My TV goes on and off on its own.
I have a LCoS Projection TV, blue dots are appearing on the background 24/7. We have no blue colour at all instead there is green on those pictures. The TV from time to time goes on and off(even if it is off the 'red' standby light can go off)
Model- 71SAID_AA
Make- LG
  • 5,138 Answers
Bad light engine call Encompass Parts 1-800-639-3328
Posted on Feb 08, 2010
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Near the bottom edge of the screen on my Wega KF-50WE 610 has appeared a ''blue haze'' that appears after the TV has warmed up. It started a few days ago as ''fuzzy blue dots'' about the size of silver...
This was caused by a defect in the optical block of the TV. It will only get worse with time and the only way to fix it is to replace the whole optical block which is very expensive (over $1000 usually) and time consuming (you need to take the whole TV apart). However, since it was a defect, there was a class action lawsuit that caused Sony to extended the warranties for certain models on the optical block for parts and labor. Call Sony to see if your model was one of the ones they extended the warranty for.
Oct 04, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Sony 65" Rear Projection loses picture, then gets diagonal lines
This is common problem on this tv, picture tube is bad. Blue and green is more % bad.
Thank you
Aug 07, 2009 | Hitachi 51F59 51" HDTV Projection...
Need to take off tinys green dots in my screen tv.
It seems that your DLP Engine is going. The DMD board in the engine is the problem. it is an expensive fix
Jun 29, 2008 | Olevia Televison & Video
Kolin PT-501 LCD/LCOS HDTV, rear projection TV
Well i really do not know what that is but i do have a thought it could be a bad connector and if you want i have the same tv for sale for $300 shipped just for parts the problem with my pt501 was the screen turned colors but the lamp is in excellent shape and so is the lcos screen the ownly thing that does not work is the main board (ciruit board) i will send you the hole thing for just 300$ shipped if you'd like email me back giovani.rivera@yahoo.com
Jun 29, 2008 | Olevia Kolin DLT2711M 27 in. LCD...
Onscreen menu appears greenish
call tech and suggest to balance your screens ..they will know the procedure.
Nov 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Blue out of focus; casting blue "glow"
Be very carefull replacing the fluid as leaks will short stuff out and are messy.
Jun 12, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
