Question about ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
I cant set up my xbox 360 on my esa tv - ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
3 Suggested Answers
JULIANFIX
  • 975 Answers
SOURCE: help with getting to video
TRY THE SAMSUNG CODES for any universal remote
Posted on Apr 23, 2008
cash360
  • 9 Answers
SOURCE: my esa tv keeps searching picture comes and goes
My thoughts are, they threw it out for a reason!
Posted on Jan 25, 2012
I have an xbox 360 hdd 120gb its working but i only have a picture but no sound. i have checked the settings, has anyone had the same problem?
Sound is turned all the way up in the setting and the TV? Still cant hear it? Try a different cable if all else fails.
Oct 28, 2012 | Microsoft XBOX 360 120 Gig Hard Drive -...
My esa tv keeps searching picture comes and goes
Jan 25, 2012 | ESA ET427E 27" TV
I cant get a valid ip address for my xbox 360
set settings to automatic
if that doesnt work open command prompt on your computer type ipconfig and hit enter
manually enter the ip and dns settings that come up
if that doesnt work google xbox 360 port forwarding
Nov 17, 2009 | Microsoft Xbox 360 Console
Can't find esa tv code for my xbox universal remote
0415 is the code - ESA is a Sylvania knock-off
Sep 30, 2009 | ESA ET427E 27" TV
I need help getting my tv on component 2 with out a remote
if you can enter you tv set up screen,, plug you xbox 360 in and turn on, then run setup
Aug 12, 2009 | iLO 3200 32 in. LCD Television
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
When x box 360 is plugged in to tv,there is no signal
try reconnecting all the cables and make sure you have the right setting(normal tv or hd, theres a switch on the cable), if that doesnt work, you might have a faulty cable, or even worse your xbox has an interal problem(very hard to explain, read this if you cant connect to tv....(http://xbox-experts.com/e/errorcodes.php) and you'll need to send it to microsoft for repairs.
Nov 12, 2008 | Microsoft Xbox 360 Console
Help with getting to video
Oct 15, 2007 | ESA EF402E 20" TV
ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV Logo
42 people viewed this question
Top ESA Televison & Video Experts
Demonic-2011
Demonic-2011
Are you an ESA Televison and Video Expert? Answer questions, earn points and help others
