Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
I don't know what is the best for freezer setting tepm I have it on zero right now but it is frosting too much
  • 4,793 Answers
Simle answer is to buy freezer thermostat...keep freezer at-20, meat will last 12 months...-22 meat WILL LAST INDEFINATELY cost a fortune to run though.
Posted on Feb 08, 2010
My GE profile side by side defroster stopped working. I have a ice build up at the bottom. defrosting it by shutting off and restarting after it all melted did not work. Any suggestions? Thanks, Don
Hello Don,
Here is what to check on the defrost system ;
DEFROST HEATER ...remove back wall of freezer and you will see a black heater at the bottom of the coil thats frosted up,it looks similar to the bake element in your oven,or in some cases it is going to be a spiraled wires inside of a glass tube. To check it,use a multimeter set to the lowest ohms of resistiance setting and follow and find the wires at the top of that frosted coil,unplug/disconnect those wires and check for continuty with around 5-20 ohms of resistiance. If it has that amount of ohms the heater is good. If your meter display does not change or displays OL the defrost heater is broke and needs to be replaced
DEFROST TERMINATION THERMOSTAT... it's round and has 2 wires and clips to the top of that frosted up coil. IT MUST BE CHECKED WHEN COLD SO BEST TO DO WHEN FROST IS STILL BUILT UP. To check it disconnect the wires on it and check for ZERO ohms of resistiance. As with the heater if the meter display OL or doesnt change,it is the problem
DEFROST CONTROL...it is hard to check for a semi unskilled person and if the heater or defrost t-stat check good its going to be the problem. It will NOT be in the freezer it could be on back wall or inside the control panel in the refrigerator section.
Good luck,
Gene
While these pictures are for a different brand ALL refrigerators are similar and may look some what different than your but will be similar enough oldtech2332_10.jpgoldtech2332_11.jpg
Aug 23, 2011 | GE Refrigerators
I have about 15 yr. old Sub-zero Refrigerator. Lately there are some frost forming on the wall inside it. Please help!
Try to defrost it by un-plugging it, and letting the frost melt. Also, you could try to up the temp settings inside the fridge or freezer and not have it set at the lowest setting. Try the recommended setting from the manufacturer.
Feb 03, 2010 | Refrigerators
Sub Zero Freezer (501r) has frost build up at top of door frame
  1. any luck in fixing the frost build up at the top? - having the same problem with mine. replaced the seal 6 months ago and problem has now returned.
Jan 21, 2010 | Freezers
Drain in fridge is clogged - ice formation under crisper drawers
We have cleared / de-frosted the drain twice and it keeps freezing up, causing the accumulated ice problem to recur. Should the freezer settings be changed?
Aug 13, 2009 | Sub-Zero Bottom Freezer Refrigerator
I have a 4yr old 13.7 cubic upright frigidare freezer. Running all the time, I defrosted it recently (only minimal frost/ice on base behind basket) after noting top shelf warmer than others and food...
Hi, Put a thermometer in the freezer and see if it gets down to 0 to 5 above zero. If it is not getting that cold, something is wrong. If you had frost building up behind the rear panel, there is a defrost problem.
Please let me know the temperature and I can assist you further.
Vic
Jun 20, 2009 | Frigidaire 20.6 cu. ft. / 583 liter...
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
GE Fridge not cooling
is the freezer fan running?is there any frost in the freezer?can you pull the frig. out and see how hot it is?is the comp. fan running?is the comp. clicking on and off,let me know what you find-mike
Nov 07, 2008 | GE Refrigerators
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 06, 2008 | Sub-Zero 650 / O Bottom Freezer...
I have an older side by side sub-zero.The freezer is icing up .It appears to be coming from the top inside of the unit where the fan is located.
  • possible causes:
Jul 06, 2008 | Refrigerators
The refrigerator temp keeps going up even though there isn't much in the unit
  • possible causes:
Jul 05, 2008 | Sub-Zero Refrigerators
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
74 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
