Question about Dell Dimension 2300 PC Desktop
Dell 2300 motherboard map I want to know where is power conecction
  • Dell Master
  • 2,517 Answers
Please follow the link below for external power connecter.
Click me.
For Motherboard power connection plug watch the below image.
Its a white color Plug.
Posted on Feb 08, 2010
    Scholar:
  • 59 Answers
Here is the download link to the the manual (pdf format) you seem to need.
Dell dimension 2300 not powering on
This may be because of the following reasons.
1: Your SMPS may be faulty
>In this case you can replace it easily.
2. Your Motherboard can be faulty.
>In this case, you may need assistance of a trained service technician to check the whole circuit of motherboard.
3. May be the power cable to your CPU may be faulty
>Replace it with a new one.
Oct 10, 2011 | Dell Dimension 2300 PC Desktop
Installed new dell motherboard per tech, installed new Dell power supply as it died too. This is a Dell Dimension 2300. It won't start.
Check all connections, to the motherboard, and also to the wall Verify that the power supply is actually switched into the ON position at the rear of the computer.
Mar 09, 2010 | Dell Dimension 2300 PC Desktop
I bought a pentium 4 3.0 ghz 800 mhz & my
The motherboard chipset of the Dell Dimension 2300 Desktop PC, will not support a processor with an 800MHz Front Side Bus frequency rate.
Only Intel Pentium 4's that use a Socket 478, 1.75 Volts, and a maximum of a 400MHz FSB.
The Intel Pentium 4 HT 3.0GHz processor has an 800MHz FSB, (As you have already stated), and uses 1.475 to 1.55 Volts.
The motherboard chipset for that Dell Dimension 2300, is an Intel 845GL.
This list on Wikipedia, shows you parameters the Intel 845GL chipset supports,
http://en.wikipedia.org/wiki/List_of_Intel_chipsets#Pentium_4_Chipsets
Not a good outcome, sorry. Just stating the facts.
Jan 08, 2010 | Dell Dimension 2300 PC Desktop
How to map usb ports USB1, 2, etc.
You don't map the Universal Serial Buss. You just hook all the devices to the connection points (ports). The computer find them by device, MAC address, etc., not by port number. You can hook up to 127 devices to a computer, and the computer will talk to all of them regardless the physical point of connection. That's the reason, you can buy USB hubs with 4 or more connection points that plug into an USB port (how do you map that?).
USB1 - 6 is for you to know how many devices are connected to the computer via USB at a certain time.
So if your printer is configured for USB1, what ever port you plug that printer in, will be USB1.
Oct 02, 2009 | Dell Dimension 2300 PC Desktop
My dell dimension 2300 powers on,but nothing shows on the screen and i just got a brand new power supply for it.Also when i turn it on the power light isn't lit and it sometimes works.
Could you please post back with the status of four lights at the back of the system title ABCD. Also does the system shows the dell logo on the screen as and when the power light comes on.
Try removing the memory and disconnect the HDD and the optical drives from the motherboard and then power on the system. If the system comes on reseat all the above components one by one.
Thank You for using Fixya
Proton
Jul 12, 2009 | Computers & Internet
I have a dell dimension 2300 that turns on, but the power light won't light up and the screen is blank.Is it a motherboard problem or power supply problem.
I've run into the problem several times and it can be both.Your best bet would be to try the power supply first, being the cheaper and easier of the two. If you have another desktop you could try swapping the power supplies to test (make note of which plug goes where, it's fairly simple as long as you pay attention).
If you don't have a spare then it's possible a local tech store would have one you can purchase or pay them a small fee to test for you.
If swapping them doesn't work then it points at the motherboard.
Hope this helps :)
Apr 16, 2009 | Dell Dimension 2300 PC Desktop
Dell dimension 2300
I don't know what TRIPS out sounds like, but there are number of different things that could make sounds when powered up. Let me know what and where the sounds are coming from. I am including a link for delll support for your system. Let me know if I can be of any more help. Larry
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs&SystemID=DIM_PNT_P4_2300
Mar 06, 2009 | Dell Dimension 2300 PC Desktop
Dell Dimensions 2300 hard drive replacement
that one looks like you would need a Serial ATA-enabled motherboard or adapter card find one that is pata/ide
Aug 03, 2008 | Dell Dimension 2300 PC Desktop
Dell 2300 desktop
Does the system TURN ON atleast if YES and if you do not see any action on all the peripherals that you hae mentioned above THEN CHANCES ARE YOU HAVE CONNECTED THE HDD DATA CABLE REVERSE . Remove the connection and switch on the system and see if it works . The correct way to connect the HDD is on the DATA cable which is 40wire/80wire look for one which is RED or BLUE this should be plugged nearer to the power connector (the orientation).
Apr 09, 2008 | Dell MOTHER BOARD POWER EDGE 2300 0007891P...
Dell Dimension 2300 PC Desktop Logo
811 people viewed this question
Alun Cox
