Question about NetGear DG834G Router
The port on my netgear router are not lit and the modem is not recognised
  • 298 Answers
If this is the case, the router might have a problem with the ports. But here are things that you can do to test the router:
* Use a know working Ethernet cable.
* Reboot the router.
* Reset the router, but this will erase all of the settings that you currently have set on it.
* Test if the wired connection through the modem and make sure that it will work. This will also tell us whether the modem is working fine or not.
If all of the things will not get the Ethernet or the Internet light to come on on the router. I strongly recommend that you have it checked by the router manufacturer to have it replaced specially if it's still under the warranty. As far as I know wireless router has at least 3 years warranty.
Posted on Feb 08, 2010
Ialso have suddenlink
How to Set Up a Netgear WGR614 V5 Wireless Router
Netgear routers--like all wireless routers--give you the opportunity to access the Internet with your laptop or wireless-adapted computer from virtually anywhere in your house within range of the router's WiFi signal. Though slightly different in appearance from other router models by Netgear, the WGR614 V5 acts similar in its setup process as others such as the WGT624 or WNR1000 series routers.
Things You'll Need:
Netgear WGR615 V5 routerNetgear resource CDEthernet wireBlue network wireModemComputer
1 Prepare to install the Netgear router. Log off and shut down your computer system. Turn your Internet modem off and/or disconnect its power supply from the electrical outlet. Take out the contents of the Netgear router box and verify that all the essentials are present: the resource CD, the yellow wire and the router itself.
2 Connect the Internet modem to the Netgear WGR614 v5 router. Locate the yellow Ethernet wire running from one end of the Internet modem to the computer's Ethernet port. Unhook the computer-end of the Ethernet wire and insert this end into the port on the router labeled "Internet." After inserting, confirm that the wire runs from the modem to the router.
3 Connect the Netgear router to the computer. Grab the blue cable supplied with the router. Securely insert one end of the blue cable into one of the four "LAN" ports on the router (the "LAN" ports are labeled with numbers from 1 to 4). Insert the other end of the blue wire into your computer's Ethernet port.
4 Start your network devices. Turn on or connect your Internet modem to an electrical outlet. Wait for at least two minutes to allow the modem to fully boot. Plug the Netgear router into the wall or electrical outlet as well, and wait one to two minutes. Turn on your computer.
5 Look at the Netgear router to verify that all lights are on. The "power," "Internet" and "wireless" icon symbols on the front of the router should be solidly lit. One of the four "LAN" ports should also be lit with either a green or amber color.
6 Insert the resource CD that came with your Netgear router to launch the "welcome" screen. Select "Router Setup" from the menu to begin the "Smart Wizard" setup application. Read and follow the setup steps, including naming your SSID (secure set identifier) or "network name" and setting a level of wireless security. Finish the setup process, ending with the registration of your Netgear router.
7 Verify that your Netgear router has been set up correctly. Open an Internet browser from both the computer that is connected to the router and on a computer that has a wireless card or adapter. Surf to your favorite Internet sites to verify your connection is working. Open your "network connections" utility on your operating system and make sure it shows that you're connected to your own wireless network.
Jan 09, 2012 | NetGear WGR614 Wireless Router
Our netgear wgr614v7 54 mbps wireless router has gone bad acording to our net work service.They tested there modem,that had astrong signal.now here is whats happnen,there is no signal frm modem to wireless...
This guide gives you the directions for setting up wireless on the Netgear WGR614v7.
Basically enter the routers ip address (192.168.1.1) in your browser. If you router has default configurations, then enter the username as "admin" and the password as "password." Navigate to "wireless settings" and then on that page you configure your network.
Jun 13, 2011 | NetGear WGR614 54 Mbps Wireless Router -...
Hi I would like o hook up a netgear prosafe 8port gigabit switch to my pc and run an ethernet cable which is allready hardwired to my sony bluray player so I can enjoy netflix
It would be much easier to use a simpler device, namely any Netgear 10/100 wireless router.
Cable-modem (or DSL-modem) --> Router's WAN port
Router's LAN port #1 --> your desktop computer
Router's LAN port #2 --> your Sony player
Router's wireless adapter --> your iPod Touch's WiFi adapter
Since the cable-modem (or DSL-modem) is only delivering 5 to 25 Mbits/second to your router,
unless you are paying a _lot_ of money per month to your ISP,
there's no need to buy/use expensive "gigabit" equipment.
Jun 06, 2011 | NetGear ProSafe GS108 8-Port Gigabit...
Can i use a wireless cable modem gateway (netgear) to make my current dsl modem connection wireless.
If your DSL-modem has one Ethernet port, then use an Ethernet cable to connect from that port to the WAN port on your NetGear router. Then, the router will provide both "wired" and "wireless" connections to your computers & devices.
Feb 13, 2011 | Computers & Internet
How to tell your net gear router is no longer working correctly It connects to the internet throuigh the modem I am plugged into port # 4 and I have tried port # 1. At any given time I loose connection and...
HI jamesbigble. To see if I understood your problem correctly. You are using a computer thru a router. And the router is connected to a modem. After a while all the lights on the router are lit. And then you have to unplug it and plug it in again and it will work for a while right? Well, if that's the case, that's the router for sure, you need to replace it. If you see something like that happening to the modem, well the same answer for the modem. If any modem, router or switch have all the lights lit, it means some serious problem. Maybe hardware/power or firmware issue. In case you dont want to spend money, I would recommend go to the netgear website and download the latest firmware for your router and try it. I hope this helps. Please dont forget to rate and write positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
How to connect Netgear to Time Warner internet modem? I have Netgear installed on my computer, and I have the internet modem plugged in to my computer.
Just disconnect the ethernet cable from the computer and put it into the slot called internet on the router then run ehernet cable from port 1 to computer.
Dec 05, 2009 | NetGear WGR614 Router
NetGear DG834G Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
