Question about Acer Aspire 5050-3242 Notebook
PXE-E61 media test failure on Acer Aspire 5050 laptop
Upon booting up, the following msg appeared on DOS black screen:
For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.17 (051202)
PXE-E61: media test failure, check cable
PXE-M0F: Exiting PXE ROM
Operating System not found
Upon trying to do a reformat, the process is hanged at Windows blue screen while the Windows setup is doing the following:
Examining 152626 MB Disk 0 at Id 0 on bus 0 on atapi...
I highly suspect it's a hardware failure on the Realtek network adapter (cable connection loose?) but would like to confirm this
Thanks in advance for any help/advice rendered
    Problem Solver:
  • 10 Answers
Yes, your analysis of the problem is correct. The problem could be with the hardware & while you are trying to reinstall the Windows OS, the software checks on all hardwares before installing. The best solution would be to take your system to a nearest service provider & get the problem rectified. Once the problem is rectified by them, try to reinstall the OS along with them, so that if there is any other problem apart from the above they will be able to help you.
Posted on Feb 08, 2010
Testimonial: "Prompt and clear reply, highly recommended! Thanks! "
3 Suggested Answers
  • 5603 Answers
SOURCE: I have a realtek RTL8139{x}/8130/810x PCI FAST
If you use ethernet, then your connection, possibly the cable, is not working.
IF you don't use the ethernet connection, and have no cable plugged in for ethernet, the warning is NORMAL.
Posted on Jan 11, 2010
SOURCE: PXE-E61 : media test failure, check For Realtek
Are you on a company network ?
As I said if you are, then booting from a network may be part of your company system.
If it is just a home computer then you have other issues which could range from something as simple as a faulty hard drive cable to a dead hard drive.
If it is a company computer on a full lan then turn boot from network back on and see if it will boot. if not then te server that has the boot source may have an error or the lan may have issues.
Posted on Nov 01, 2011
Intel UNDI, PXE-2.0 (build 082) Copyright (C) 1997-2000 Intel Corporation For Realtek RTL8139(X)/8130/810X PCI Fast Ethernet Controller v2.13 (020326) PXE-E61: Media test failure, check...
You probably have the bios set to boot from a network, instead of the hard drive.
Find out how to get into your bios as the computer is booting (maybe F8, maybe ctrl-s?) then change the boot order to HD first, followed ny C D-ROM, followed by floppy, then network LAST.
FiOS-Dave
Aug 15, 2010 | Computers & Internet
My Acer Aspire 5100 keeps rebooting. This is what the screen says: INTEL UMDI PXE2 REALTEK RTL8139 PCI FAST ETHERNET CONTROLLER PXE-E61: MEDIA TEST FAILURE CHECK CABLE PXE-M0F: EXITING PXE ROM That is all...
The error message means that your system is trying to boot from LAN ie... Network boot enabled in your BIOS.
Since the system can't find any where to boot from. It is restarting.
Also probably your bootloader on the harddrive is corrupt. Please reinstall the operating system using a CD/DVD.
Jul 11, 2010 | Acer Aspire 5100 Notebook
Wile I am trying to boot it up it goes in to a loop
Hello.
That error message usually refers to a hard disk failure. Your hard disk cable could be loose or faulty. Or, your hard drive would need to be replaced.
I'd suggest to check the cable and run your system's hardware diagnostics (often F2 or F12) when your system boots.
Hope this helps.
Nov 26, 2009 | Compaq Presario M2000 Notebook
Argh girlfriend spilled hair gel on my laptop
thats ethernet card realtek
did you check to see hard drive is securely in tack
saying can't find os
you may need to do a new install let me know
if you took apart you made have caused hard drive to become lose
Jan 17, 2009 | Acer Aspire 3610 Notebook
ACER Aspire 3050: Operating System not found
Normal 0 false false false MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Обычная таблица"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Since the computer is on, immediately start to press F2 or DEL button in order to enter the BIOS and reset all settings to default. Most likely you turned on the «Boot from network «option.
Sep 11, 2008 | Acer Aspire 3000 Notebook
Toshiba satellite p20, pxe-e61, pxe-mof
cable plug possible defective, if possible plug into another computer and see if error occurs. since you did not state OS go into the Device Manager and insure 'network adapter' has driver installed and working. Is there an external media hooked up?
Jun 16, 2008 | Toshiba Satellite P205-S6287 Notebook PC
Acer Aspire 5050-3242 Notebook Logo
998 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
