Question about Microsoft Computers & Internet
Monaco EZ Color doesn't work with Vista 64-bit
I have Monaco EZ Color v. 2.6, Rev. 111503. It has worked on my older computer using Windows XP. It doesn't work on my newer computer using Vista 64-bit. My monitor is profiled, but I need to profile my printer for various papers. Any solution?
    President:
  • 3,278 Answers
Hello.
Give this a try:
Select the EZColor v2.6.5 driver. Download, save, unzip and install from:
http://shop.colourconfidence.com/page.php?xPage=updates.html
Hope this helps.
Posted on Feb 08, 2010
Windows 7 will not recognise vdr-m70 dvd camcorder
Panasonic supplied software for the VDR-M70 for Windows 98 through XP on the CD. Due to changes in the OS over time, the installer can't run under Windows 7. Panasonic has not updated the drivers for Windows 7 and Microsoft indicates that it is not compatible with any version of Windows 7.
There are work-arounds depending on your version of Windows 7. If you have the 32-bit OS, try using the compatibility mode. To find out which version of Win7 that you have, click Start > Control Panel > System and Security > System. If the name of the OS ends with x64, then you have the 64-bit version of the software. Otherwise, you have the 32-bit version.
For the compatibility mode, right click on the installer on the CD (browse Computer). Choose Properties and then click on the Compatibility tab. Select Always Run this program as and an older version of Windows (XP). Apply and Save your changes. Then right click again on the installer and choose Run as Administrator.
This may not work (and won't work for the 64-bit Windows 7). If it doesn't work, you need a machine with an older version of Windows. This can be a second computer, a dual boot computer or a virtual computer (if your hardware supports virtual computing). For most options, you will need a licensed copy of the older version of Windows.
If you have Windows 7 Pro or Ultimate or upgrade to one of them, you can have a virtual version of XP for free. Download and install Virtual PC and XP mode from Microsoft in order. Then install the software for the camcorder in XP mode as if it were your only computer. (Of course this doesn't help if your hardware doesn't support the Virtual PC.) Other virtual computer programs are VMWare and Parallels.
Note: you can not directly share files or hardware between the Win7 and the virtual computer. You have to put files on an external drive (optical, flash drive or other external hardware) to share them.
I hope this helps.
Nov 12, 2011 | Panasonic Palmcorder VDR-M70 DVD Camcorder
THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW CAN I FIND THE DRIVER?
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
Oct 03, 2011 | Mitsubishi Color Printer 8000DW Thermal
Will Platinum 16 run on my new windows 7 computer
From their web site:
Windows® XP SP3/Windows Vista® SP1/Windows® 7¹, Pentium® III, 500MHz processor or faster for Windows® XP and Windows Vista®; 1GHz or faster 32-bit or 64-bit processor for Windows® 7, 128MB RAM (1GB Windows Vista®, 1GB Windows® 7 32-bit, 2GB Windows® 7 64-bit), 8x DVD-ROM Drive or faster
Looks like it should work.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 26, 2011 | HP Computers & Internet
Instant dvd recorder software 'not responding'
Hello Joshua,
Instant DVD Recorder 2.6.1 UPDATER
  • Please install the Instant DVD Recorder 2.6.1 UPDATER if you are using the Dazzle DVD Video Recorder, Dazzle Video Creator or Dazzle Video Creator Platinum with a previous version of Instant DVD Recorder. This updater also includes the hardware drivers.
  • If you are using a Dazzle product already that includes Instant DVD Recorder version 2.6.1, then you do not need to install this update.
New with this version:
  • added support for Windows Vista 64 bit and Windows 7 (32 & 64 bit)(
  • Includes Windows Vista and Windows 7 drivers (for both 32 and 64 bit) for the DVC 100, 101, 103, 107 hardware NOTE: DVC130 and DVC170 don't have 64 bit drivers and can only be used with Windows XP and Windows Vista 32)
  • 16x9 detection
  • PCM Audio (already included with Instant DVD Recorder ver. 2.5)
Supported Hardware:
  • Dazzle Video Recorder ( DVC90) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC130) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator Platinum ( DVC170) - Windows XP and Vista 32 bit only
  • Dazzle Video Creator ( DVC100 and DVC101) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator ( DVC103) - Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • Dazzle Video Creator Platinum ( DVC107) Windows XP 32 bit, Windows Vista and Windows 7 (32 bit and Vista 64 bit)
  • and other compatible hardware
Installation Instruction:
  • To be able to install this version, you must own an Instant DVD Recorder Version 2.x full version
  • To install this Instant DVD Recorder version not as an update but as a full version you need to enter your Instant DVD Recorder Version 2.x serial number during the installation process. The serial number was included in your Dazzle product.
  • With Windows Vista 64 bit or Windows 7 64 bit, you need to install Instant DVD recorder 2.6.1 as a full version.
  • If you own an Instant DVD Recorder Version 1.x full version, to only install Instant DVD Recorder 2.6.1 full version.
  • If you use this Instant DVD Recorder Updater to update the Instant DVD Recorder included with Studio Version 12, 11 or 10, please make sure that Instant DVD Recorder is already installed on you system. Please note that the version of Instant DVD Recorder included with Studio Version 12, 11 or 10 can't be installed under Windows Vista 64.
For Windows XP
http://apps.pinnaclesys.com/cdb/register/enter.aspx?checkRegistration=1&langue_id=7&supportFileID=35261&productid=2250
For Windows Vista 32 Bit
For Windows Vista 64 Bit
For Windows 7
Sep 15, 2011 | Pinnacle Dazzle DVD Recorder
I have a ce-100 futura sewing machine that will not work with windows 7 what do i need to do to fix this problem
The Futura software and the machine drivers exist for Windows 98, NT, 2000, ME, or XP. If you have Win7 32-bit, you may be able to run in the compatibility mode. Load the CD into the optical drive, then right click on the .exe file on the CD. Then choose Properties. Select the Compatibility tab and check Run this program in the compatibility mode. Click Apply and OK. Then right click again and choose Run as Administrator. This isn't guaranteed to work since the changes in the OS are significant.
To check if you have Win7 32-bit or the 64-bit version, click Start > Control Panel > System and Security > System. The title will say Windows 7 (Version) for a 32-bit OS. It will read Windows 7 (Version) x64 for the 64-bit version of the OS.
If you have the 64-bit OS or the compatibility mode doesn't work, you need a computer running an older version of Windows. This can be a second computer, a dual-boot computer (where you select your OS at startup) or a virtual computer (that runs inside the real computer). If you have Win7 Pro or Ultimate or upgrade to one of those versions, you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS.
I hope this helps.
(The last person I dealt with with the issue of an embroidery machine not talking to Windows 7 kept their old Windows XP computer just to work with the sewing machine. Fortunately the old computer was still working enough to use for the purpose.)
Jun 28, 2011 | Singer CE-100 Futura Computerized Sewing...
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
I have the photo printer for 4 years, just installed it with original ink cartridges, the printer prints regular text just fine, but in trying to print photos, the photos come out very red with no...
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 28, 2010 | HP Photosmart 8450 InkJet Printer
Integrated Camera is not reconized by vista 64-bit.. Please help me....
Very often you will find that not much older periferials like Cameras, Printers, Ipods, Scanners, and many Applications do NOT work with VISTA 64 Bit O.S..
First go to the CAMERA MANUFACTURER Customer Services or Website and see if they have a PATCH or another Driver for this camera so it can operate on VISTA 64 Bit. If it does, simply DOWNLOAD THE DRIVER AND "RUN" it and it will replace to old driver and your Camera will Run Properly,
If there is no Driver offered to run on 64 bit program then you have more serious issues that require more radical fixes which you have to evaluate on the basis of how much you need the Periferial or can there be a substitute that can run on the 64 bit program. 64 Bit programs are basically not much different from the much more popular 32 Bit Programs your camera would probably work on, no problem.
Try Calling Microsoft Customer Service and/or look on their Home Page for Solutions but generally the only alternative is:
1) Return the Camera and Exchange for one that runs on Vista 64 bit O.S.
2) Downgrade your Computer to a 32 Bit Version of Vista.
3) Look for the latest Beta Solutions you usually find on Google that may fix this
Vista 64 Bit O.S. Versions are only necessary if you are using more than 4 GB of RAM for e.g. GAMMERS who require a lot of Memory (actually up to 128 GB). Otherwise there is little difference between 32 and 64 bit versions. As VISTA was not that popular to begin with, many manufacturers did not bother providing UPGRADED SOFTWARE AND DRIVERS for VISTA 64 BIT assuming few would buy it off the shelf and mostly their product would be used with WIn XP or Vista 32 Bit until the Next Microsoft O.S. Came around.
Vista is a Memory Hog and as such should be used with only 4 GB of RAM for it to run properly. 3 is adequate, 2 GB its lethargic at best. VISTA 32 bit HAS A LIMIT OF 4 GB of RAM so that is cutting it close but still a better idea to "DOWNGRADE" to 32 Bit so your O.S. would be much more compatable with other Periferals and Software Applications. Many Periferals ( appliances) and Applictions will not run on 64 bit programs especially if they were designed before 64 bit was introduced. THE BEST FIX, IF YOU ARE NOT A RAD GAMMER REQUIRING MORE THAN 4 GB OF RAM is to "DOWNGRADE" TO VISTA 32 bit or even better to Windows XP if your computer can work with that O.S.: check with the Manufacturer. Your camera may even work on XP 64 bit.
Kodak still makes some nice disposable Film Cameras; you can take your pictures then have them developed, and scan them into your computer that is if your SCANNER STILL WORKS with the 64 bit program LOL
Good Luck
Aug 20, 2009 | Lenovo ThinkPad T61 Notebook
Canon MP500 all in one printer is not compatible with Windows Vista. Is there a solution for this problem, or do I need to buy a different printer?
My Canon PIXMA MP500, purchased in mid-2006, came with the (then) ScanSoft OmniPage SE2 software on a CD. The PC had WinXP Installed. I had no use for the ScanSoft it so I made no effort to install it.
Fast Forward:
Two PC crashes later, July 2009. Using Win Vista Home Premium
LOST, important WinWord document file, only a hard copy available.
I tried to recover, scanning the "Xerox" copy. The SE Version of OmniPage was very complicated but I succeeded in producing a replacement *.doc file.
It appears that newer editions of WinVista contain the right printer drivers for this Canon Model.
Apr 26, 2009 | Canon Pixma MP500 All-In-One InkJet...
LG UX830 phone and Windows Vista 64 bit
The drivers provided by LG will work on either XP or Vista, but are 32-bit, and will not work with the 64-bit versions of Windows.
Oct 26, 2008 | Lands Phones
Computers & Internet Logo
230 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
