My machine has professional XP with service pack 2. I can see in the device manager the USB2 but when I plugin a USB2 device (HD or card reader) I recieved an error saying: "This device can perform faster if you connect it to a Hi-speed USB 2.0 port" I updated the Bios but no louck.
Is there away to set it up for USB2? My machine has professional XP with service pack 2. i have usb2.0 but i could work with speed of usb1.1 when i connect a high speed usb drive a bllon shows error "This device can perform faster if you connect it to a Hi-speed USB 2.0 port" I updated the Bios but no result if i install it from mother board disk it give error that is Windows XP USB2.0 Driver Installation ==================================== Please using Windows XP SP1 (Service Pack 1) or later versions, you DO NOT need to install this driver, because they already contain software support for USB 2.0. what can i do
-   also: MSI KM3M-V Motherboard and i can work with my devices, when i disable usb 2 rendering: The result is mutch slower but works. When i listen music or printing, its fine, but if i wanna copy like 5 Gb data into external hard- Drive, it takes 150 minutes.-   Guest
Jan 19, 2009
-   exactly the same problem.... not recognize... but it did the SD Card
-   Guest
May 09, 2008
-   I too have the same problem and the usb ports are 2.0 because sometimes I can uninstall them from the device manager, reboot and when I plug in my device the message will not appear but for some reason it will hiccup and the message will reappear. does anyone know where to get the usb 2.0 drivers?
I do not care about service pack 2, I just installed service pack 3 and it did not fix the problem.-   mattmurdock
Hi, your USB port's on motherbord are probably 1.1 and because of that you give message "This device can perform faster if you connect it to a Hi-speed USB 2.0 port" There is solution buy a new motherboard :+) good luck
my macine mercury board815E and celeron 1.1Ghz processor, is there when i attatched my external harddisk via usb port that will not recognized even its power also not on plz give solution to me
Try opening up the device manager and unistall everything in the Universal Serial Bus Controllers. Then reboot and let windows reinstall the USB controllers. Windows should now be able to recognize properly USB2 devices.
I have a pixma mp830. I try to print in color but it comes out mostly pink with lines everywhere. I...
(More)
I have a pixma mp830. I try to print in color but it comes out mostly pink with lines everywhere. I have taken all ink cartridges and replaced them with new ones. I took out the holder for the cartridges and put it and warm warter none of these worked. Any suggestions?
