The problem that I have with my washer is that water system fails, nowadays already it does not close the water automatic, and previously the flow of cold water was poor for what always was using cold water and warm at the same time
  • 3,740 Answers
Hi and welcome to Fixya. It sounds like you have debris in the water valve inlet screens. Possibly inside the water valve itself. Here is a procedure you can do to try and reverse flow / clean the water valve.
Get a 3 gallon bucket...Turn off both wall connected hoses.
Remove ONE hose from the wall shut off valve and place it in the 3 gallon bucket.
Turn on the hose that is still connected to the wall shut off valve.
Select WARM on the temp selector.
Let the water back flow until the bucket is about 1/3 full. While the water is flowing use the handle of a screwdriver the GENTLY tap in the hose connection at the washer water valve several times to free or loosen debris.
Reverse the hose positions on the wall shut off valve and repeat above until the bucket is 2/3 rds full.
Then turn off the water at the wall and disconnect the hoses from the water valve ONE at a time. One the hose is removed take out (remove) the metal inlet screen from the water valve. You have to use a blade or a scribe on the very outside of the screen to remove it. Take the screen to a sink and using a slow flow of water clean the screen with your fingers / fingernails until you can see through it when you hold it up to a light. Once clean press the screen back into the water valve and then repeat the remove and clean procedure for the other screen.
Reconnect all hoses
Turn on the water and test for leaks.
Check water flow during the fill. You see a remarkable difference.
If there is no change then there is still debris in the diaphram of the water valve. Most often you can not open the water valve and it must be replaced.
Thanks for using Fixya! Kelly
Posted on Feb 08, 2010
Testimonial: "Thank you for your help!"
What does Code nf on washer machine Samsung vrt model mean
NF indicates no water flow. This could mean that the incoming water valves were shut-off, the incoming water flow is low, or that the washer didn't detect the water flow into the washer correctly. If the drain hose is too low, the washer could fill and drain simultaneously. This can also cause the problem.
First if the washer is not getting any water, then check your shut-off valves and the hoses. Disconnect the hoses from the washer and place a bucket under them. Check the flow by turning on each valve for a bit. Clean or replace the filters at the shut-off valves and in the washer. Consider replacing the hoses. Some anti-flood hoses will reduce the water flow if they detect leaks. Make sure that the hoses are not kinked. If the water flow is good at the shut-off valves, then the inlet valve may have failed in the closed position.
If water is filling the washer, then the problem is in the water flow detection system. This could indicate the small reed switch is damaged, the air tube to the reed switch is clogged or that tube has a hole in it. Some washers check for fill by the change in the drum weight. This signal may not be reaching the control unit due to a problem with the sensor or the wiring.
If the washer is filling and draining, pull your drain hose up. It is below the washer fill level. This creates a vacuum that will drain the washer.
I hope this helps.
Aug 25, 2017 | Samsung Washing Machines
Kenmore washer frontloader model 417.41122410 code E11
An E11 error indicates a problem with the incoming water. The error will occur if the tub doesn't fill normally in about 8 minutes. This could be related to closed shut-off valves, failing anti-flood hoses, or debris in filters in the hoses or at the inlet valve on the washer. It could also come from a fault with the sensor that detects the weight of the washer tub, a problem with the reed switch that tracks water flow into the washer, the air tube that goes to the reed switch or a failure of the inlet valve. It can even indicate that the end of the drain hose is below the water level in the washer and is siphoning water out as the tub fills.
If no water or a trickle of water is reaching the tub, first make sure that the shut-off valves are open. Next close the valves and disconnect the hoses. Place the hoses into a bucket and check the water flow by opening the shut-off valves. Shut off the valves. Clean the filters, including those in the inlet of the washer. Reconnect the hoses or replace them with new ones if there was low flow. (Check the flow at the shut-off valves themselves with a similar bucket under the valve opening, if you can.) If these steps don't work, you need to replace the inlet valve assembly. It failed in the closed position.
If water is filling the tub normally and flowing out the drain, check the drain hose position. If the tub is filling and is held in the tub, then the washer isn't correctly measuring the water flow. Check the reed switch and that tubing by blowing into the tube. Replace a faulty switch and remove any blockages from the tubing. Check the wiring harness to ensure that the message got to the control board.
See http://www.searspartsdirect.com/model-number/41741122310/0582/0153200.html for parts diagrams and price lists. You need the control panel diagram.
I hope this helps.
Aug 15, 2017 | Kenmore Washing Machines
How do I reset GTWN7450DWWwasher after code H2O supply comes on?
If the water supply valves are open, turn off the valves and disconnect the hoses. Replace the hoses. (You may have flood-prevention hoses. When these fail, the hose actually restricts water flow to avoid flooding.) If you want to test this, try placing a bucket under the inlet hoses and opening each valve in turn. Check how fast the water fills your bucket. Make sure that you cleaned the filters at the washer inlets and at the supply valves.
If the valves were closed, try running the washer with the valves open.
If that doesn't help, the flow meter valve has possibly failed or another part in that system has failed. This is part 805 on the tub and lid diagram here: https://www.geapplianceparts.com/store/parts/assembly/GTWN7450D0WW .
To purchase the part from GE, go to https://www.geapplianceparts.com/store/parts/spec/WH13X10057 . It is available at other appliance parts suppliers. The price is similar at the vendors that I consider using.
I hope this helps.
Nov 29, 2014 | GE GTWN7450DWW 28" 4.6 cu. ft. Capacity...
What is a Venturi co-current flow system?
A venturi co-current flow system can be used to introduce the bubbles into the water stream. The tank water is pumped through the venturi then enters the skimmer body. This method of skimming is much more popular nowadays.
Aug 30, 2012 | A H Fabrications Fish
Whirlpool HFW95HEXW. During the Clean Washer cycle, water trickles down the front of the washer and pools in the pedestal drawer. The amount of water is small, but this happens during every Clean Washer...
YOUR WATER MAY BE OVERFLOWING A BIT AT THE TOP, JUST UNDER THE MACHINE'S COVER.
A SENIOR LADY FRIEND HAD SIMILAR SITUATION
WE TILTED UP THE TOP ON HER AUTOMATIC WASHER AND DISCOVERED THERE WAS A LARGE BUILD UP OF LIME, LINT , OLDE SOAP AND SOFTENER .
WATER GOING INTO THESE AUTOMATIC WASHING MACHINE IS OPEN TO THE AIR AND NOT CLOSED IN.
THIS HARDENED MESS WAS INTERFERING THE WATER FLOW, CAUSING SOME WATER TO RUN DOWN ONTO THE FLOOR.
Feb 09, 2018 | Whirlpool WFW95HEX Washer
I have a single handle belanger shower faucet- replaced cartridge and no hot water , Need help
Check the hot water shut off valve, when the washer fails sometimes the valve itself sticks closed, and sometimes the washer breaks up and clogs water passageways down stream...
To test, pull the hose off of the hot water shut off valve, open the valve and see if you have water flow. (route hose into a bucket, you need more that a small amount of water.....
If you have good water flow from the shut off valve, then you likely have a particle that has lodged in the passageways of the faucet. Reverse flow with air pressure and see what you get out....
Jul 17, 2011 | Plumbing
My washer is starting normally and agitate for the first cycle but does not refill water to rinse the clothes. the cold water faucet can't supply the washer.I checked it if there is something clogging...
you probably have low flow hoses I don't like them they are guaranteed not to over flow but they fail so often, or maybe the water inlet is faulty ( cold side) if water comes out the faucet at the wall, then the issue is at hose or valve, close your water faucet then get a bucket and take loose the hose from the rear of washer ( unplug washer please) place hose in bucket and with one hand hold it in then open the water faucet at wall if water comes out then the water inlet at machine is faulty, if no water comes out then you have a low flow hose replace them with the stainless but not low flow.
Mar 10, 2011 | Speed Queen Washing Machines
Saltwater pump keeps reading low flow...but water is flowing throught it...have already ckd the flow sensor..the filter pump seems to not sound the same as it did before the new filter went in...pool only...
sounds like air lock
Start by closing your plungers
now get the cartridge out and drain the lower bleeder screw
put filter back in and the cover ring
now open the top bleeder screw on top of the cartridge cover
open the other bleeder screw on the pump itself if there is one if not go right to opening the plunger that discharges the water
When water start coming out of the bleeder on the cap open the intake plunger
wait 5 seconds then turn your filter on
wait 1 minute then close all bleeders
This should do it
Jul 06, 2010 | Intex Automatic Salt Water System for ...
Pressure washer does not spray consistent flow of pressure
Pressure washers have a pressure regulator/unloader that bypasses the water back into the intake when you let go of the trigger with motor running. If you let the machine run for long preiods in bypass the system could be damaged due to heating of the water being bypassed. The water is in a closed loop. The as the unloader wears it will tend to want to bypass which is what is happening in your case. Dirt trapped at the tip will cause this also. Install clean tip to solve problem. If clean tip did not help then try lowering the pressure by turning pressure regulator counterclock wise. If problem is gone then parts are failing but keep using pump. Good luck.
Jul 09, 2010 | Karcher G3025OH Pressure Washer
Automatic washing machine plumbing requirement
The automatic clothes washing machine counts on a pressured water system - like what is provided in a town / city or from a well that has a pressure system to deliver water at pressure like when you open a valve for a bath tub, sink or shower.
You need to have a plumber provide valve/faucets for both hot and cold water. The valves are sometimes called a "hose bibb" with a threaded end that the hoses connect to and then are connected to the back of the washer. When the hoses are connected and the valves are open, the automatic washer will open a solenoid valve when the time is right to allow water to flow in, then closees. Some owners keep the hose bibb valves open forever after they connect the washer, others close the valves after they are done washing all loads for the day/week.
You will also need a drain provided that connects into the house plumbing. The Whirlpool Duet provides the drain hose from the washer which drops into the pipe the plumber provides. It is important that the drain pipe allow air to move past the washers drain hose, to allow proper draining.
Hope that helps. Please post back how things come out, OK?
May 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
