Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
How to remove ibm thinkcentre p4 3.0 motherboard
  • IBM Master
  • 5,660 Answers
This is the link to the IBM ThinkCentre S50-8183, Hardware and Maintenance Manual,
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51004
On this page scroll down to the heading -
Publication type: Publications,
and left-click on the blue - 74p2660.pdf
This is a PDF file download. May take up to 25 seconds before you see the first page, and additional time to full download it.
Suggest you let it download all the way before looking through it.
Otherwise you may break the download connection.
(The file should also be downloaded all the way, before saving it to your computer.
If you do not know how to save this PDF file to your computer, and would like to know how, please come back and state so in a Comment)
If you cannot download the Hardware and Maintenance Manual, please come back, and state so in a Comment.
(I had to try to download twice, as the connection dropped on me. Second time was a charm)
The following is from me:
1) Computer off, unplug the power to the computer.
2) BEFORE you reach inside the open computer case, TOUCH the metal frame of the computer case, to relieve Static electricity from your body.
Static will fry out (Short Circuit) the delicate hardware components inside your computer.
(Even if this problem should relate to replacing a bad motherboard, you don't want to fry out the other hardware components. Processor, Ram Memory, Harddrive, and so on)
Should you get up, and walk away in the middle of working on your computer, when you come back touch the metal frame again.
Basic tips from me:
A) Opening the computer case.
Facing the front of the computer, there are two Cover Release Buttons. One on each side of the computer case, towards the front.
Press these release buttons in at the same time, rotate the cover up, and back.
The computer case is a 2 part type of case. The top opens like a clamshell, and is hinged on the back.
Should the cover not rotate it may be locked.
See if a lock is present on the back of the cover. If so remove it.
B) Looking at the inside of the Front of your computer, you'll note that the CD Drive, Floppy Drive, and Harddrive, are located inside a rectangular metal framework.
(Floppy Drive on the left, CD Drive on the right, Harddrive under the CD Drive)
This rectangular metal frame is the Drive Bay, and is hinged on the very front side of the computer case.
If you grab the side that is towards the middle, you can lift it up, and tilt it towards the Front.
The cables that you see coming from the motherboard to the CD/DVD Drive, Floppy Drive, and Harddrive, Do Not have to be disconnected from the drives.
THIS is in reference to the flat ribbon IDE cables, or round SATA cables.
These are Interface cables. Also known as a Signal cable.
( NOTE* IDE is also referred to as PATA. The term PATA was implemented to avoid confusion.
PATA is Parallel ATA
SATA is Serial ATA )
You can leave them connected to the drives themselves, just tie them up out of the way with a zip tie, or bread wrappers, and flop them to the outside of the computer case.
You Do have to remove the power cables to these three drives, to remove the motherboard.
They come from the Power Supply, and crossover the motherboard.
(Looking at the Hardware and Maintenance Manual, for the IBM ThinkCentre S50 series of Desktop PC's,
I see there are IDE and SATA connectors on the motherboard.
This means to me that you could have an IDE or a SATA harddrive. You MAY also have either an IDE or SATA optical drive. {CD/DVD Drive)
To avoid possible confusing information, I won't detail out how to remove both an IDE and SATA interface cable.
I'll let the Hardware and Maintenance Manual explain this.
IF, you are unable to download the manual, or if you need more detailed information than the manual provides, I will gladly give it.
We may have to post back, and forth, for the info you need. Just post your additional questions in a Comment)
BEFORE you disconnect any interface cable, that comes from the drives to the motherboard, I suggest you make drawings, and notes.
The Hardware and Maintenance Manual shows, and details information pretty well, but will never be as concise as any notes, or drawings you may additionally make.
Note which direction Each cable connector, plugs into the motherboard's connector, and where they go. Reference this in a drawing, and make a note.
Note where the power cables plug into the motherboard, and which power cables go where.
You'll also have to remove the Power Supply, in order to remove the motherboard.
There are two Fan connectors on the motherboard. It doesn't state if the Processor has a Fan, and doesn't look like it does. One of the Fan connectors, is to the computer case fan in the Front.
Observe, and make a note of which way the Front Panel cable connector plugs into the motherboard.
This may be critical.
The connector, (Header), on the motherboard may not have a locking device on it.
If it does, so does the Front Panel cable connector, and this automatically tells you how the connectors line up with each other.
Or there may be a Locating Lug, and a Notch.
If you take the computer all the way apart, don't worry I can tell you how to put it back together.
You do need to note which way that Front Panel cable plugs into the motherboard, though, before you remove it.
(The Front Panel, is the plastic piece on the front of your computer, where the Power On button, LED lights, and drive openings are)
Don't forget to plug in the 4-pin ATX power cable from the Power Supply to the motherboard. This is power for a Pentium 4 and above processor.
Looks like this,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
(May be Black in color instead of White)
Posted on Feb 08, 2010
Intel pentium 4 3ghz driver download
There are no drivers for CPUs.
The drivers are motherboard and device specific (the motherboard can be regarded as a device).
They will also depend on your operating system (which you should specify)
Your computer is an
IBM ThinkCentre A51 8123 isn't it ?
Go here
http://support.lenovo.com/gb/en/products/desktops-and-all-in-ones/thinkcentre-a-series-desktops/thinkcentre-a51
Enter any chosen parameters in the drop down menus at the head of the table, eg drivers for what component, operating system, to narrow your search, and look for what you need. Good luck. Report bsck if you have problems
10.December.2014
Aug 08, 2014 | IBM Computers & Internet
Driver download
Check the ibm website driver matrix - this is an IBM Thinkcentre so search on thinkcentre and the model number not the motherboard!
Dec 25, 2013 | IBM 89P7935 Motherboard
IBM ThinkCentre 8183 (M51) does not boot
I think it is more than likely your hard drive is the problem, you get the splash screen and everything is working up to that point which tells me the motherboard is fine.
Jul 07, 2012 | IBM ThinkCentre M51 PC Desktop
IBM ThinkCentre M50 8189 power indicator is constantly blinking. There is no picture showing on the monitor.
This shows that the unit is dead right now. Do you hear any fans whirring? Do you hear the whine of the hard disk? If you do not hear any of these, you may not be getting power to your Motherboard. You can remove the cover to see if anything is running inside and then I can help you further
Nov 03, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Hi,guys.Where, I can found an user manual or user guide for IBM .
Hi pnivarna,
That motherboard came with the IBM Thinkcentre system A50, and hopefully that's the machine your referring to! But, IBM no longer supports the Thinkcentre you get support from a new company called Lenovo, HERE is where you find all the necessary information drivers, manuals, and updates for that 19R2560 motherboard of yours.
Good Luck,
Please don't forget to leave a rating based on my Solution
Thanks Mark
Apr 06, 2009 | IBM Computers & Internet
Driver provlem
Is it possible it's a Sound Blaster Audigy?
http://www-307.ibm.com/pc/support/site.wss/MIGR-51794.html
Hope this helps!
Mar 28, 2009 | IBM Computers & Internet
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Computers & Internet Logo
1,411 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
