Question about Brother CS-8150 Computerized Sewing Machine
Brother Sewing Machine model:CS8150 bobbin thread problems
My brother sewing machine model:cs8150 the bobbin thread tangles and makes a clunking noise only sewed with this 3 times what is wrong
  • 22 more comments
  • Stephieface Feb 23, 2008
    No matter how much I adjust the tension, change the needle, change the thread, change the fabric, and even manually adjust the tension screw on the bobbin cartridge, the lower thread comes out a messy tangle of loops. On my old brother machine (old old old, like 12 years old) the only thing needed was to adjust the screw tighter. with this model, not even that works. Help.
  • Annie K
    Annie K Oct 15, 2013
    take it back and get your money back it has a defect
  • rtark Jan 27, 2014
    Be sure the thread is in the thread take-up, which is the arm that moves up and down. It's easy to miss it on the newer machines
  • Anonymous Mar 12, 2014
    Need manual ee brother machine for threading instructions p
    threads tangle up under bobbin in my New Home Sewing Machine model #L373
  • Anonymous Mar 13, 2014
    could a wrong bobbin size give the check for broken thread message
    My sewing machine will sew correctly with a loaded bobbin, but when I go to reload thread on the bobbin, the winder will not turn.
    how to wind top of brother machine bobbins
  • Anonymous Mar 15, 2014
    my needel hits the bobbin
    How do I thread a JPL2 sewing machine
  • Anonymous Mar 16, 2014
    threading finesse sewing machine
  • Anonymous Mar 17, 2014
    can't figureout how to thread my sewing machine
    what year model is my Brother VX1140 Sewing machine?
  • Anonymous Mar 20, 2014
    Machine not picking up the bobbin thread
    bobbin wont thread propurly
  • Anonymous Mar 21, 2014
    plugged it in threaded it and it makes a noise but won't sew
  • Anonymous Mar 23, 2014
    when i sew the bobbin case wont move
    Okay! I put the clothes in the machine and I start sewing but the machine starts to shake and make banging noises and the light flickers while it does that and beeping noises happen at the same time.. I have a project thats due tomorrow and I really need help fixing this so I could pass this class. Can you give me some suggestions I really need it
  • Anonymous Mar 24, 2014
    Bobbin rattles when sewing.
  • Anonymous Mar 26, 2014
    I need to assemble again
  • Anonymous Mar 28, 2014
    bobbin directions was followed but the machine only spins some times and other time just humbs.
  • Anonymous Mar 30, 2014
    i have a brother sewing machine model #1520 the tension spring was laying inside the door where the bobbin goes where does the spring go to for me to put it back?
  • Anonymous Mar 31, 2014
    I can't get my tension set right when I use upholstery thread on my Brother CS6000 sewing machine.
  • TJBeckwith Nov 11, 2017
    If what the others suggested didn't work, you can also check to make sure your bobbin is wound and threaded properly. If you don't put it in the slot properly the needle won't pick up the bobbin string when it cycles through.
  • 27 Answers
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Posted on Feb 23, 2008
  • Annie K
    this is not helpfull
    New Friend:
  • 37 Answers
If the upper thread is not in the thread take-up arm, the stitch cannot be pulled tight, this will make the thread gather on the bottom. On the newer machines, it's easy to miss it. Before you thread the needle, rotate the hand wheel and see if the take up arm is threaded, if it is, it will pull the thread against you.
Posted on Jan 27, 2014
  • Brother Master
  • 11,140 Answers
ALWAYS RAISE the presser foot when threading the top thread.
Posted on Nov 11, 2017
    New Friend:
How to thread a brother pacesetter sewing machine super full automatic
Posted on Nov 17, 2013
Can't figure out how to fill the bobbin
hi Beverly.
you have not said what make and model.
but try this.
Always wind the bobbin before threading the machine and needle.
  1. Place spool of thread on spool pin.
  2. Slide spool pin holder/cap firmly over rim of spool to prevent thread from tangling.
  3. Push bobbin winder pin to far left if it is not already there.
More items...
Winding a Bobbin ' Singer Sewing
www.singerco.com/sewing-resources/bobbin-winding-other
or try this.
How to fill bobbin for sewing machine
How do you fill a bobbin on a Brother sewing machine? Use only the included bobbin or bobbins of the same type (part code: SA156, SFB (XA5539-151)).
  1. Turn on the sewing machine, and open the top cover.
  2. Place the bobbin on the bobbin winder shaft so that the spring on the shaft fits into the. ...
  3. Remove the spool cap that is inserted onto the spool pin.
More items...
How do I wind the bobbin? ' Brother
support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=hf_pc420eus... Search for: How do you fill a bobbin on a Brother sewing machine?
or you could go and look at this link to see if it helps you out some more.
igniter button for SUNJOY PH018PSS Google Search
Nov 21, 2017 | Sewing Machines
Bobbin winder shaft wont spin
If you take it apart, you'll void the remaining warranty. The usual cause is not getting the door open completely and/or thread wrapped around the spindle.
You'll also want to take a look at: http://www.brother-usa.com/support/ModelInfo.aspx?R3ModelID=CS8150
Feb 11, 2014 | Brother CS-8150 Computerized Sewing...
Where can I buy a computer board for a Brother CS8150 sewing machine
you'd have to contact brother customer service and ask them
how to buy one or contact a brother dealer and check with them
how to get one.
Mar 06, 2013 | Sewing Machines
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
I need several parts for my brother CS8150
sewingpartsonline.com
a1sewingmachines.com
sew4less.com
sewvacdoctor.com
ebay
Apr 19, 2012 | Brother CS-8150 Computerized Sewing...
I need a manual for my Brother sewing machine CS8150. Is it possible to get one?
check with brother website for a manual
or
sewusa.com
sew4less.com
ebay
Jul 14, 2011 | Brother CS-8150 Computerized Sewing...
Cord got shoved in on a cs8150 brother how do split the case to replace?
If you have to take the body apart on a two piece machine it is a major task if you have to take off any dials, I would advise a shop repair.
Nov 06, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
1,197 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
