Question about Kenwood Car Audio & Video
Trying to remove factory radio from 86 chevy g20 van with shaft style openings were to begin
    Sergeant:
  • 306 Answers
Remove the doghouse . remove the knobs and shaftnuts behind the knobs. to the right of the dash there will be a metal bracket attached to the radio and the body of the van. remove the bolt and disconnect the wiring and remove radio from behind dash
Posted on Feb 08, 2010
1990 Chevy van fusebox location
Donald, You did not state the model, so I posted the link for the models I found for chevy van fuse box. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Interior Fuse Box Location 1990 1996 Chevrolet G20 1994 Chevrolet G20...
Blown Fuse Check 1990 1996 Chevrolet G20 1994 Chevrolet G20 Chevy Van 4 3L...
fuse box diagram 1990 chevy astro van pdf 1 Docs Engine com
1990 Chevy van fusebox location Google Search
Jul 27, 2016 | Cars & Trucks
How do you remove the back seat from a 1994 chevy g20 van?
I believe the seats are bolted to the floor of the van. Make sure you unplug all electrical connections before removing the seats.
Feb 11, 2014 | 1994 Chevrolet G20
How to replace a hanger bearing on a G20 CHEVY VAN
It is pressed in in, but most just replace the entire center support assembly it is allot easier.
Jun 27, 2012 | Cars & Trucks
How do I remove or replace the arm rest on my Captains chair? I have a 1995 Chevy G20 van.
how do i remove the broken piece of arm rest from my 1999 full size chevy van . front drivers seat
Jan 24, 2011 | 1995 Chevrolet G20
Trouble replacing headlight switch
first unplug the wireing harness,on the other side ,the flat side there is a small spring loaded little button you push in and that releases the knob with the shaft then the shaft should come out with the knob,you may need to rotate the shalf to help get it out.
Jan 26, 2010 | 1993 Chevrolet G20
How do I replace the rear transmission seal on a 1993 Chevy G20 van.
Hi ...first off remove drive shaft ....you will see 4 or five bolts just before the end of the transmission ...remove it to gain access to the rear seal ...pull straight out ...some times you will have to pry slowly to remove it ...then you will see in the shaft that the rear seal is in there ....push in and remove ....put the new seal in the reverse way
Jan 02, 2010 | 1995 Chevrolet G20
How to replace freeze plug G20 van
Most drive into place. To get the old one out drive one part or edge in this will tip the opposite side out. Take hold with a pair of good pliers or vise grips and pull it out. Drive new one into place after putting sealer on the outside edge. It is possible to replce with a rubber expandable plug if it is hard to get to. Talk to your local auto parts store for the best style of plug for your needs.
Sep 09, 2009 | 1985 Chevrolet Chevy
Belt change for 1995 chevy g20
there should be a diagram sticker under the hood . first thing check to make shure all accesories move freely no locked pullys that may have shot the belt to begin with
Apr 04, 2009 | 1993 Chevrolet G20
Electronic Control Module Installation 1994 G20 Chevy Van
I just had the same problem. If it is a regular van try under the driver seat in a plastic box. If it is a conversion van try in a pannel just behind driver seat on side of van wall behind a pannel that looks like a vent.
Dec 28, 2008 | 1987 Chevrolet G20
Car Audio & Video Logo
270 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
