Question about Kenmore Elite 45986 Front Load Washer
HE3 front load washer
Washer will not start. Appears to be no power, however checked oultlet and there is power available. Moved washer out to vaccuum behind with no great effort and then replaced only to have this problem occur. Anyhelp is greatly appreciated. CCKnight
  • 1 more comment
  • kbells Feb 22, 2008
    Hi There:
    We have the EXACT same problem. Our front load washer was working great yesterday, this morning I put in a new load of laudry and it won't even turn on. I tried to unlock it, unplugged it, checked outlet. I can't figure it out. There doesn't seem to be any life to the machine. HELP!
  • CCKnight Feb 25, 2008
    I love the thorough treatment plan and will wait for my husband to get home before I attempt :)
    However, here's and interesting fact: when I reposition my cord the washer will show power to the panel again. If I move the cord, again the power goes out....can this be a more specific problem, such as a short??
    Thanks,CCKnight
  • Jeff Rockwell
    Jeff Rockwell May 11, 2010
    Are there ANY indicators at all on the front panel? You may have inadvertently locked the control panel when you moved it. Try holding the DRAIN/SPIN button down for 3 seconds.
I just tried the solution to place washer in diagnostics mode. Still-nothing, not a light in sight. Thanks though.
Posted on Feb 23, 2008
  • 5,911 Answers
PS you can also place the washer in diagnostics mode to see if the same "F05" error is displayed. To do so, select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, though). "C:00" will be displayed as the washer runs through a series of tests that check the door latch, flow meter, hot and cold water inlets, dispenser, motor actions, drain pump, AND the heater & NTC. The heater and NTC are checked at segment C:05. The washer should advance through all segments and end after C:08. There is a tech sheet inside your washer along one of the side panels that has all this information available to you.
  • Jeff Rockwell
    Jeff Rockwell Feb 23, 2008
    Please disregard my Solution #1. I posted it to the wrong problem and it doesn't address this problem correctly.
    The following is a list of the recommended procedures from Kenmore to try for diagnosing this particular problem:
    1. Check the line voltage and for blown fuses (I know you've already tried this, just following Kenmore's check list sequence).
    2. Check for voltage going to Central Control Unit (CCU) by listen
    ing for a click in the CCU when unit is plugged in. You will need to unplug the washer and plug back in. Listen for a "clicking" sound. If no click is heard, Kenmore recommends replacing the CCU. This is the main control board inside the washer. You can access it by removing the top panel. The CCU is located at the back of the washer in the center just above the wash tub.
    3. Unplug the washer before continuing.
    4. Check continuity of line cord and line filter. The line filter is located to the immediate RIGHT of the CCU. There are two pink wires, a black wire and white (or yellow) wire. Readings across the filter should read 0 ohms.
    5. Check harness connections to CCU. Remove all connectors on the CCU ONE AT A TIME and reseat them. Sometimes the connections oxidize and reseating them corrects problems.
    6. Check touch-pad/LED assembly. Make sure the ribbon cable is connected to the touch pad board and at the CCU.
    If you identify the culprit, any parts you may need can be found at searspartsdirect.com or repairclinic.com. Just type in your COMPLETE model number (located around the door opening) in the search menu. There is a detailed part index available. I hope this helps. If you have any further questions/concerns, please post back with your comments.
  • Jeff Rockwell
    Jeff Rockwell Feb 25, 2008
    If you are talking about the A/C power cord, you may have a bad outlet, a loose connection at the terminal inside the washer where the cord plugs into the line filter, or the cord itself could have a loose or broken wire. Intermittent connectivity issues like this can be dangerous as they often arc, causing hot spots. It's better to find it now, before you notice some burned wiring somewhere. I would suggest securing the power to the washer and ensure all the terminal connections are tight. You may have to hire an electrician to check the outlet if that proves to be the problem. Use extreme caution working around any of the terminal connections with the washer plugged in. There's still 120 VAC present at the line filter with the washer turned off.
Drum knock when spin cycle
Hello.
Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator.
1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded.
2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle.
3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes.
4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle.
Thanks.
Nov 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The display has an F code...dl or dh. Clothes are stuck inside.
This could be the MCU which on an HE3 2009 3.8 cu ft washer front load appears to be the most common problem. This leads to the F71 because the MCU and the CCU are not able to communicate. Can be accompanied by no lights.
Jan 12, 2011 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 washer and dryer will not lite (begin cycle)
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Neptune front load washer
if i remember correctly usa is 60 cycles and european is 50 ..might be wrong but don't think it's possible without a lot of changes ..best get an adaptor if available..this should plug into foreign outlet and then plug washer into it
Jun 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore HE3 WasherManual?
Click on your model number (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is..
Apr 13, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
HE3 washer wont power up
WON'T POWER UP. (Touch-pads do not respond when pressed)
Check the line voltage and for blown fuses.
Check for voltage going to Central Control Unit ( CCU) by listening for a click in the CCU when unit is plugged in
lf no click
replaceCCU.
Unplug the unitb eforec ontinuing.
Checkc ontinuitoy f linec orda ndl inef ilter.
Checkh arnessc onnectiontso CCU.
Checkt ouch-pad/LEaDs semb
Feb 23, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3
I don't know if this will help or not, but my machine has gone through (2) fill valve assemblies so far. In one case, it wouldn't fully shut-off and was also erratic. I replaced it (very easy to do) and that fixed the problem. I think my machine is an HE2, but I'd guess it's probably the same parts... (Parts available through the Sears web site. The last one I bought was around $55 for the assembly.)
Jan 02, 2008 | Kenmore 42822 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
169 people viewed this question
Sal De
fordexpert
Robert Rankin
