Question about Xerox Phaser 7300DN Laser Printer
Printing on CD labels seem to ruin fuser in Phaser 7300
We use our Phaser 7300 in an education setting in a student graphics lab, so it sees lots of use. A few days ago, we printed a few CD labels, first changing the paper set-up to recognize the new media type. It printed great on the labels. The next day, with the media type set back to plain paper, the fuser was not only failing to fuse toner on heavy-coverage prints, but the paper was getting jammed in the fuser and, in one case, catching on fire.
This happened the last time we printed a CD label and then tried to go back to regular media (and acknowledging that in the printer set-up). We replaced the fuser, and everything was fine. But obviously, we don't want to replace the fuser each time we want to print a label!
What are we doing wrong?
  • designteach Feb 22, 2008
    Makes total sense. Thanks for the direction. Is there a cure for the current fuser if it has the coating, or do I just need to replace it one more time?
  • 3 Answers
It may be some type of incompatibility with your printer and the Xerox brand labels.
We have had success with our gloss laser printable cd labels in Xerox Phasers. I am happy to send you samples for testing if you would like to try out our product.
You can check out our cd rom labels at the link below:
http://www.onlinelabels.com/labeltypecdrom.htm
You can fill out our sample request form at the link below:
http://www.onlinelabels.com/sampreq.asp
Posted on Feb 22, 2008
    President:
  • 2,072 Answers
Probably the labels have a slight plastic fiber or coating in them and is getting a coating on the heat roller.
Here are part numbers of the correct CD labels you can run without a problem.
Xerox Matte Coated CD Labels, 6-Up, 11x17
Reorder 3R12373
75 sheets per box
White 1+ Box $65.21Printing on CD labels seem to ruin fuser in Phaser - spacer.gif spacer.gif
spacer.gif Other items to consider: Return to Top spacer.gif Item Color Price/Unit Quantity Xerox Gloss Coated CD Labels, 6-Up, 11x17
Reorder 3R12372
75 sheets per box
Item Color Price/Unit Quantity Xerox CD-ROM Glossy Coated Labels, 4 x 7
Reorder 3R6322
50 CD-ROM Labels, 25 Sheets per carton
White - Glossy Coated 1-9 Box $17.4Printing on CD labels seem to ruin fuser in Phaser - spacer.gif 10-49 Box $16.90 50-99 Box $15.65 100+ Box $14.89spacer.gif
  • Rick Kasper Feb 22, 2008
    Although not intentional you just can't go by faith that anything will run through a fuser. Sometimes they are product specific.
    Seems that just so happens the ones you are running are problematic for that fuser.
    That fuser in particular does not use a conventional Pressure roller, it used a pressure belt, which does make a difference in fusing thicker stocks.
    No need to replace a fuser every time, just be sure the media is correct.
    You may be able to take, WHEN cold, take a cloth coated with alcohol and clean the fuser roller.
    YOu can open the slot and take a cloth on the end of a popsicle stick and dampen the cloth then.
    Rotate the roller to remove the contamination, then once you install the fuser, probably just go into word and typy a period on a document and run about 100 clean pieces of paper through allowing the fuser to more self clean then anyting, I doubt you really ruined it unless you can see some large flakes melted to the rollers.
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
How to set printer HP 4200 for printing lables
You shouldn't really have to do much. Just change the paper tray setting to labels of the appropriate size. It should prompt you to be sure it's right when you put the paper tray back in. Just make sure the labels you use are rated for use in a laser printer. Ink jet labels will come off and wrap around the fuser and ruin it. about a $300 repair.
Oct 29, 2010 | HP LaserJet 4200 Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox 6280 - need to print labels on a sheet of 30 labels
Shouldn't be a problem, provided you use labels that are intended for a laser printer. Inkjet labels can wreck your laser printer (inkjet labels can't cope with the heat of the fuser in a laser printer).
Use the right template in your Wordprocessor package for the labels you are using (or create a custom label layout in your Word processor).
Use the Multi Purpose Feeder input tray (fold down from the front door), put the labesl face down, print (making sure that you tell the printer to use Labels and the MPF. It's important to tell the printer that you are using labels, as these are thicker, and need more heat from the fuser (especially if you are printing several sheets of labels, as this cools the fuser a little)
Jun 14, 2009 | Laser Phaser 6280v_n 25ppm 256mb - XEROX &...
Phaser 7300dn Fuser problem
I don't think so. I have had this problem when I'm using a thicker paper and the paper type is set wrong in the printer.
The printer seems to adjust something based on what paper you say is printing. Try pulling the paper out of the printer, then re-inserting it and then choosing a different paper type - one closer to what you are using - or choose the "special" paper type.
This should solve your problem.
Jun 04, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300 Error Code/Message
Seems to be something to do with the Ram.
More help HERE
Jun 01, 2008 | Xerox Phaser 7300DN Laser Printer
Phaser 7300N paper jam
What code is comming up with the jam? That would help me narrow it down for you.
Apr 05, 2008 | Xerox Phaser 7300DN Laser Printer
Fan Failure Error 54
1 of 2 things.
You need to clean or replace the fan.
You have to remove the back, right side and top cover to access that fan.It is near the back just behind the fuser module.
It could also be the low voltage power supply fan. Most likely the fuser fan.
Once you remove the fan, there is a label on it, remove the label, There is a rubber plug behind the label, remove the plug and drip some lubricant into the fan. Reassembly and it should be ok.
I would recommend replacing the defective fan though.
Here is a very reliable part source.
https://www.partsdrop.com/store/
If you call ask for Britt and specify the model number and that you need a fuser fan and probably order a Power supply fan, Neither are very expensive.
Have both on hand to be 100 percent sure the problem is resolved, But its a 90 percent fuser fan failure code. It operated in a heated area and can dry out faster.
Mar 27, 2008 | Xerox Phaser 7700 Laser Printer
XEROX 7300
Sounds like you have had a fuser roll failure.
Could be either the heat or pressure roll failure from your description.
That is an easy replacement. You can call 1-800-835-6100 and order one. It is on the left side of the machine, The area that is very hot. It has 2 thumb screws to remove and replace it. Only issue would be, the fuser has a replacement count on it that needs the proper laptop hooked up to it to reset the count. Although it will not fail to run without the count reset, once the fuser count reaches 100,000 images in the counter, it will shut the machine down until it is reset.
Mar 18, 2008 | Xerox Phaser 7300DN Laser Printer
Specific PDF Document/Specific Print Area Black Toner Not Fusing And Flakes Off
Without a doubt you have a problem with the fuser.
What that is caused from is buildup over time of ink on the heat roller. The teflon coating wears some and the ink sticks to the aluminum instead of pealing off onto the paper.
You then do not get enough heat or perssure to "fuse" the image into the paper.
Replacine the fuser will correct the problem.
Feb 03, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser 7300DN Laser Printer Logo
510 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
