Question about Sony Office Equipment & Supplies
Lamp cover error please help - Sony Office Equipment & Supplies
  • 3 Answers
Lamp/cover problem in sony es 4 is in two parts, in first case, the led keeps blinking.in this case problem is related with cover switches and thier connection with main board. in second case, led glows permanently, in this case either lamp or ballast pack may be faulty.
Posted on Aug 06, 2010
Just moved my 52 inch sony wega and when we plug it in and try to turn it on it blinks red three times and does nothing
Welcome to fixya.com!
3 Red blink error shows that lamp cover is not fixed properly after lamp replacement.or either its moved, replaced Etc .
Please check Lamp Cover and put it back properly as it should be .
I hope that helps you. do comment if its not
Fixed tell us if there is any error message showing we will help! just comment with a messege
Apr 30, 2011 | Sony Grand WEGA KDF-42WE655 42" Rear...
Power ligth blinks three times then starts blinking red tv wont start
Lamp cover error, lamp cover is not attached securely. Please check the lamp cover if deformed. If the lamp cover has been deformed due to excessive heat exposure, replace it with a new one. Sometimes the lamp cover melts due to overheating caused by poor air ventilation. Clean the fan and lamp compartment to avoid overheating....
Nov 30, 2010 | Sony KDS-60A2000 60" HDTV
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
I cant get a picture to display after just replacing the lamp
After replacement of lamp, please put back Lamp Cover securely as TV shows error of lamp cover (3 times blink)
May 07, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Replaced lamp in my sony55 inch tv still have lamp error 1
hello, if your still getting the lamp error then your lamp cover is'nt on right i'ld suggest taking cover off then re-installing it if the t.v. is'nt reading the lamp cover then it'll give you this error after re-placing the lamp, also take the lamp out and re-connect make sure the 2 prongs are on the lamp tight.
Mar 31, 2009 | Sony KDF-E55A20 55 in. LCD Television
Turn off
I think you recently replaced lamp or opened lamp cover which is not installed properly.
Please check Lamp Cover because 3 times error shows that lamp cover is not fixed.
Feb 19, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
E3 error on fujitsu fi-5530C
You have a rear optical error.
check the lamp is lighting.... open the ADF and push in the cover open switch. if one if off, replace it or the lamp inverter
swap the cameras over to be sure the fault follows to an E2
replace the optical unit
good luck
Jan 09, 2009 | Fujitsu fi-5530C Scanner
I have SONY KDF-50E2000 about 15 months old with expired warranty. One day it just refused to turn on. I have green power light for couple seconds, after that it starts blinking red 3 times with interval....
Its definately the error for lamp cover or lamp position error either the lamp door switch is broken or the lamp contacts are not making contact
Jan 08, 2009 | Televison & Video
Sony VPL-ES3 Multimedia
Hi Marsat!
Actually both the filter cover and lamp covers have a long straight plastic part which is inserted in small hole. At the end of the holes are micro switches. When you fit the filter cover this switch is pressed and projector knows that it is ok to turn on. Similarly if lamp cover is loose the micro switch is not fully pressed resulting in this message. Tightening it presses the micro swith and the indication vanishes. In your case if plastic parts are intact, lamp cover screw is fully tight, filter is clean and properly seated with a click sound, then may be some micro switch has malfunctioned and you have no option but to take the projector to some qualified repariman.
Regards
Raheel
Jul 10, 2008 | Sony VPL-ES3 Multimedia Projector
Hi again
yes 3x its lamp cover no doubt. ballast supply will give different error on this unit. this should help hdtv man
Diagnostic Item
Description
Number of times
STANDBY or LAMP LED
lamp flashes
Probable Cause Detected Symptoms
Lamp cover error 3 times - Lamp cover is not fastened securely - No picture/No sound
Fan error 4 times
- Fan1-4 Power is not supplied.(G2 board)
- Fan connector is not seated securely
- Fan caught wires or harnesses
Temp error 4 times
- Internal temperature is too high
- IIC-E line connector is not seated properly
(WE:H3 board, WF/XS:H4 board)
Lamp driver error 5 times - Lamp driver defect - No picture/No sound
Low B error 6 times -No "DD 6V " output (G1 board) - No picture/No sound
Audio error 7 times
- Short-circuit of Audio power supply line
(KD board, G1 board)
- Blowout of a fuse
(F4702,F4703,F4704 on KD board)
- IC failure
(IC4703,IC4708,IC4710 on KD board)
D-OVP error 8 times
- Overvoltage of +3.3V or +2.5V
(A board, B board)
ATSC-OVP error 10 times
-No "DTL MODULE 5V " output
(G1 board, G2 board)
Lamp error LAMP-LED is ON. - Lamp is dead - No picture/No sound
Jul 01, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
1,826 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
