Question about Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L)
The computer does not find the hard drive but the motherboard have current
Dont realy know i try hook it up with dvd drive plugs see if it finds it there and go from there
Posted on Feb 08, 2010
WON'T START UP
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
make sure the CPU central processing unit has thermal grease and a dust free secure seating
even something as small as an electrical extension or a faulty fan lead can cause this problem computers need all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
also check your computer ram and cmos battery to make sure they are securely seated and the battery has plenty of charge
some motherboards cmos batteries are soldered in
hope it helps
Mar 31, 2012 | Biostar P4M900-M7 FE Motherboard
Hard drive has power but will not spin up
test all leads that attach frrom motherboard to your hard drive including electrical extensions SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
hope this helps you
Mar 21, 2012 | Toshiba 320GB MK3265GSX SATA 3Gb/s 2.5"...
Western digital lap top drive does not seem to spin at start up 160 gb
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
hope this helps you
Nov 28, 2011 | Western Digital Scorpio WD1600BEVS 160 GB...
Problem : the computer is turning off just few seconds after turning on, this happens after i replaced the motherboard
desktop or laptop computer?
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your computer hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and to have an end so any faulty leads will end up with a computer error
make sure you have enough RAM and the ram modules are securely seated with no dust in the sockets
a computer needs all of the data and electrical current to travel through every working device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this help you
Oct 07, 2011 | ASUS P4P800 SE (890552603657) Motherboard
How to detect sata hard drive P4M800-M7 Motherboard the sata hard drive can't detect
Hi fleetpio,
1. How to detect sata HD?- I am assuming that you have fixed the hardware part. During POST (Power On Self Test) press delete key inyour keyboard.
2. After pressing delete, a menu like the image above will appear. use arrow key to navigate, enter to select, +/- to modify values, Esc to exit current menu and F10 to save settings. proceed to Features Setup and press enter.
3. Another menu will appear like the image shown above, on the Onboard SATA-IDE from IDE change it to SATA-IDE.
4. Press F10, Saves the current configuration and exit setup.
5. To verify if the SATA hard drive has been detected, look on your POST if the HD appears. If the full screen logo appears repeat Step1 proceed to Standard CMOS Setup, check if youre HD appears.
Hopefully this information helps.
Thank you for using FixYa.
Sep 01, 2011 | EliteGroup P4M800-M7 Motherboard
Laptop boot problem
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
hope this helps
Aug 25, 2011 | Biostar 945GC-M7 TE Motherboard - v6.0,...
Seagate 160gb hard drive recognized in device manaager but not my computer why
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they could be faulty ?
one bad lead will end with a computer error a computer needs its connections continue its cycle and have an end to function properly
hope this helps you
Aug 24, 2011 | Barracuda Networks Seagate ST3160215A...
Just installed a new Gigabyte 880GM-D2H motherboard, 4 GB RAM (Corsair DDR3 1333), AMD Phenom II multi-core processor (X6 1055T), 750 W power supply, Maxtor 500 GB hard drive and a Blu Ray DVD Drive. ...
motherboard to hard drive leads
even something as small as an electrical extension or a faulty fan lead can cause this problem computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
hope this helps
Jul 25, 2011 | Gigabyte (GA-880GM-D2H) Motherboard
What type or brand of hard drive do I have to get to install in Acer AM5641 Desktop ? I want to upgrade to a 1 tb hd.
You currently have a 320GB 7200-rpm SATA II hard drive, with 8MB cache install on a base package of your make and model of computer. I would recommend a hard drive like Samsung Spinpoint F4EG 2 TB Internal hard drive. You can find it roughly for $70.00 - $90.00 at online stores like amazon, new egg, etc.
I hope this helps.
Jun 30, 2011 | Acer AM5641-B5660A Desktop PC & Monitor...
My dual core motherboard crashed i am trying to use the 320 gig hardrive with vista os system on this computer. Its all plugged in right i just can seem to help my computer find it. Do i have to disable...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also it could be a dirty computer clean all of the dust from your computer you could use a vacuum cleaner but whatever you use make absolutely sure there is no moisture gets to anything in your computer and before you touch anything be sure to wear an earth strap hope this helps
Jun 01, 2011 | MSI 661FM3-V Motherboard
Foxconn WinFast K7S741MG Motherboard for AMD Socket 462 CPU (K7S741MB6L) Logo
106 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
