Question about Nikon COOLPIX S570 Digital Camera
Lens error shows a 'lens error' message. I have turned it on and off, tried zooming in and out.
  • richter_emil Feb 08, 2010
    thank you. I tried these suggestions, but nothing worked. Anything else I can do?
    Brigadier General:
  • 7,191 Answers
Your problem dated 8th Feb 2010 was re-posted today. If it has been already resolved, kindly ignore this message.
Thanks for using FixYa
Posted on Aug 09, 2010
    President:
  • 2,761 Answers
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. It's also possible that the lens zooming mechanism is sticking due to a buildup of sand, dust, etc. To remedy this, try cleaning the area where the lens meets the camera with canned air. If these solutions don't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair. BillB
Posted on Feb 08, 2010
  • 3,230 Answers
Well lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism or the camera been dropped with the lens extended or the camera has been powered on, but the lens had been blocked preventing its extension or the battery ran down with the lens extended ... you can please follow the below to correct this problem -
Try 1 - Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Try 2 - Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Try 3 - Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Try 4 - Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Try 5 - Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method.
Please post comments if you need more help or information......
Good Luck!!
Thanks
cyrylthewolf
  • 143 Answers
SOURCE: Lens error
It definitely does sound like one of a few things:
  • The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes out.
  • The motor or servo that drives the transmission system is failing.
  • There is a physical deformity of the lens architecture itself that is preventing the lens from coming out.
Any of these symptoms is most likely going to be accompanied by a grinding sound. Especially if the gears are somehow stripped. The "puttering" sound be a description that would fit the sound a motor or servo makes when it's trying to cycle itself over but is failing. (Much like a car that is trying to start up, but just won't turn over?) That would definitely be an indication of a motor going bad in the camera.
Either way, this is something you're definitely going to have to refer to Canon's technical support on. If your camera is still under warranty, you're going to have to get them to replace it or at the very least SERVICE it.
I myself will ALWAYS insist on REPLACEMENT. One might argue that the terms of the limited warranty state that they reserve the right to either replace or service the device...
...but TRUE customer service tells a different story. I have NEVER had anything serviced. I have always had replacements. Either I've INSISTED on it or they've just been smart and not even made it an issue by making it their procedure. I get a brand spankin' new device and THEY get a happy customer.
Always keep in mind how much you spent on their product and ENGRAIN that into their heads.
Here's the deal...
If you ARE out of warranty, get around that by telling them that you DID buy it within the last 9 months and that you do NOT have proof of purcahse. If they insist on asking for it, then humor them and "try" to look for it and once again inform them that you do NOT have it.
They can't really dispute the warranty at that point if they can't prove that you DIDN'T buy it within the last 9 months.
I hate to work the system like that... But I paid $400 for mine. I'll be damned if I'm going to be out the money for it! Am I right?
Anyway... That is the best advice I can give you, unfortunately.
Call them as soon as you can! Get it replaced!
If you think that you can keep yourself together and composed well enough to play the system... Contact Canon's tech support and see what you can accomplish.
Remember... It's not as if you're going to get in any trouble. The worst they can do is refuse you. You have NOTHING to lose but the money you spent on the camera!
Here is their support info.
For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
Good luck with this. Let us know what comes of it. :)
Cyryl
Posted on Nov 17, 2007
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
SOURCE: Zoom Error
1. Remove and change out main batteries.
2.Remove back-up battery (Little coin-sized battery), wait 1 minute, re-insert battery. If no change replace back-up battery.
Posted on Apr 15, 2008
SOURCE: hp photosmart r742-lens error
Press the lens till the little doors close but not at all, i just fix it these ways 2 min ago! I SWEAR, just press it with a little hard and cross ur finger =D it work for me!
Posted on Jan 11, 2009
  • 919 Answers
SOURCE: Zoom Error message
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 29, 2009
My fujifilm s1000 keeps showing "zoom error." I don't know what happend. It's like one day it's working, the next not. I have a family member graduating Friday and can't afford a new camera. I've taken out...
Hi.
If you try turning on the camera with the lens cap on, you may get zoom error. Ensure that you are removing the lens cap before turning on the camera.
If the autofocus ring is held while taking the picture, or operating the lens this will also cause the Zoom error message coming up.
If that is not the problem, then the lens has troubles extending. This may happen because of dust stuck in lens mechanism, or because of a mechanical fault concerning the lens.
Any cause preventing lens from full extention or retraction will trigger zoom error.
Here a basic manual in PDF format.
Here Owners manual.
May 20, 2010 | Fuji FinePix S1000FD Digital Camera
When i turn on my panasonic lumix dmc fz28 it shows system error
HI there the camera lens guide pin is damages and thats why not zoom the image properly . You got the system error message. So you need to replaced or repair the lens guide pin. Thanks.
Apr 01, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Error message ''Lens error'' on nikon coolpix digital camera
Try cleaning any grit out of the lens mechanism with compressed air and a little wiggling of the lens. If that doesn't do it, the camera needs servicing.
Nov 15, 2009 | Nikon Coolpix S210 Digital Camera
Lens error
inside the lens their is strip ,its broken inside change it
Jul 09, 2009 | Casio EXILIM ZOOM EX-Z70 Digital Camera
When I try to turn the camera on, shows message "retry power on"
hola no tengo driver de la camara como puedo vajarlos largan chameleon
Jul 06, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Error message now showing
Does the lens extend and retract as normal?
If so then the internal drive gear for the zoom / focus has been damaged and will need to be repaired/ replaced.
If the whole lens will not move or is stuck then it needs to be removed, stripped and re-assembled.
Feb 18, 2008 | Fuji FinePix F45FD Digital Camera
Zoom error message on fujifilm a350 digital camera
whilst reading out loud instruction to fix the 'zoom error' my wife turned and twisted the zoom lens clockwise and shake th camera gently - all of a certain it worked again as per normal - try it - hope it works for you too!
Feb 17, 2008 | Fuji FinePix A350 Digital Camera
E 18 Message
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 21, 2008 | Canon PowerShot S2 IS Digital Camera
Broken zoom
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Jan 16, 2008 | Canon PowerShot A520 Digital Camera
Nikon COOLPIX S570 Digital Camera Logo
22 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
