Question about Vacuums
How do i set the tension on my white powerlock serger. i lost the manual. should i set everything to zero and then try making small increases to the four tensions?
4 Suggested Answers
  • 223 Answers
SOURCE: Only every 10 or so
A sewing machine should catch and tie the threads at any thread tension. If it's not tying and you're sure it's threaded correctly then it's out of time.
Timing a sewing machine is not difficult, but the point where you adjust the timing is often not obvious. I don't know what kind of machine you have so I can't tell you just where to set the timing, but you'll find the point in the lower section of the machine, there will generally be a screw or two that, being loosened, will allow the lower section of the machine (where the bobbin is) to turn while the upper section stays still.
You want to watch the needle and the tying mechanism: as the needle starts to come up the top thread becomes slack and the hook on the shuttle carrier (the piece that either turns back and forth or goes round and round, down below) catches the slack top thread and pulls it around the shuttle. If the hook is too early in its motion it can't catch the top thread, if it's late then the top thread is gone before the shuttle can catch it.
Timing the machine is simply a matter of determining if the hook is early in trying to catch the top thread or late. Turn the machine by the handwheel, watch the interaction of the needle and hook, adjust the timing if necessary and try it again.
If you don't see where to time the machine the next best thing is to take it to someone who knows, pay them, and watch where they're making the adjustment.
Good luck with it,
lp
Posted on Jan 19, 2011
HansPP
  • 2510 Answers
SOURCE: I have a 3 year
This might sound too basic for you but check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out. This might not be exactly the same as yours but should give you an idea of the position.
images?q=tbn:and9gctyfr7tkfpdipppvqt_-ka70owyny1t5tzdw5qtysow1a3fr_qmpji113vk
Posted on Feb 26, 2011
  • 273 Answers
SOURCE: The last time I sewed
I found this thread (no pun intended):
http://www.fixya.com/support/t2902978-need_replace_upper_tension_dial
If it helped, be sure to acknowledge the thread's author (I just searched for it ;) ).
Posted on Feb 28, 2011
Where do I tighten bobbin thread
on the outside of the bobbin case where you pull the bobbin thread around and down a small; slot to under a small flat spring
that flat spring is the bobbin thread tension and is adjusted by the screw that holds that plate on
a very small amount of turn of that screw make a large difference to the tension
However if your problem is birdnesting under the material ( total mess) then the problem is not bobbin tension but the needle tension is too loose and not pulling up the bobbin thread properly
Jan 26, 2016 | SewShop.com Singer Model 1021 Instruction...
I own a singer 14sh654. Bottom stitch really loose,don't know what to set any of the dials at to make it work right. The top stitch is neat tight bottom all over the place
Hi. Loose stitching underneath means you need to increase the upper tension. Try just a little at a time, using scrap fabric of similar weight to what you want to sew.
Aug 19, 2011 | Singer Vacuums
Sewing basic stitch is good on right side of fabric but looks like a wavy line on reverse
Hi. Chances are your upper thread tension may need to be adjusted, increasing it by very small amounts at a time (say one tenth of one whole number), see if the stitching on the bottom improves. Another possibility is that the bottom fabric is moving around. Try pinning top and bottom together with straight pins set at a right angle to the stitch line. A third possibility could be lower thread tension set to tight. If the lower tension screw is all the way in, this is likely your problem.
Aug 19, 2011 | Vacuums
I need an owners maual for a White serger 1934D electronic downloadable
You may want to check on this site below there are lots of manuals they offer.
Just click HERE so that you will be directed to the site.
Thanks
Aug 06, 2011 | Vacuums
The tension of the thread on top and bottom is not equal. How do you adjust the bottom thread to make it equal to the top?
Hello
First locate the sewing machine tension gauge. Sometimes its called a knob or a button or found on your Touch Screen if you have a computerized machine. Refer to your manual if you can't find it.
Either your needle thread is too tight or your bobbin thread is too loose.
First check that your bobbin thread hasn't slipped out of its tension spring in the bobbin case.
If the bobbin thread is correctly threaded through the tension spring, then decrease your needle tension by 1 number. Test by stitching several inches on your small quilt sandwich. Keep decreasing the tension until no needle thread is visible on the quilt top.
If sewing machine tension problems occur during the middle of a quilting session, again, first refer to the checklist above. Once you're satisfied that your sewing machine is threaded properly and your needle is not the culprit, then adjust the tension as outlined above.
If you have just started testing your quilting thread choices and you are using different threads for the needle and bobbin, you will in all probability make adjustments to your tension.
Make a small quilt sandwich from the materials used in your quilt to make this sandwich. It doesn't have to be pretty or even pin basted. It should be just big enough to test some of the stitching you plan to do on your quilt.
Jul 11, 2011 | Vacuums
I have a white serger 1600 which I do not have the threading instructions. I have tried to thread it but cannot get the machine to work properly. help!
Here is the you tube website which has a 4 part video on using the
White serger 1600 machine: http://www.youtube.com/watch?v=5kF5ilPxR4Q
I also have a website with instructions threading this machine: http://www.ehow.com/info_8107633_instructions-thread-white-speedylock-serger.html
At the ehow site, you can search for all kinds of information in case you need more than learning how to thread and adjust the stitching. Happy sewing!
I hope this helps. If it does, I'd appreciate you vote. Thanks,
Handie Andie
Apr 07, 2011 | Vacuums
My Babylock Serger Eclipse was bought around 1994 and had a looper threading tool wire to thread it when I could not get it to thread manually. I lost the tool and can't get the thread to blow through....
Try one of the Serger looper threading tools listed on this Amazon.com page: http://www.amazon.com/Serger-Looper-and-Needle-Threader/dp/B000Q30C3G/ref=pd_sbs_ac_1 .
These are third party tools. See the main item and the section "Customers who viewed this item also viewed" for other manufacturer's looper threading tools.
I hope this helps.
Mar 21, 2011 | Vacuums
I can't understand how to thread lower looper (red) The instructions on the cover are very unclear
Sounds like you are trying to thread a serger or overlock. I would be helpful if you offered up the model number. However, a few things I've learned.
Sergers MUST be threaded in ORDER. Failure to do so will break your looper (had it happen)
In other words if you break one of the 4 or 5 threads... you have to un-thread all the other points and begin with Thread 1, then do thread 2, etc., etc.,
If you would give me the Make and model number of your serger... I will be happy to see if I can find your manual and threading guide for you.
Mar 11, 2011 | Vacuums
Janome sewing machine Harmony 2139 The bobbin thread is not connecting with the needle to make a stitch. We have put in a new needle. Using needle 4 tension
I think I just answered this question. But if not, try to set the tension adjustment and or the type of stitch. Let me know if this works or not.
Dec 02, 2010 | Vacuums
How do you adjust the tension of the v-belt on the u6630-900
Hi! I'm not so familiar with this model, but I believe the V-belt is only under tension when the brush roll  control is in the "HARD" or "OFF" position. I'm not sure what the exact mechanism is, but I suspect that moving the control to the "ON" position is what places the belt under the correct tension and thus drives the roller.  Please let me know if I'm right! As for your other point, not sure what you mean by the "hood assembly cover" or why you might want to take it off. If you can clarify, I'll help if I can.
Feb 25, 2009 | Hoover U6630-900 WindTunnel Bagless...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
