Question about ViewSonic G800 20" CRT Monitor
Horizontal widh shrinked
After changed the resolution from 800*600 to 1024*768 Horizontal scanning failed. All picture concetrated in the thin (about 8mm) column in the center of the screen. osd controls working only horizontal width not.
Changed back the resolution bat the same problem.
Help me pls.
  • Deak Imre Feb 23, 2008
    Cheked and changed the Q303 (2sc4290) strartup ok bat after 5 seconds started to shrink again ,after power down and wait 5 min started up ok dat the same problem after 5 sec
  • 981 Answers
Huh, it sounds like the monitor's horizontal deflection amp (a big transistor) failed. It is not so if you can feed it a good signal and get a wider picture.
You would replace that thing with a transistor with a similar drive profile (i.e. not a FET), if you practice the right safety; better to use a service tech to do it unless you were trained in it. Alternately, you can try freezing your monitor (wrap it to keep out condensation! I only mention this because it's freezing out, where I am....) and see if this helps the transistor recover; it's not that sage or safe though, because of the condensation/electricity hazard and unlikely event that you will ground a work bench surface to do this test!
Be safe and consider using lower-power-consumption flat screens in warm weather.
Posted on Feb 23, 2008
No picture. Just a thin horizontal band of light running through the center of TV.
HI,
Your tv has problem with its vertical scanning side. vertical scanning output ic (integrated circuit ) may have some problem ( faulty or dry soldering in its leads). You can easily find out the vertical ic on your tv. there will be four wire coming from the coil which is fitted on the picture tube neck, of which 2 will goto horizontal scanning section and the remaining two will go to vertical scanning section. just follow the two thin wire (normally in color green and yellow ). it will goto a socket on the main board. follow the track on the board. it will lead u to vertical scanning section. check for any dry soldering, if not , replace the ic.
ok
Mar 07, 2011 | Mitsubishi CK-35308 35" TV
There is a horizontal line in the mid
Hello
The vertical scan of your TV has failed. All picture tube type TVs have both horizontal and vertical scan sections to scan the picture on the secreen. When horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line through the middle of the screen. In your TV, the second stated has happened.
This may be due to an IC trouble or a voltage loss inside the printed circuit board of your TV. To rectify this fault you have to open your TV, and locate the vertical output section inside it. It is very easy to locate that section. There will be four wires goes from the deflection yoke; the coil fitted at the neck of the picture tube; out ot which, two will be thick and the other two will be thin. The thick wires are usually colour coded as red and blue. Colour coding may differ from set to set. Anyway you have to follow the tow thin wires, as they are carrying vertical scan signal to the yoke.
Following it, you will reach to a plug in point on the printed circuit board. Upside down the printed circuit board, and follow the track through which that wire connection goes, and finally you will reach to the vertical output section.
There may be transistors or IC used on that section. First check the voltage at the vertical output section. Voltage lose also may occur in this section. If it uses IC, check for any loose or bad solderings at the terminals of the IC. I advice you to resoder the suspected points by applying a little more solder, without shorting the terminals. In most cases this will solve the problem. If there is voltage, and there is no loose solderings and still the fault perists, replace the IC or transistors, whatever it may be, with same type and number.
If you want anymore asistance, fee free to contact me through Fixya. OK.
Dec 27, 2010 | Toshiba CF30F40 30" TV
Blank screen except for a single horizontal line through the middle of the screen.
Hello
Your TVs vertical swee sction has failed. All CRT based TVs have both vertical and horizontal sweep sections to sweep the picture both in vertical and horizontal direction to display it on the picture tube screen. This process is otherwise called as scanning. If vertical scan section fails, you will see a horizontal line at the middle of the screen and if horizontal scan fails, you will see a vertical line on the middle of the screen.
You have to open your TV to retify this fault, as the fault lies in the internal circuit board. Open it after disconnecting it from the mains wall socket, and locate the vertical output section inside. It is very easy to locate. On opening you can see a coil fitted on the neck of the picture tube, called deflection yoke, and there will be four wires from it goes to the main board. Out of which two of them will be thick, and the other twos will be thin. The thick wires are usually colour coded as red and blue. Just follow the two thin wires. You will reach to a plung in socket to which these four wires together connected. Turn upside down the circuit board, and follow the print track through the print side of the above said two thin wires connection goes. it will go to the vertical output section.
Before doing any thing, first look into the circut board for any loose or bad solderings are there. It is a common fault that this section have loose solderings on it, because most of the components will heat up while working. Repeated heating and cooling, make loose soderings to emerge.
Resolder all the suspected points, as loose solderings will be microscopic,a nd acnnot be detected very easly. We in the service field also will fist do this.
Usually vertical output section is composed of an IC related circuit. Solder all pins of that Ic first and feel the effect. If this does not help, desolder the IC out of the board, will be screwed on to a metal heatsink, go for the same type and number. Replacing the IC will solve your problem.
If you wants any more assistance, feel free to contact me through Fixya. OK.
Dec 09, 2010 | Toshiba 32A30 32" TV
Picture has been reduced to a thin line in center of set sound and remote functions still work
Hello
Your TVs vertical output section has the trouble. All TVs have both vertical and horizontal scanning sections, which scans the picuture on the secreen both vertically and horizontally, to get a picture frame. If horizontal scan fails, you will see a vertical line at the middle of the screen, and if vertical scan fails, there will be a horizontal line across the middle of the screen. Your TV has the second stated trouble. To get it rectified, you have to open your Tv.
Unplug your TV from mains socket and open it. Locate the vertical output section. It is so easy to locate. Your TVs picture tube neck id fitted a coil alongwith it, which is called the deflection yoke, and it will have four wire connections. Out of these four wires, two of them will be thick, usually red and blue in colour, and the other twos will be thin. Just follow the two thin wires, you will reach to a point that these four wires are plughed onto a pin connection, on the main printed circuit board.
Upside down the board, and trace the track to which these two thin wires goes, through the print side, will reach to the vertical output section.
Normally this section consists of an IC for this purpose, and can be screwed onto a metal heatsink, as it will get heated when it works. Before unsodering it , just look at the soldering points of this IC pins for any loose soldering points. Loose soldering are very difficult to locate, as thay will be very minute up to microns, so resolder all the pins of this Ic, by applying a little more solder, and see the effect. Sometimes this will resolve the problem. If not go tho the main input voltage that goes to Ic pin. If it is not there, check out the reason. If it is there and still vertcal scanning does not occur, resolder out the IC from the circuit board, and go for a same type and number.
If you wants anymore asistance, feel free to contact me through Fixya. OK.
Dec 08, 2010 | Insignia NS-RTV32 32" TV
Insignia 32" Tube TV NS-RTV32
The vertical output IC LA7847 is failing. It will likely fail permanately and you will have just the horizontal line. The set will require service. Just do not run the set very long in this state. That thin white line can likely burn into the crt phospher and will show all the time thus ruining the glass picture tube...
Jun 05, 2008 | Televison & Video
Horizontal display
Check with the manufacturer information that you have the refresh rates and maximum resolution set correctly. If in doubt, go to your display properties and try something basic to test if this is the problem. A basic setting may be as low as 1024x768 at 60 Hz.
(You can access your display settings by right-click the desktop anywhere and choose properties, then settings).
Leave the monitor at that setting for a while to see if the monitor changes the picture.
If the picture changes, it may be component failure in the monitor. If not, the problem is then related to the settings from your VGA card are too high or dense causing the monitor to fail after a time. Try something higher like 1280x1024 @ 60Hz and keep going till the picture fails. Compare the best functioning resolution with the manufacturer claims about the product in the product documentation.
Be sure there are no cable bunches and the power cables are not wrapped up with the VGA cable under the desk or there are not too many cables lying about, although unlikely, this has been known to distort the picture.
Let us know if this helps.
Cheers
Gund
Mar 30, 2008 | LG Studioworks 775N 17" CRT Monitor
Scanning
One approach that works for me is to scan the document at high resolution and then shrink it afterwards. For some reason this seems to result in higher quality than scanning at the final (lower) resolution in many cases. For example I use ACDSee Photo Manager to scan or post process a scan from elsewhere. Within ACDSee there is an option in the jpg output (file save as) dialog for quality versus compression. I set this to default to the highest compression and resave the jpg or convert to jpg if the file did not start out that way. This generally shrinks the file by up to 2x or even 4x without any degradation that I can see. For example the screen capture below went from 39k to 18k after this step with no resolution change. If that is not enough I then perform a resize operation, for example 50% which would further reduce the file size down to a quarter of the input size (the dimensions in each direction would shrink by 50%. Even after shrinking, I find that files lookbetter than if they had simply been scanned at the final resolution.f611aa5.jpg
Dec 06, 2007 | Brother MFC-8860DN Printer
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Aug 22, 2006 | Jensen TS2750J TV
A thin horizontal line across the screen
I know I have seen thin lines in the past on older CRT monitors, these are usually wires which support the aperture grill. LCD is just a panel so this must be something different. What color is the line? It is probably an error in the scanning process.
Aug 01, 2006 | Gateway FPD1975 19" LCD Monitor
Horizontal scanning does not work
You have high voltage. Horizontal sweep is not working. Mostly we see shorted sweep transistor. Mike
Jul 03, 2006 | iiyama Vision Master Pro 510 22" CRT...
ViewSonic G800 20" CRT Monitor Logo
51 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
