Question about Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum
I have the Bissell Pro-heat 2X which is new and only used one time and today I am trying to use it and the brushes will not work at all. They will not turn and spin like they are suppose to.....Please Help ! John Baumgartner Roanoke, VA
  • 281 Answers
Look on the front of the little gree guy and where the switches are you should see a small diagram of a brush above or below one of the switches flip the switch to the brush diagram
Posted on Apr 11, 2009
  • 27 Answers
Check your belt. Your belt could have come off or burnt out. There could be something jamming the roller.
Posted on Feb 23, 2008
Hi my Bissell pro heat 2x the brushes don't turn and nothing come out like the water what to do
Bissell 2X machines are famous for this. The brushes not turning is probably just a broken belt but the not spraying is a bad solenoid. I've never seen a 2X that didn't fail after about 6- 8 uses
Jul 02, 2017 | Bissell Vacuums
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell proheat 2x troubleshooting
depends on the suction capability generally the are slower than the bottom as you don't have to go over this with as much power/force hopes this helps
Apr 15, 2014 | Vacuums
Bissell pro heat 2x brushes are not turning???
Brushes are controlled by belts. They must have come off or broke.
Sep 27, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Replacement electric motor for Bissell Pro Heat 2x Select carpet
bissell proheat i can spray solution from the handle but it has no suction help
Mar 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Roller brushes siop after a couple of seconds
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
87uyf
Jan 17, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x multi surface carpet cleaner making spots
maybe there's not enough vacuum or it hasn't been primed enough. I have a proheat that drove me crazy till I started leaving the heat switch on. I get wads of carpet fiber that mat around brush and spit out on the carpet, so I frequently remove them. I'm just wondering if after you empty the water, it may not have built up the suction. Good luck! hope this may be helpful
Jan 13, 2009 | Bissell 1699 ProHeat Clear View Upright...
Bissell Pro Heat 2x steam cleaner, problems!
Must likely the brush motor is bad. The top cover has to come off to check it, this is where the tank sits on. Part # 2036757 and is #35 in the pix.
Mar 14, 2008 | Vacuums
Kenmore Progressive Bagless Upright with Inteli-Clean SystemVacuum Logo
130 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
