Question about Electrolux Washing Machines
Simpson top loading washing machine turned itself off in the middle of a cycle and now will not turn back on
  1. Hard To Repair LCD TV
  2. Maintenance Agreement
Posted on Feb 08, 2010
My LG top load washer keeps stopping mid cycle- what could be wrong?
First rule out the simple points like to clean the filter for fluff or coins that may be interfering with pump. Secondly is the pump itself.
Jan 09, 2018 | LG Washing Machines
I have a simpson esprit 750 automatic top load 7.5 kg washer on any cycle i try to fill it up to start cycle as im filling it up the water is draining out
Hi if it's draining out on your floor you have a split hose, very easy to fix just put your washing machine forward(turned off)and lay it on a towel, Look underneath and you should see the split hose..... Good luck....
Mar 18, 2016 | Simpson Washing Machines
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Error code df on a simpson washing maching
The clue is in the water temp. light flashing. DF means that the temperature sensor is faulty. Replace it with a new one. Turn power off at wall. Remove the 3 screws & open panel. Sensor is plugged onto control board near the middle top of board & goes down into the base of the control panel at the middle where the water enters the machine. Unplug from the board taking care not to damage the pins on the board. Replace the new one making sure the o-ring is on it. Close up panel & turn power back on.
Oct 15, 2012 | Simpson Washing Machines
GE top loading washer turns off by itself
How about a lid switch. Try pushing down on lid to restart.
May 10, 2010 | GE WBSR3140DW Top Load Washer
Simpson Aquarius washing machine 7kg: water
SOUNDS LIKE A PLUMBING PROBLEM WITH DRAIN PIPE .YOU COULD FIT NONRETURN VALVE TO DRAIN FROM WASHER BUT THAT WOULD NOT STOP SINK FROM OVER FLOWING
Jan 08, 2010 | Washing Machines
Simpson enduro 701 very slow to fill and timer sticks
Hi my name is joyce, sounds like you have trash in you water filter that is in your water line that comes in your machine in the back of washer, this may be the cause for the slow water and the timer will cause the machine not to advance to the next cycle, if you would like I will help to find a service techincian.
Joyce
Feb 06, 2009 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
90 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
