Question about Refrigerators
Drip tray inside fridge is turning to ice then defrosting and making a big puddle inside the bottom of the fridge then running out thru the door
  • 572 Answers
Ur drain is clogged
Posted on Feb 08, 2010
While cleaning fridge I left the door open too long now it won't work. Help
Ice can build up inside the thermostat and mechanism housing when the door is left open and then stay stuck stopping the compressor from going on until the refrigerator is defrosted. If you see water dripping or a puddle inside the unit then it needs to be defrosted.
Dec 07, 2016 | Refrigerators
RB215LABP Samsung Heater drip tray not draining. Drain seems to be free of debris. In my opinion the tray is not heating up during defrost.
the water condensation in fridge or freezer is usually the result of bad door seals, or a clogged drain line. Unless ur having a defrost issue and its freezing over really bad and hindering air circulation. then check the defrost terminator and heating element.
Freezer /fridge water/ice in fridge and or freezer, or leaks on floor
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
Jun 22, 2015 | Samsung Refrigerators
Kenmore refrigerator ice build up bottom tray of freezer
check ur defrost system then
Aug 15, 2014 | Kenmore Refrigerators
My whirlpool French door fridge is leaking all over the floor. The drip pan underneath is bone dry. I can't find the drain hole inside the fridge to see if it is clogged. Is letting it thaw for tw
there is a water tube connection at the bottom of door on hinge side that has a spring and allows it to swing with door. it also has a fitting there so the door can be removed.it is the tube running inside the door to the ice water dispenser. if it has one, it can leak at the fiting
Jul 07, 2012 | Whirlpool GX5FHDXVY Stainless Steel (248...
Water leaking inside our fridge. kenmore fridge. about 8and a half years old.
There is a drain line that discharges water from the freezer when the defrost cycle kicks in. It will be a plastic tube that runs from the bottom of the freezer to a tray under the fridge. It has come loose or become plugged I always blow air thru the line and make sure it is not loose. You can also get leakage from an ice maker but this problem will usually show up as ice formingin the freezer first. good luck
Aug 10, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Side by side leaks out front door on freezer side
try checking the tube that water drains out , it could be plugged with crumbs or old partials of food and causing the problem, This has happened with my fridge at one time , affecting the defrost cycle of the freezer and dripping water out of the door, The tube was located under the crisper in the back of the inside of my fridge, Hope this solves your problem
Apr 19, 2009 | Kenmore Refrigerators
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
JCD2389DES Water Leak Problem
We also had this problem with a Jenn Air side by side. I cleaned out the drain tube and melted the ice in the collector tray but we still had water coming out of the freezer door later on. My wife started looking for a new fridge because she was tired of cleaning up the pudles daily. I went online to another site and found this to be a common problem. It seems the defrost cycle is not long enough to let all the water drain out of the collector tray and it ends up frozen in place and the the tube gets blocked and the the water runs down the inside back of the freezer untill it fills the the bottom of the freezer. Then it freezes and the the next time the water flows out the front of the door on to the floor. There are kits available to solve this problem and they cost about $20. I looked at what was in the kit and made my own part. It is a 9 or 10" long piece of # 12 or #14 copper wire (house wiring ground wire).
Turn off fridge and take the shelves out of freezer and then take off the large grill on the back wall and melt the ice in the bottom area where the metal water collector tray is. Look under the fidge where the evaporator tray is and make sure water is in fact running down the tube. To make sure it is, empty out the evap tray and put it back in and pour water into the defrost collector tray to see if the water flows down to the evap tray. If it doesn't then blow it out. If it does then take the copper wire and shove all but 2" of it down the tube that drains the collector tray. The last 2" or 3" of wire needs to be bent 90 degrees so that it lays flat in the tray. It seems the cooper wire that is down inside the tube conducts enough warmth from outside the freezer to keep the tray from freezing up to soon after the defrost cycle and lets all the water drain out down to the evaporating tray which is under the fridge. We never had water in the evaporating tray before because it was never making it down the tube. It has been many months now since my fix with no water on the floor.
Jun 27, 2008 | Jenn-Air JCD2389G Side by Side...
Water from core is getting into my freezer
Right, the drip tray on the upper coil section has a blockage (possibly mold) that prevents the defrost condensate from reaching the evaporator pan that should be at the bottom of the fridge. Those lines are usually accessed from the back of the fridge.
Jun 19, 2008 | Amana ARB220RCW Bottom Freezer...
'ice dam' on bottom of freezer, now problems with fluctuating temps
Kat, you only have 1 problem happening.And no this is not due to the original repair. (though I have to admit... replacing the filter/drier, starter and compressor is NOT part of routine maintenance and has me a little befuddled.) Your evaporator drain is plugged. Most likely with what we in the biz call "bio-gookus". This is normal, but must be cleared to keep the water from puddling and coming out your freezer door. With the evap panel removed and the drain hole exposed, pour 1/4 cup of HOT water into the drain hole. Use a small screwdriver or other small instrument to pick out the ice buildup. Once this is clear, use something like this http://www.azpartsmaster.com/shopazp/Gallo+Condensate+Blowout+Guns+(A66800).html to blow out the rest of the lines. After doing this, pour more hot water into the drain to verify free flow. This will take care of your leak problem. Now... the frost buildup. NEVER RUN YOUR FRIDGE WITH THE PANELS OFF! They are there for a reason, believe it or not. They direct air flow across the coils (both evaporative and condensing). Frost buildup is normal, though you may be experiencing higher levels of frost because of the panel missing...Your fridge utilizes an automatic defrost system. It'll initiate every 8 hours. This is controlled by a timer located in your fresh food section. The defrost heater RARELY fails on these. Fix the evaporator drain and replace all panels. This will solve your dilemma.
Aug 09, 2007 | Maytag MSD2758G Side by Side Refrigerator
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
