Question about Minolta Di550 B&W Laser Printer
HOW TO PUT IP ADDRESS ON MINOLTA DI550 - Minolta Di550 B&W Laser Printer
  • Minolta Master
  • 6,161 Answers
  • 8 Answers
SOURCE: Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Posted on Feb 02, 2008
SOURCE: getting the ip address
To print out machine current ip address, go to utilities, user setting, printer setting, print reports, configuration.
Posted on Mar 23, 2008
  • 990 Answers
SOURCE: i have a Minolta Di550
already solved
Posted on Dec 17, 2008
  • 990 Answers
SOURCE: Minolta Di550 Copier with a malfunction code of C-OF24
Hello sir; here have few steps need to follow;
1, press "function", press "printer", "F8" press "start" machine will run about 4 minutes the start key will turn from orange to green.
2, same procedure go to F5 will run about 30 seconds.
Posted on Jan 09, 2009
firecontrol7
  • 6161 Answers
SOURCE: Minolta Di550 gets spots on print
Your drum cleaing blade or anti spill mylar may need replacement.
Posted on Apr 15, 2010
How to change ip address to konica minolta dialta 470 or connect to printer from computer
work out ip address of computer like for example usually 10.0.0.2 or 198.168.0.2 submask 255.255.255.0 then go to printer and select settings - network settings - ip address and put in xx.xx.xx.253
xx.xx.xx is the network address like 10.0.0 or 198.168.0 and the same subnet mask as computer is using. .
computer run
dos prompt
type in
ipconfig
press enter key
Jan 23, 2017 | Konica Minolta Office Equipment & Supplies
Ho doI network a Minolta Di550?
Best Operating system would be Windows 95 maybe XP at best.. NOT good for Windows. Go to Konica Minolta web site see if you can get the drivers for that machine all call KMBS to see if they can help you
Go thG
May 05, 2014 | Minolta Di550 B&W Laser Printer
Can Minolta Di550 be networked to a computer?
If it has a print controller it will be on the left side rear. only windows 95 XP at best
Apr 25, 2014 | Minolta Di550 B&W Laser Printer
Konica minolta di470 connect to pc
In Utility Key Network Section not Show in the Machine then How can put the IP address in Network Section.
I had been printing using IP address 192.168.1.25.
Nov 30, 2013 | Konica Minolta Office Equipment & Supplies
Minolta di550 error code c-13fc
Image processing board or the Print head ( What houses the LASER inside the machine they are not talking to each other so that code is displayed. Check the connections , I would go with print head 1st. Di550 is a legacy Minolta machine, might be tuff finding a print head as for Image control board WOW! Home and close front door resets if it comes back need above
Nov 19, 2013 | Minolta Office Equipment & Supplies
I need the Konica Minolta Di470 ip address to connect the pc to print documents etc.
The ip address is provided by your it department if you do not have an it department then you can select an ip address that is not being uesd example 192.168.1.200 this lus the sub net mask standard sub net mask 255.255.255.0 needs to be put in the network section of the machine then you can go to the c: prompt on your computer type in ping then the ip address you put into the machine you should get 4 replys and no drops then you will also need to load the print driver for the machine onto your computer
Jan 11, 2011 | Konica Minolta Di1610 Copier
How do I input ip address in Minolta DI1610
press the Utility/Counter -> Network Settings -> IP address
Feb 09, 2009 | Konica Minolta Di1610 Copier
Jan 08, 2009 | Minolta EP1030/1030F CS/PRO Copier
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Master Reset?
Page 147 will show you reseting procedures
http://www.copierprofessionals.com/protectedmembers/130914/DI_450_550/DI_450_550/FIELD.pdf
Let me know if this helps. If not I will keep looking.
Nov 21, 2007 | Minolta Di550 B&W Laser Printer
149 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
