Question about McCulloch Garden
Hi i have a McCulloch chainsaw 2818av just need to know how to turn the idle up
    President:
  • 2,220 Answers
Page 7 Item 22. Below the "H" & "L" needle valves (items 20 & 21).
http://www.oscar-wilson.com/MANUALS/MCCULLOCH/211318-03.PDF
If the chain chatters it is to fast or the clutch needs repair. I think CCW is faster, make small adjustments, blip the throttle let it settle.
On the engine cover there are often 3 holes for needle valve adjustment. Idle is usualy marked "T".
If you have an Owner's Manual the location is usually displayed somewhere within. I could not find an on line OM. HTH
Lou
Posted on Feb 08, 2010
Keeping me up at night!!
It sounds like something got switched in the reassembly. It happens. Here is the service manual to try and figure it out. Let me know if that helps, or you need some more help. Good luck.
Service Manual McCulloch MS1432
May 14, 2014 | McCulloch Ms1432, 14" Chainsaw Chain 49dl...
Tune up McCulloch Mac 110
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Nov 12, 2012 | McCulloch Garden
What is the initial carburettor adjustment for a mac 120 MCCulloch chainsaw?
Hi williamsc32...
Before you remove or try to adjust your low and high speed jets you should always count the number of turns it takes to lightly seat the idle mixture screw and high speed needle adjusting screws.
Be sure to write the number of turns down on a piece of paper so you will know how many turns from the seated position to open the jets when you go to reinstall them, or if you remove them for cleaning or replacement.
If you have aready tried to adjust them then the adjustments below should get it running for you for final adjustment when warm.
Normally you will adjust your idle jet to 1/2-3/4 turn open from the bottom seated position.
Then you will re-adjust the low speed of the engine when the engine is warm by turning the idle screw in or out till the engine runs smoothly at idle speed, around 1200 RPM.
The high speed jet is adjusted to 1 1/2- 1 3/4 open from the bottom seated position, after the engine is warm.
Then re-adjusted by turning the High Speed jet adjustment screw in or out till the motor runs smoothly at high speed.
Alway use the "lightly seated" method if you have not changed the screw settings.
Please take time to rate me
Bud
Sep 28, 2012 | McCulloch Mac 110, 120, 130, 140, 160, Eb...
Mcculloch mt270 strimmer cuts out when I press the trigger
Carburetor needs replacement. Possibly primer bulb assembly as well.
Contact us
User manuals
McCulloch Service
Sep 26, 2012 | McCulloch Garden
My carberator is way out of adjustment need to know where to begin
Turn the jets all the way in then turn them out 11/4 turns.then start it and adjust the low speed jet until it idles properly.then pull the trigger for full throttle and adjust until runs smoothly.
Dec 23, 2010 | McCulloch Garden
I have McCulloch 11-600031D PRO MAC 55 08/73 to 03/77 IPL 92384A-R1. i got it running but it is hard to keep it running i screwed in both idle and mix all the way in i just don't know how much need to...
Typically the screws are seated gently then turned out 1 turn as a base adjustment. The saw should start & run, if not perfectly at this point. A little fine tuning is always nescessary. If you can't get it to run at these basic settings, a carburetor service is probably needed.
Nov 26, 2010 | McCulloch Garden
Stalls during idle
Try setting the idle speed screw CW a little (not the two jet screws) until the engine will continue to idle, but not turn the chain. If this doesn't seem to help, then adjust L jet screw about 1/8 turn CCW. Hope this helps!
Jun 14, 2010 | Garden
The second hand McCulloch 120 chainsaw I purchased
I think the pre-adjust settings are to turn jets in all the way and back out 1.5 turns each. then:
You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 08, 2009 | Standard Oregon Chainsaw Chain For...
I would like to know how to adjust the carburator of McCulloch 3516 chainsaw 35cc/cm 46759-77
the carbuator has two 2 adjusting screws on it.one is high side and the other is low side.start by turnig them both in until they touch bottom.now turn them both out 1 1/2 turns.this should start and run saw.throttle saw up to full throttle and adjust high side in until you get the best RPM out of saw.do not adjust high side any less then 7/8 turn out from bottom.if you do you will burn saw up from to lean burn.once the high sie is set now adjust low side until the saw will idle by it's self.let me know if this helped you.......
May 02, 2009 | Garden
Garden Logo
291 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
