Question about Kenmore Oasis HE 27082 Top Load Washer
F1 & F51 error on my Kenmore Elite Oasis HE washer
I have been having the F1 & F51 error on my Kenmore Elite Oasis HE washer since for the past 6 months. I have to repeatedly press stop and start for the machine to work. Then go back just before the rinse and press stop and start until it works again. I see that many others have the same issue.
    President:
  • Kenmore Master
  • 662 Answers
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Good news for Oasis F-51 sufferers! Sears will replace the electronic control board (the F51 prob) for free, in warranty or not. Serial #s for the bad board are: CS48 - CS52 or CT01-CT49. Call Sears at 800-847-9083.
You hv to rate me ‘very helpful’, or the call won’t get thru!!
Posted on Jun 14, 2010
  • prem mathew Jun 14, 2010
    Normal
    0
    false
    false
    false
    font-size:10.0pt;
    You hav to first check whether something is stuck in-between
    your outer and inner drum. Un-plug
    first. Is the basket moving smoothly, as
    in previous washes? If not, there could
    be something stuck, and the F51 reading could be correct - strain on motor.
    You have to get in to the top of the washer. There are two
    clips that hold the front of the top in place - wedge a putty knife against
    these (hard) while pulling up to release the top. The top will then swing up as
    a piece. It is easier to undo the clips in the back allowing the whole top to
    swing completely back and away (having an extra person helps, you don't want to
    put pressure on the wiring harness between the base and the top). Next you have
    to unclip the cover all around the edges (lifting the tabs) and swing it back.
    Take a flashlight and inspect carefully the gap between and under the drum for
    any stray items, and remove them. Reverse the process to re-assemble.
    Habit-Forming:
    New Friend:
  • 76 Answers
That Oasis Error can be quite a few different problems, below is link that will show you step by step how to figure out what the problem is and repair it.
Kenmore Elite Oasis Washer F51 Error Code Explained
Posted on May 02, 2017
Kenmore elite f 51 code
Error Code
  • Clear the error code and stop the beeping by pressing the "Stop" and "Start" buttons at the same time. Unplug your washer so you can examine the problem.
Function
  • The error code displays because something is wrong with the motor sensor. This can be for a number of reasons. After you clear the code, try washing clothes again and seeing if the error appears. If it does, then you need to take further steps.
  • Sponsored Links
Prevention/Solution
  • Check around the inner washer and underneath for any lost clothes or jammed objects. This can be anything from toys to shoes.
Considerations
  • If there are no objects, your washer parts may need to be cleaned or replaced. Call Kenmore at 800-4-MY-Home to talk to a service representative and find out about replacement parts.
Types
  • Along with "F51", error codes "F1" and "F50" could mean the same thing. Check for these error codes and follow the same procedure with your washer.
Read more: http://www.ehow.com/facts_7565280_kenmore-elite-error-code-f51.html#ixzz346p9Y6ro
Jun 07, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Leaking and F51 error code on my Kemore Elite Oasis Washer
The F51 error code indicates that the control is not sensing proper motor movement through the signals from the RPS (rotor position sensor) circuit.
This can be caused by several different problems.
Make sure that you are not overloading the washer.
Overloading can cause this problem. A toy or foreign object could be under the washer that is interfering with motor rotation. With the washer empty, spin the basket inside the washer tub to see if it spins relatively easily.
If not, you could an item caught between the spin basket and the tub. You could have a wire harness problem causing signals to not be transmitted properly between the RPS and the machine control board.
A failed RPS sensor or a failed control board could also cause this problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 05, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F51 error
Hello, the F51 code is a motor rotor position sensor failure. It's best to call in the warranty service as there is a bunch of tests that need to be run to determine if it's the sensor or control board. If the tech wasn't any help, contact the store for a replacement.
Thanks
May 20, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
F1 error
yep electronis control board in the console is bad.
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
In mid wash the Kenmore Elite Oasis HE flashes F51 and
check if basket turns freely. if it does replace the main board
Jan 28, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Error F51 for Kenmore Elite Oasis Toploading washer??
bad main board or motor possitioner sensor.. most likely motor sensor.
China made junk parts with a million problems
Nov 21, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Elite Oasis HE F1 Error
Im sorry to tell you but you have a bad control board. This was a faulty board from the factory. There is a class action lawsuit agianst whirlpool (whirlpool made the oasis). Try calling to get whirlpool to fix it. Maybe try joining the lawsuit. They have remanufactured the part so the new one wont do that again. Its a great machine when it works right.
Nov 18, 2008 | Kenmore Oasis HE 27087
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
Ok these are not the series 70, getting a model number off the door will reallllllly help. Some of these sound like the oasis. F1 is motor control or primary control failure and F 41 is a rps thermistor failure.
For the guest with the 11027086601 kenmore elite oasis here is a link for supplying me with a partial model number, much thank yous!! paste in a browser:)
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?modelNumber=11027086601&productCategoryId=0153200&brandId=0583&modelName=RESIDENTIAL WASHER&diagramPageId=00002&componentDescription=CONTROL PANEL PARTS&documentId=K0601003&backToLink=Return to Sub Components list
Aug 02, 2008 | Kenmore 22422 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,583 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
