Question about Microsoft Windows Vista Home Basic for PC
Program on computer
How to format to cpu
  • Sean Steiner May 11, 2010
    Are you asking how to install Windows Vsta on your computer? Please clarify what it is you want to know.
    President:
  • 1,216 Answers
Posted on Feb 08, 2010
What is the video converter
In simple words :
A video converter is a software which converts a form of video to another. For example, an MP4 video can be converted to a 3GP format using a video converter.
Definition from Wiki :
Video converters are computer programs that can change the storage format of digital video. They may recompress the video to another format in a process called transcoding, or may simply change the container format without changing the video format. The disadvantages to transcoding are that there is quality loss when transcoding between lossy compression formats, and that the process is highly CPU intensive.
Total video converter is one of the converters :
May 07, 2014 | iPhone Apps
Tip
Computer CPU/Processor maxed 100%
Is your computer experiencing a CPU that is running at 100% Is your computer experiencing slow performance?
You can view your CPU utilization and other performance stats using Windows Task Manager. Press Ctrl + Alt + Delete and bring up Task Manager. Go to the performance tab.
The top of this screen should show your CPU stats.
In Linux you can use the TOP command,
Type the top command:
$ top
A CPU that is running at 100% utilization is not necessarily a problem. When the computer is booting up, or coming out of sleep mode, it may max out the CPU which is normal. The CPU will be utilized fully in order to bring the computer up as fast as possible. Some computers will even utilize the CPU while it is idle, to complete background task such as disk cleanup and file reallocation.
A problem will occur if the CPU stays maxed out. If it stays at 100% for more than a couple of minutes, you may be experiencing degraded computer performance.
Steps to reduce performance degradation.
-In a limited number of cases, software bugs can cause CPU utilization to spike. You will know this is the case if you are using a computer program(that is not hardware intensive like photo/video editors) and notice degraded computer performance. Check your CPU stats while running the program. If this is the case, check online for solutions and possible upgrades which resolve bugs in the software.
-You can reduce Windows start up programs, which will speed up the boot/wakeup process. You can do this from the MSCONFIG window. Go to Start > and in the run box type "msconfig". Go to the "startup" tab and you can uncheck which programs you do not want to start with Windows.
-A majority of the time a computer will get to a point were the hardware will need to be upgraded in order to handle the work you are doing. Common computer upgrades are memory, cpu, motherboard and hard drive.
-G33k
on May 15, 2011 | Computers & Internet
Asus p5vd2-vm se Unknown CPU detected, BIOS update required to unleash its full power after update the bios
http://download.cnet.com/biosagentplus/3000-2098_4-10175528.html
This is an efficient, easy-to-use tool to help you figure out the details that make your computer tick. BIOS Agent is a lightweight freeware application with a clean and well-designed interface that lets you get the information you need with only a few button clicks. The program can retrieve information on the type of BIOS your computer runs and chipset type, as well as information on CPU, ROM, and RAM. Once you've gathered the details you need, you can save the report in TXT format or print it. There's no installation required for BIOS Agent. This program will be useful for administrators or power users looking to keep their systems up to date. hope this helps
Mar 22, 2011 | Computers & Internet
I get a norton warning that I have high cpu usage yet Im not running any programs.My computer is running slow and doing alot of clicking noises.I have 98% available free space on my hard drive and i...
1. Try disabling some of the Startup Programs.Press the "Windows" key on your keyboard and the "R" key at the same time. When the run dialog box comes up, type "msconfig" then press OK. The System Configuration Utility will open. Go to "Startup" tab, disable all startup programs, hit OK then restart computer.
2. Test if the computer still runs slow, if it doesn't try repeating the step 1, and re-enable the startup programs one by one or you can just check on the programs that you want to automatically start whenever you start Windows. These startup programs eats your computer resources which should have been used by the computer for processing instead.
3. If you hear clicking noises from the computer it might be the computer's Hard Drive. Download and run a Hard Disk test. You can download Hard Drive Utilities from here - click this link
4. If the Hard Drive test fails then we will need to replace the Hard drive. If it passes run a full system scan using your Security software. The computer might be infected by a virus/malware which causes slow performance.
Hope this helps.
Mar 21, 2011 | Computers & Internet
So I bought a new power supply and a case, put everything in the case and everything seemed to work fine, but the computer kept turning off every 5 mins. After checking for a while I noticed I hadn't...
Hi,I'd say if your up and running and the system keeps running for more then 10 min's.No the cpu is most likely still good.The problem is that when the system was crashing it lost some files,getting all the file links back can be very tedious,I'd recommend formatting the hard drive and reinstalling all your app's.Save all you can before the format as you will lose everything thats on the hard drive.Hope this has been helpfull plesae rate!!
Nov 25, 2010 | AMD Phenom X4 9750 Quad Core Processor...
What the long beep means? while i am printing my computer beeps very long.
When your computer is "printing", it is working hard to format the text/pictures for printing. As it works hard, the CPU heats-up. When the temperature of the CPU exceeds a programmed value, e.g., 55 to 60 degrees Celsius, your motherboard will start "beeping" to indicate that the CPU is "too hot".
Turn the computer off, and open it up.
Check that the fans are working.
Take a can of compressed-air, and give your computer a "blow-job" to remove all the dust, because dust acts as unwanted "insulation".
Jun 15, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Licensed programs in my CPU
Hopefully you have registered your programs. You need to contact the manufacturers of your programs. In future always make a copy of the registration codes or serial numbers. You may have to have some proof of validity. If you have the original packaging they should still contain the serial numbers. Some programs will actually give you the registration code by opening the program and going to the help menu and then 'about'.
Jan 30, 2010 | NRS BitDefender Antivirus 2009 Full...
My computer is slow.
first sec your operating system drive and sec drive properties if your drive is full then you remove unnesasery program and free your oprating system drive in 50% or you can clean your windows temt folder or you can formate youe oprating drive and instoll again or you can add additional ram in your pc.
Jul 16, 2008 | HP Desktop Computers - Hewlett-Packard...
Microsoft Windows Vista Home Basic for PC Logo
23 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
