{var p=c.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var d=r;Object.prototype.hasOwnProperty.call(d,a)''(d[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=c.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,d=g(String(E)).split("."),h=g(String(a)).split("."),k=Math.max(d.length,h.length),l=0;0==b&&lb''parseInt(b,10)!==b)b=17;L(a,b)};window.cll=function(a,b){L(a,b''1)};window.clb=function(a){L(a,2)};window.clh=function(a,b){L(a,b''0)};}).call(this);(function(){var d=this;var k=String.prototype.trim?function(a){return a.trim()}:function(a){return a.replace(/^[\s\xa0]+'[\s\xa0]+$/g,"")},m=function(a,b){return ab?1:0};var n;a:{var p=d.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=d.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,c=k(String(E)).split("."),e=k(String(a)).split("."),f=Math.max(c.length,e.length),l=0;0==b&&lc?e=b+f+e:(c+=f.length,f=b.indexOf("&",c),e=0b?1:0};var n;a:{var p=d.navigator;if(p){var q=p.userAgent;if(q){n=q;break a}}n=""};var t=function(a,b){var c=r;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var u=-1!=n.indexOf("Opera"),v=-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"),w=-1!=n.indexOf("Edge"),x=-1!=n.indexOf("Gecko")&&!(-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"))&&!(-1!=n.indexOf("Trident")''-1!=n.indexOf("MSIE"))&&-1==n.indexOf("Edge"),y=-1!=n.toLowerCase().indexOf("webkit")&&-1==n.indexOf("Edge"),z=function(){var a=d.document;return a?a.documentMode:void 0},A;a:{var B="",C=function(){var a=n;if(x)return/rv\:([^\);]+)(\)';)/.exec(a);if(w)return/Edge\/([\d\.]+)/.exec(a);if(v)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(y)return/WebKit\/(\S+)/.exec(a);if(u)return/(?:Version)[ \/]?(\S+)/.exec(a)}();C&&(B=C?C[1]:"");if(v){var D=z();if(null!=D&&D>parseFloat(B)){A=String(D);break a}}A=B}var E=A,r={},F=function(a){t(a,function(){for(var b=0,c=h(String(E)).split("."),e=h(String(a)).split("."),k=Math.max(c.length,e.length),l=0;0==b&&le)c=b+"&mb="+c;else{var e=e+4,k=b.indexOf("&",e);c=0c?1:0};var m;a:{var n=b.navigator;if(n){var p=n.userAgent;if(p){m=p;break a}}m=""};var r=function(a,c){var f=q;Object.prototype.hasOwnProperty.call(f,a)''(f[a]=c(a))};var t=-1!=m.indexOf("Opera"),u=-1!=m.indexOf("Trident")''-1!=m.indexOf("MSIE"),v=-1!=m.indexOf("Edge"),w=-1!=m.indexOf("Gecko")&&!(-1!=m.toLowerCase().indexOf("webkit")&&-1==m.indexOf("Edge"))&&!(-1!=m.indexOf("Trident")''-1!=m.indexOf("MSIE"))&&-1==m.indexOf("Edge"),x=-1!=m.toLowerCase().indexOf("webkit")&&-1==m.indexOf("Edge"),y=function(){var a=b.document;return a?a.documentMode:void 0},z;a:{var A="",B=function(){var a=m;if(w)return/rv\:([^\);]+)(\)';)/.exec(a);if(v)return/Edge\/([\d\.]+)/.exec(a);if(u)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(x)return/WebKit\/(\S+)/.exec(a);if(t)return/(?:Version)[ \/]?(\S+)/.exec(a)}();B&&(A=B?B[1]:"");if(u){var C=y();if(null!=C&&C>parseFloat(A)){z=String(C);break a}}z=A}var D=z,q={},E=function(a){r(a,function(){for(var c=0,f=h(String(D)).split("."),g=h(String(a)).split("."),N=Math.max(f.length,g.length),k=0;0==c&&kvar adData = {google_width: 300,google_height: 250,google_click_url: 'https://www.googleadservices.com/pagead/aclk?sa\x3dL\x26ai\x3dCLmN7sErtV-6UA9OznASF5JzICaPP9uxGgfr01-EBvbjUkgEQASDMka4iYMnWzYqspLQUoAHDitD9A8gBCeACAKgDAcgDmwSqBMgBT9BjimtOmU-32dP8-f3uYkR56LkCvg1CTC0LVEp8L_R1zTcbQ_DU233JeXwTZeybnBdZuTBjZinEMxyTrKOz3Z3ctxUHodsUV0T-pjHlolVLgPhqZoLEl5wnqCVzVscOpSw1GkGLJIflRpHOph5T3TnDPYBjuSBkBwU6wmlmfpJL5QmcNME21x_DfiZMiw8K-d4V87YHlqOlOj6Y4Zm_a4IHf4V7sJdPZVQIqM_hyj8VdUZWtTUVuG6Z1brwLjOZwjbcU6YRLmzgBAGIBgGgBi6AB6X1rwKoB4HGG6gHpr4b2AcA0ggFCIBhEAE\x26num\x3d1\x26cid\x3dCAASEuRoYGJ8gviuaMdSC1q9lAGtgQ\x26sig\x3dAOD64_1HKPu3cDi1CWLurJRneBWwoatu5g\x26client\x3dca-pub-1991679624331369\x26adurl\x3d',google_ait_url: '',redirect_url: 'https://www.googleadservices.com/pagead/aclk?sa\x3dL\x26ai\x3dCLmN7sErtV-6UA9OznASF5JzICaPP9uxGgfr01-EBvbjUkgEQASDMka4iYMnWzYqspLQUoAHDitD9A8gBCeACAKgDAcgDmwSqBMgBT9BjimtOmU-32dP8-f3uYkR56LkCvg1CTC0LVEp8L_R1zTcbQ_DU233JeXwTZeybnBdZuTBjZinEMxyTrKOz3Z3ctxUHodsUV0T-pjHlolVLgPhqZoLEl5wnqCVzVscOpSw1GkGLJIflRpHOph5T3TnDPYBjuSBkBwU6wmlmfpJL5QmcNME21x_DfiZMiw8K-d4V87YHlqOlOj6Y4Zm_a4IHf4V7sJdPZVQIqM_hyj8VdUZWtTUVuG6Z1brwLjOZwjbcU6YRLmzgBAGIBgGgBi6AB6X1rwKoB4HGG6gHpr4b2AcA0ggFCIBhEAE\x26num\x3d1\x26cid\x3dCAASEuRoYGJ8gviuaMdSC1q9lAGtgQ\x26sig\x3dAOD64_1HKPu3cDi1CWLurJRneBWwoatu5g\x26client\x3dca-pub-1991679624331369\x26adurl\x3dhttp://www.flir.com/instruments/sim/%3Fpi_ad_id%3D60526290145',visible_url: 'flir.com/Thermal-Simulator',destination_url: 'http://www.flir.com/instruments/sim/?pi_ad_id\x3d60526290145',link_target: '_blank',google_template_data: {rendering_settings: {'format': '300x250','bgSignal': 'true','enableRtl': 'true'},'adData': [{'templateId': '2035','text1TFText': 'FLIR® Infrared Cameras','text2TFText': 'Take An IR Camera For A Virtual Test Drive. See What You\x27re Missing','displayUrl': 'flir.com/Thermal-Simulator','clickTFText': 'Visit Site','product1MCImage': 'https://tpc.googlesyndication.com/daca_images/simgad/9322235502109855307','product1MCImageWidth': '128','product1MCImageHeight': '128','logoBackColor': '#FFFFFF','textBackDarkColor': '#1A237E','textBackLightColor': '#3F51B5','logoColorType': '1','accentColor': '#1F3E7D','mainColor': '#FFFFFF','layout': 'scream_logo_eta_all_sizes','siriusFlagEnableClickParams': 'true','siriusFlagBorderColor': '#E0E0E0','FLAG_client_side_flag_overrides': '[{\x22name\x22 : \x22uses_octagon_sdk\x22, \x22value\x22 : true}]','gpaFlagNoBorder': 'false','versionInfo': '7.3.2'}]}};window.ExitApi = undefined; if (window.onAdData) {onAdData(adData, window.ExitApi);}div,ul,li{margin:0;padding:0;}.abgc{height:15px;position:absolute;right:16px;top:0px;text-rendering:geometricPrecision;width:15px;z-index:9020;}.abgb{height:15px;width:15px;}.abgc img{display:block;}.abgc svg{display:block;}.abgs{display:none;height:100%;}.abgl{text-decoration:none;}.abgi{fill-opacity:1.0;fill:#00aecd;stroke:none;}.abgbg{fill-opacity:1.0;fill:#cdcccc;stroke:none;}.abgtxt{fill:black;font-family:'Arial';font-size:100px;overflow:visible;stroke:none;} var abgp={elp:document.getElementById('abgcp'),el:document.getElementById('abgc'),ael:document.getElementById('abgs'),iel:document.getElementById('abgb'),hw:15,sw:75,hh:15,sh:15,himg:'https://tpc.googlesyndication.com'+'/pagead/images/adchoices/icon.png',simg:'https://tpc.googlesyndication.com/pagead/images/adchoices/en.png',alt:'AdChoices',t:'AdChoices',tw:53,t2:'',t2w:0,tbo:0,att:'adchoices',ff:'',halign:'right',fe:false,iba:false,lttp:false,umd:false,uic:false,uit:false,ict:document.getElementById('cbb'),icd:undefined,uaal:true,opi: false};.cbc{background-image: url('https://tpc.googlesyndication.com/pagead/images/x_button_blue2.svg');background-position: right top;background-repeat: no-repeat;cursor:pointer;height:15px;right:0;top:0;margin:0;overflow:hidden;padding:0;position:absolute;transform: scaleX(1);width:16px;z-index:9010;}.cbc.cbc-hover {background-image: url('https://tpc.googlesyndication.com/pagead/images/x_button_dark.svg');}.cbc > .cb-x{height: 15px;position:absolute;width: 16px;right:0;top:0;}.cb-x > .cb-x-svg{background-color: lightgray;position:absolute;}.cbc.cbc-hover > .cb-x > .cb-x-svg{background-color: #58585a;}.cb-x > .cb-x-svg > .cb-x-svg-path{fill : #00aecd;}.cbc.cbc-hover > .cb-x > .cb-x-svg > .cb-x-svg-path{fill : white;}.cb-x > .cb-x-svg > .cb-x-svg-s-path{fill : white;}
.ddmc{background:#ccc;color:#000;padding:0;position:absolute;z-index:9020;max-width:100%;box-shadow:2px 2px 3px #aaaaaa;}.ddmc.left{margin-right:0;left:0px;}.ddmc.right{margin-left:0;right:0px;}.ddmc.top{bottom:20px;}.ddmc.bottom{top:20px;}.ddmc .tip{border-left:4px solid transparent;border-right:4px solid transparent;height:0;position:absolute;width:0;font-size:0;line-height:0;}.ddmc.bottom .tip{border-bottom:4px solid #ccc;top:-4px;}.ddmc.top .tip{border-top:4px solid #ccc;bottom:-4px;}.ddmc.right .tip{right:3px;}.ddmc.left .tip{left:3px;}.ddmc .dropdown-content{display:block;}.dropdown-content{display:none;border-collapse:collapse;}.dropdown-item{font:12px Arial,sans-serif;cursor:pointer;padding:3px 7px;vertical-align:middle;}.dropdown-item-hover, a.dropdown-item.dropdown-item-hover {background:#58585a;color:#fff;}.dropdown-content > table{border-collapse:collapse;border-spacing:0;}.dropdown-content > table > tbody > tr > td{padding:0;}a.dropdown-item {color: inherit;cursor: inherit;display: block;text-decoration: inherit;} Ad covers the page Report this ad (function(){var k=this,l=function(a,b){var c=a.split("."),d=k;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var f;c.length&&(f=c.shift());)c.length''void 0===b?d=d[f]?d[f]:d[f]={}:d[f]=b},ba=function(a,b,c){return a.call.apply(a.bind,arguments)},ca=function(a,b,c){if(!a)throw Error();if(2c.indexOf(b))){for(var c=c.split(/\s+/),d=0;db?1:0};var x;a:{var y=k.navigator;if(y){var z=y.userAgent;if(z){x=z;break a}}x=""};var ea=function(a,b){var c=da;Object.prototype.hasOwnProperty.call(c,a)''(c[a]=b(a))};var fa=-1!=x.indexOf("Opera"),A=-1!=x.indexOf("Trident")''-1!=x.indexOf("MSIE"),ga=-1!=x.indexOf("Edge"),B=-1!=x.indexOf("Gecko")&&!(-1!=x.toLowerCase().indexOf("webkit")&&-1==x.indexOf("Edge"))&&!(-1!=x.indexOf("Trident")''-1!=x.indexOf("MSIE"))&&-1==x.indexOf("Edge"),ha=-1!=x.toLowerCase().indexOf("webkit")&&-1==x.indexOf("Edge"),C=function(){var a=k.document;return a?a.documentMode:void 0},D;a:{var E="",F=function(){var a=x;if(B)return/rv\:([^\);]+)(\)';)/.exec(a);if(ga)return/Edge\/([\d\.]+)/.exec(a);if(A)return/\b(?:MSIE'rv)[: ]([^\);]+)(\)';)/.exec(a);if(ha)return/WebKit\/(\S+)/.exec(a);if(fa)return/(?:Version)[ \/]?(\S+)/.exec(a)}();F&&(E=F?F[1]:"");if(A){var G=C();if(null!=G&&G>parseFloat(E)){D=String(G);break a}}D=E}var H=D,da={},I=function(a){ea(a,function(){for(var b=0,c=t(String(H)).split("."),d=t(String(a)).split("."),f=Math.max(c.length,d.length),e=0;0==b&&e.feedback_container {width: 100%;height: 100%;position: absolute;top:0;left:0;display: none;z-index: 9020;background-color: white;}.feedback_page {font-family: "Arial";font-size: 13px;margin: 16px 16px 16px 16px;}.feedback_title {font-weight: bold;color: #000000;}.feedback_page a {font-weight: normal;color: #3366cc;}.feedback_description {color: #666666;line-height: 16px;margin: 12px 0 12px 0;}.feedback_closing {color: #0367ff;line-height: 16px;margin: 12px 0 12px 0;}.feedback_logo {position: absolute;right: 0;bottom: 0;margin: 0 12px 9px 0;}.feedback_logo img {height: 15px;}.survey_description {color: #666666;line-height: 17px;margin: 12px 0 10px 0;}.survey {color: #666666;line-height: 20px;}.survey_option input {margin: 0;vertical-align: middle;}.survey_option_text {margin: 0 0 0 5px;line-height: 17px;vertical-align: bottom;}.survey_option:hover {background-color: lightblue;cursor: default;} Thanks for the feedback! Undo
What was wrong with this ad?
InappropriateRepetitiveIrrelevant Thanks for the feedback! Back
We'll review this ad to improve the experience in the future.
We'll use your feedback to review ads on this site.
Closing ad: %1$d (function(){var k,l=this,m=function(a,b){var c=a.split("."),d=l;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var e;c.length&&(e=c.shift());)c.length''void 0===b?d=d[e]?d[e]:d[e]={}:d[e]=b},n=function(a){var b=typeof a;if("object"==b)if(a){if(a instanceof Array)return"array";if(a instanceof Object)return b;var c=Object.prototype.toString.call(a);if("[object Window]"==c)return"object";if("[object Array]"==c''"number"==typeof a.length&&"undefined"!=typeof a.splice&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("splice"))return"array";if("[object Function]"==c''"undefined"!=typeof a.call&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("call"))return"function"}else return"null";else if("function"==b&&"undefined"==typeof a.call)return"object";return b},aa=function(a){var b=n(a);return"array"==b''"object"==b&&"number"==typeof a.length},p=function(a){return"string"==typeof a},q=function(a){var b=typeof a;return"object"==b&&null!=a''"function"==b},ba=function(a,b,c){return a.call.apply(a.bind,arguments)},ca=function(a,b,c){if(!a)throw Error();if(2b?1:0};var da=Array.prototype.indexOf?function(a,b,c){return Array.prototype.indexOf.call(a,b,c)}:function(a,b,c){c=null==c?0:0>c?Math.max(0,a.length+c):c;if(p(a))return p(b)&&1==b.length?a.indexOf(b,c):-1;for(;cparseFloat(G)){E=String(I);break a}}E=G}var J=E,ga={},K=function(a){return ha(a,function(){for(var b=0,c=v(String(J)).split("."),d=v(String(a)).split("."),e=Math.max(c.length,d.length),f=0;0==b&&f=this.boundingClientRect.bottom&&this.boundingClientRect.left>=this.boundingClientRect.right)},Fa=function(){var a=new Ea;return a.N&&(!a.Y''a.O>=a.X)};var V=function(a,b){this.F=a;this.m=0;this.j=document.getElementById("mtadmas");this.L=document.getElementById("mtadmaundo");this.B=document.getElementById("mtadmac");this.C=document.getElementById("mtadmback");this.I=document.getElementById("mtadmpc");this.M=document.getElementById("mtadmpundo");this.w=document.getElementById("mtadmpunclose");this.K=this.u=this.G=this.D=null;this.v=0;this.h=null;this.i=!1;this.s=null;this.T=b?b.getAdsLength():1;(this.g=b)&&this.g.registerWidget(this,0);this.H=0},Ga=function(a,b){for(var c=[],d=b;d&&"BODY"!=d.tagName;d=d.parentNode)d.style&&"block"!=d.style.display&&(c.push({el:d,val:d.style.display}),d.style.display="block");for(var d=a(b),e;e=c.pop();)void 0!==e.W&&(e.Z.style.display=e.W);return d},Ha=function(a){for(var b=document.getElementsByName("surveyOptions"),c=0;ce''e>g''a.h)){var h=sa();c=r(function(){var a="";g=g&&Y(this);g--},a);c();0parseFloat(F)){E=String(H);break a}}E=F}var I=E,w={},J=function(a){x(a,function(){for(var b=0,c=p(String(I)).split("."),d=p(String(a)).split("."),r=Math.max(c.length,d.length),h=0;0==b&&hthis.D&&(this.i=-1,U(this,1,a),null!==this.g&&(this.g.registerFinalizeCallback(m(this.g.fireOnObject,this.g,"attempt_survey_trigger",["wfocus",this.C,this.B,this.l,this.w,this.s,a])),5E3 (function(){var l=this,aa=function(){},ba=function(a){var b=typeof a;if("object"==b)if(a){if(a instanceof Array)return"array";if(a instanceof Object)return b;var c=Object.prototype.toString.call(a);if("[object Window]"==c)return"object";if("[object Array]"==c''"number"==typeof a.length&&"undefined"!=typeof a.splice&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("splice"))return"array";if("[object Function]"==c''"undefined"!=typeof a.call&&"undefined"!=typeof a.propertyIsEnumerable&&!a.propertyIsEnumerable("call"))return"function"}else return"null";else if("function"==b&&"undefined"==typeof a.call)return"object";return b},m=function(a){return"string"==typeof a},ca=function(a,b){var c=Array.prototype.slice.call(arguments,1);return function(){var b=c.slice();b.push.apply(b,arguments);return a.apply(this,b)}},p=Date.now''function(){return+new Date},q=function(a,b){var c=a.split("."),d=l;c[0]in d''!d.execScript''d.execScript("var "+c[0]);for(var e;c.length&&(e=c.shift());)c.length''void 0===b?d=d[e]?d[e]:d[e]={}:d[e]=b};var da=function(a,b,c,d,e){if(e)c=a+("&"+b+"="+c);else{var f="&"+b+"=",g=a.indexOf(f);0>g?c=a+f+c:(g+=f.length,f=a.indexOf("&",g),c=0e?c[1]="?":e==d.length-1&&(c[1]=void 0)}return c.join("")};var la=Array.prototype.indexOf?function(a,b,c){return Array.prototype.indexOf.call(a,b,c)}:function(a,b,c){c=null==c?0:0>c?Math.max(0,a.length+c):c;if(m(a))return m(b)&&1==b.length?a.indexOf(b,c):-1;for(;cb?null:m(a)?a.charAt(b):a[b]]''""}var b=u;if(wa())return xa(b);var b=va(b),c={};ma(b,function(a){c[a[0]]=a[1]});var d=ca(pa,c);return v("Opera")?a(["Version","Opera"]):v("Edge")?a(["Edge"]):w()?a(["Chrome","CriOS"]):(b=b[2])&&b[1]''""},xa=function(a){var b=/rv: *([\d\.]*)/.exec(a);if(b&&b[1])return b[1];var b="",c=/MSIE +([\d\.]+)/.exec(a);if(c&&c[1])if(a=/Trident\/(\d.\d)/.exec(a),"7.0"==c[1])if(a&&a[1])switch(a[1]){case "4.0":b="8.0";break;case "5.0":b="9.0";break;case "6.0":b="10.0";break;case "7.0":b="11.0"}else b="7.0";else b=c[1];return b};var za=function(a){za[" "](a);return a};za[" "]=aa;var Ba=function(a,b){var c=Aa;return Object.prototype.hasOwnProperty.call(c,a)?c[a]:c[a]=b(a)};var Ca=function(a,b){for(var c in a)Object.prototype.hasOwnProperty.call(a,c)&&b.call(void 0,a[c],c,a)},Ea=function(){var a=Da;if(!a)return"";var b=/.*[&#?]google_debug(=[^&]*)?(&.*)?$/;try{var c=b.exec(decodeURIComponent(a));if(c)return c[1]&&1e)return"";a.c.sort(function(a,b){return a-b});d=null;c="";for(var f=0;f=n.length){e-=n.length;b+=n;c=a.g;break}else a.l&&(c=e,n[c-1]==a.g&&--c,b+=n.substr(0,c),c=a.g,e=0);d=null==d?g:d}}f="";a.h&&null!=d&&(f=c+a.h+"="+(a.P''d));return b+f+""},Ka=function(a){if(!a.h)return a.o;var b=1,c;for(c in a.f)b=c.length>b?c.length:b;return a.o-a.h.length-b-a.g.length-1},La=function(a,b,c,d,e){var f=[];Ca(a,function(a,h){var g=Na(a,b,c,d,e);g&&f.push(h+"="+g)});return f.join(b)},Na=function(a,b,c,d,e){if(null==a)return"";b=b''"&";c=c''",$";"string"==typeof c&&(c=c.split(""));if(a instanceof Array){if(d=d''0,de?encodeURIComponent(La(a,b,c,d,e+1)):"...";return encodeURIComponent(String(a))};var Oa=function(a,b,c,d,e){if((d?a.O:Math.random())b;){try{if(c.google_osd_static_frame)return c}catch(e){}try{if(c.aswift_0&&(!a''c.aswift_0.google_osd_static_frame))return c.aswift_0}catch(e){}b++;c=c!=c.parent?c.parent:null}return null},vb=function(a,b,c,d,e,f,g){f=g''aa;if(10=e)){var f=Number(c[d].substr(0,e)),e=c[d].substr(e+1);switch(f){case 5:case 8:case 11:case 15:case 16:case 18:e="true"==e;break;case 4:case 7:case 6:case 14:case 20:case 21:case 22:case 23:case 24:case 25:e=Number(e);break;case 3:case 19:if("function"==ba(decodeURIComponent))try{e=decodeURIComponent(e)}catch(h){throw Error("Error: URI malformed: "+e);}break;case 17:e=na(decodeURIComponent(e).split(","),Number)}b[f]=e}}b=b[0]?b:null}else b=null;if(b&&(c=new M(b[4],b[12]),N&&N.match(c))){for(c=0;cW&&!T&&2==Y&&pc(t,"osd2","hs="+W)},rc=function(){var a={};qb(N,a);a[0]="goog_dom_content_loaded";var b=sb(a);try{pb(function(){wb(b)},10,"osd_listener::ldcl_int")}catch(c){}},sc=function(){var a={};qb(N,a);a[0]="goog_creative_loaded";var b=sb(a);pb(function(){wb(b)},10,"osd_listener::lcel_int");dc=!0},tc=function(a){if(m(a)){a=a.split("&");for(var b=a.length-1;0osdlfm(-1,'','BBMfmsErtV-6UA9OznASF5JzICQCB-vTX4QEAABABOAHIAQngAgDIA5sE4AQBoAYuwhMYChAQme-Z_QciCAgCEAEYASAAGMOK0P0D','',1804538184,true,'ocy\x3d1\x26ud\x3d1\x26la\x3d0\x26',3,'CAASFeRoYGJ8gviuaMdSC1q9lAGtgeOdCQ','//pagead2.googlesyndication.com/activeview?avi\x3dBBMfmsErtV-6UA9OznASF5JzICQCB-vTX4QEAABABOAHIAQngAgDIA5sE4AQBoAYuwhMYChAQme-Z_QciCAgCEAEYASAAGMOK0P0D\x26cid\x3dCAASFeRoYGJ8gviuaMdSC1q9lAGtgeOdCQ');if (window.top && window.top.postMessage) {window.top.postMessage('{"googMsgType":"adpnt"}','*');}{"uid":3,"hostPeerName":"https://www.cnet.com","initialGeometry":"{\"windowCoords_t\":0,\"windowCoords_r\":1280,\"windowCoords_b\":984,\"windowCoords_l\":0,\"frameCoords_t\":1002,\"frameCoords_r\":1216.5,\"frameCoords_b\":1252,\"frameCoords_l\":916.5,\"styleZIndex\":\"auto\",\"allowedExpansion_t\":0,\"allowedExpansion_r\":0,\"allowedExpansion_b\":0,\"allowedExpansion_l\":0,\"xInView\":0,\"yInView\":0}","permissions":"{\"expandByOverlay\":false,\"expandByPush\":false,\"readCookie\":false,\"writeCookie\":false}","metadata":"{\"shared\":{\"sf_ver\":\"1-0-4\",\"ck_on\":1,\"flash_ver\":\"23.0.0\"}}","reportCreativeGeometry":false,"isDifferentSourceWindow":false}" scrolling="no" marginwidth="0" marginheight="0" width="300" height="250" data-is-safeframe="true" style="border-width: 0px; border-style: initial; vertical-align: bottom;"> Step 5: Right-click on the AutoHotkey icon from the taskbar and select Reload This Script.
[email protected]
