Question about Dell Precision M70 Notebook
Screen Problems My screen keeps whiting out, I think that there is a pin in the monitor that keeps coming disconnected. How can I fix this
  • 96 Answers
You can attempt to open the notebook up and see if the display plug is unplugged a bit. Unfortunately this will void your warranty.
-CompDoctor
Posted on Feb 08, 2010
My screen wont display
If you disconnect all the cables except the power cable, is the screen still white? White is unusual as it is the presence of all colors. Thus the white is probably coming from the video source.
If possible connect to a different video source.
Dec 09, 2013 | Samsung S22C150N 21.5" LED Monitor
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
Attention autoconfig please wait -- this message keeps popping up in the monitor continuously. it also adjusts the contrast anf brightness some times automatically. please help
Sounds like the "auto config " is built in to your monitor. It selects screen sizing based on the resolution, sync timing, refresh rate, etc... that your video card is adjusting on the computer.
I would suggest you to try changing the resolution in Windows and see if still receive the alert.
For more information on Screen resolution and display on monitor, check the below Microsoft Help & How-To Articles:
1:
Change screen resolution :-
http://windows.microsoft.com/en-us/windows-vista/Change-screen-resolution
2: Getting the best display on your monitor :-
http://windows.microsoft.com/en-US/windows-vista/Getting-the-best-display-on-your-monitor
3: Troubleshoot monitor and video card problems :-
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-monitor-and-video-card-problems
If it is doing it often and you are not changing screen resolution I would say the monitor itself might have issues. It's possible your display driver may be corrupted. I would suggest you to download and install the latest drivers for the Monitor from the manufacturer's website.
For more information on Updating a Driver and fixing driver problems, check the below Microsoft Help & How-To Articles:
1: Update a driver for hardware that isn't working properly
http://windows.microsoft.com/en-us/windows-vista/Update-a-driver-for-hardware-that-isnt-working-properly
2: Tips for fixing common driver problems
http://windows.microsoft.com/en-US/windows-vista/Tips-for-fixing-common-driver-problems
Check the plug and cable, look for bent pins or pins pushed in.
Are you using one of those DVI/VGA adapters? If your monitor has dual inputs (DVI & VGA) have you tried using the other input?
Anyway you could check if the issue exists when the monitor is connected to another PC? Or maybe try another monitor on your PC?
source: answers.microsoft.com
Mar 12, 2011 | Computers & Internet
Screen is white when on.....
Try disconnecting your connection to your computer.
If you see a no signal message with a dark background, you have problems with your video card.
If you continue to recv. the white screen, you have input signal problems with the LCD monitor itself.
If you do recv. a no signal message witha dark background, try removing and reseating the video card.
Oct 24, 2009 | ViewSonic VX2235wm LCD Monitor
Won't power up with or without battery
i think u need a free diagnosis of ur system. there is a link i am sending u which provides free diagnosis.
http://tinyurl.com/m7ghqz
Jun 18, 2009 | HP Pavilion ze2000 Notebook
Samsung Syncmaster 940n - white screen
This is a known symptom of a failed power supply board. Here is a repair guide for this unit that shows how to dis-assemble the unit and then what to look for and replace to rebuilt the power supply board and bring the monitor back to life.
http://www.ccl-la.com/blog/index.php/repairing-a-samsung-940n-with-a-blinking-power-light/
And here is a picture of the power supply board.
I hope this helps you, if so please rate my solution.
BuddyMc
Mar 25, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Mitsubishi diamondpro 930sb flickering
I have had the same problem with my 991sb and most recently my 930sb. The first was replaced at NEC's expense however on this second one i'm out of luck. I think its a problem with its power inverter. It may be repairable by a tv repair place. I'll be looking into it and let you guys know.
Sep 06, 2007 | NEC Diamond Pro 930SB 19" CRT Monitor
Picture problems
What are normal things like text files and the desk top like? If it only photos that are problematical then it won't be the screen. Have a check around the system and a little think through- them come back
Jul 09, 2007 | Philips 170C4FS 17" LCD Monitor
Monitor Black, Green Power Light Flashes Monitor is 4 yrs. old
Assuming you've already checked your driver and system settings, tried a different monitor, and checked the cable and connector pins, this would almost certainly be a problem with the power or signal circuit board inside the monitor.
Jan 19, 2007 | ViewSonic VA720 17" LCD Flat Panel Monitor
Dell Precision M70 Notebook Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
