Question about Sony VAIO PCV-W600G PC Desktop
Inherited sons XP computer but after connecting all cables and turning on power the computer seems ok but cannot get monitor screen to work as normal. Note I have checked the monitor on other computers and it works ok.
  • 617 Answers
You need to do a right click on your desktop, to properties, to settings tab, change screen resolution at least to 800*600 then color quality to the highest it has, then apply then you can go up on screen till where you want it
Posted on Feb 08, 2010
My home dell computer monitor has went black with a box on it. * The floating dialog box appeared on screen (against a black background) * The dialog box float around the screen without any visual...
The dialog box you are seeing means that the monitor is not receiving a signal from the computer.
check your cable going from the monitor to the computer. if the cable seems ok, hold the power button on your towerr until it turns off, then wait 5 seconds and push the computer power button again.
Cheers
Dec 26, 2017 | Dell E152FP 15" Flat Panel LCD Monitor
Computer does not display any boot screen, although it turns on. no USB ports work, not do any other inputs on the rear of the machine. this was done after migration of parts to a new case for the...
DC5000MT (i think you left off the"T" right?) MT=mini-tower then.
they at SFF then too.
old old desktop pentium 4, with pata hard drive?
no monitor stated, make nor model #
no vga card stated.
migrating? oops.. why do that? nor if PC ran before?
NO OS stated,? windows XP what? (it came with XP)
ok the mobo turns on with case power button?
and the CPU fan spins fast, as does PSU fan?
what does USB ports mean>? using what there?
PS/2 keyboard. using that? or pS2/mouse?
does it beep:?
are you sure the monitor is ok?
if monitor is ok ?
and PSU and 1 stick of ram is ok
the BIOS screens work.
or the PSU
does this mobo have onboard VGA jack GPU:>
if yes, try both it and PCI video card.
and 1 stick of ram at a time. slot1, bank 0
Aug 12, 2017 | HP DC5000M PC Desktop
Samsung syncmaster225UW monitor suddenly not working on pc. Plugged into laptop works fine on analogue, on sons pc shows digital and wont let me change to analogue, any ideas, im not technically minded,...
Have you tried connecting the monitor then powering the PC on. at that point i would say it could be a problem with the PC.
When you connect the monitor and power on the PC, do you see anything on the monitor screen at all?
Has anything been modified on the PC right before it stopped?
Sep 29, 2017 | Samsung 215TW SyncMaster 21" LCD Monitor
When i plug the monitor into my computer the flashes Benq only!
Try connecting the monitor to a different computer, e.g., a laptop.
The power-cord to the monitor seems to be OK.
Check the "data" cable between the monitor and the computer -- try a different cable.
With the monitor turned on, restart your computer, and watch the monitor. The computer should show some start-up messages (white text over black background), followed by the Windows "splash" screen. If it does, the monitor is working correctly.
Jul 03, 2010 | BenQ FP737S-D 17" LCD Monitor
Having the same problem as others, my 912n monitor is a black
The problem seems to be that the computer, do not recognize “which monitor’s connected?” Follow these steps to correct the problem: Shutdown the monitor, next shutdown the computer. Unplug” the monitor, from the power outlet. Disconnect all cables on the Monitor from the computer. Next, reconnect all cables, and power, in the reverse order. Start computer first! Turn on the monitor, (right) click on an empty area of your Desktop Screen; next click Personalize, click Display Settings, click Identify Monitor. At this point, the monitor should be present, click on monitor. To finalize the application, click Apply! Next, click (OK). To “Fix” the (Resolution): Part: (1) Click Display Settings, adjust “resolution.” Click, Advanced Settings, “click” Properties, click on Drivers, “click” Update Drivers; click “OK!” Part: (2) Right click on “Desktop”, (in the upper area) check if the Graphic ™ Control Center is visibly presents, if so, click to open. You can adjust the Graphic Settings. Click “Apply” next, “OK” when finished! Restart the computer. I hope this Fix it.
Jan 17, 2010 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Dell E153FP monitor won't display any video from system (Dell GX260). My e173FP monitor works fine. E153FP powers up, runs Self Test Feature Test fine, menus all seem OK. Tried Factory Reset... still no...
You probably have tried this, but make sure monitor is set to correct display... i.e., Analog or Digital
Also, try starting in safe mode and verify Monitor is able to handle the display settings resolution
I’m happy to help further over the phone at https://www.6ya.com/expert/steve_52488d61fac93877
Apr 10, 2017 | Dell E153FP 15" LCD Monitor
Power light flashes momentarily; monitor will not turn on
It seems that you've already checked this no, but double check that the power cable in the back of the monitor is securely plugged in. My suspicions would be that there's some kind of breakage in the power cable itself. I suggest you inspect every inch of it carefully.
Nov 21, 2017 | ViewSonic 19 VE910B 1280X1024 TFT LCD...
Screen black
Take the post (power on self test) disconnect vga cable and connect power cable if monitor shows no signal check signal cable massage then monitor is ok fault is in cpu. open it and clean the dust
by vaccum cleaner you will get the display again
Oct 17, 2008 | X2Gen MG19MY 19" LCD Monitor
Sony VAIO PCV-W600G PC Desktop Logo
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
