Question about GE 24 in. Monogram ZBD6880KSS Stainless Steel Built-in Dishwasher
Touchpad on GE monogram not working right
The touchpad won't let me change the wash cycle which is stuck on china/crystal. Also the light showing that the dishes are clean or santized doesn't come on. I don't care about that, but would like to change the wash cycle
  • 291 Answers
This is a pretty expensive repair that I don't usually recommend. You have a bad touchpad assembly, and may have a bad main control board. This is a pretty expensive maybe, with no perfect way of diagnosing both problems, without first installing the touchpad and testing to see if it is the only bad part. You can check to see if there is any warrantee left on the electronic parts. If your Dishwasher is only 2 to 5 years old, your owners manual will usually tell you what warrantees you have. Some only have a year warrantee, some have a 2 to 5 year electronic control warrantee. Also we are seeing a lot of these repairs right after there was a power surge in the area. You can have your dishwasher rewired by installing a normal receptacle that is accesible to you, and install a surge protector that your dishwasher is plugged into. You can also have an electrician install a surge protector for your whole house, in your circuit breaker box. If you do replace your dishwasher, the dishwasher that I have the fewest repairs with is the Whirlpool/KitchenAid model.
Posted on Feb 08, 2010
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
Tip
Tips For Dishwasher for its safety and getting dishes cleanest
A) If your household is small, try gradullay accumulating a full load of dishes and rinsing as you go, instead of stacking dirty dishes in the dishwasher.
B) Cleaners and some elbow grease will always get pots and pans cleaner then the pots and pans cycle on the dishwasher.
C) Good crystal and china should be hand washed and not placed in the dishwasher since the detergents and jostling can damage them quite easily.
D)It can take several hours for dishes to dry when using the no-heat dry option the dishwasher. Try propping the door open to speed the drying process.
on Dec 14, 2009 | Dishwashers
How is the china and crystal wash cycle different from the regular cycle on my GE Triton XL dishwasher? Can I use regular dishwasher soap on my china and crystal?
Most dishwashers that employ this setting use a lower temperature for the water and also they do not use the element to dry the dishes, they are air dried. China and crystal are very sensitive to changes in temperature and can crack easily. They should always be washed by hand however if you have to use the dishwasher make sure you have a mild detergent. No bleach or acid should be contained. If it says citrus anything it has acid in it. Also use half the amount of detergent regardless of its strength. Hope this helps. Good Luck!
Jul 19, 2011 | GE Tritonr XL GSD6260JCC Dishwasher
Whirlpool model dp8500xxn2 Leaving white film on everything
Dishwashers have a part usually called a separator or accumulator which traps the dirt from the water during the wash cycles while the water is continuously recycled to clean the dishes. At the end of the cycle the separator is flushed out and the trapped dirt goes down the drain. If it doesn't get flushed out the dirt builds up till it starts showing up on the dishes. Some separators have a hole on top and one on bottom with a valve which stops up one hole or the other depending which cycle it's running. The valve can be stuck or broken causing the problem.
Apr 11, 2011 | Whirlpool Dishwashers
Which is the best powdered cascade product for the china/crystal setting on my miele?
Most european dishwashers are water conserving and energy saving. You have to be very careful in the type of detergent that you use. Plain, original cascade powder works fine in your Miele. Use 1/2 of the recommended amount, as your dishwasher uses much less water than the american machines that the amounts are written for. avoid cascade with additives such as bleach, or dawn. these additional components in the detergent do not rinse off well with the reduced water quantity, and will leave a gritty white residue on your dishes. Stick with the plain powder. I use Finish tablets with the red powerball, and I dont add rinse aid. These tablets work great in the Miele, asko, Bosch, and other imported dishwashers.
One caution on your china and crystal setting, your manual states that if you want to use the china and crystal cycle, the dishwasher should be connected to cold water only. The temperature of the china and crystal setting is limited to 115 degrees. your hot water is probably much hotter. if your dishwasher is connected to hot water, it will defeat the purpose of the lower temperature cycle. you will get etching on your crystal glasses.
Remember, the Miele will heat its own water one batch at a time. Connect it to cold for energy efficiency, hot for shorter cycle times. but cold only for china and crystal.
Enjoy your machine.
Nov 18, 2010 | Miele G2183SCSFSS Builtin Dishwasher
Not cleaning dishes.
check if some dirt got in the arms of the washer as sometime this will slow the flow of water and not allow the pressure to clean the dishes well
May 24, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dirty Dishes
Hello Peter, Welcome to Fixya. I'm going to start by asking a couple of questions, but that is part of a proper and thorough diagnosis from afar...in my opinion. Does a "normal" wash cycle take longer then 2 - 3 hrs ? Do the dishes appear to be dry when the dishwasher completes the cycle ? Further to this question, does there appear to be any heat in the machine upon completion of the cycle ? I ask these questions specifically because heat is a crucial factor in desolving the detergent ( usually a minimum of 145F ) and thus cleaning the dishes as well as allowing the dishes to dry properly when cleaned. If we could start here I will be better equipped to helping you solve your dishwasher troubles and with any luck assisting you in repairing it yourself. I'll watch for your reply and we'll go from there. macmarkus :)
May 23, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Rinse agent cycle
Visit Bosch web site and get a user manual. Or tray the authorized service center
May 02, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
The dishwasher has been running for 3 hours and seems to be stuck on 1 minute left. Upon opening, there was sudsy water remaining in the bottom, but the dishes looked clean. The washer just won't go to...
SHU 53 MODELS To start test program, press and hold both SCRUB WASH and DELICATE/ECONO program buttons, then turn unit on by pressing ON/OFF button. Initially, control module version # will be displayed (e.g./ ?21? = version 1 with jumper). When wash program buttons are released, lights above them will flash. To end test program, press ON/OFF button. To check each program indicator light, press its button. To check Cycle Countdown display, Refill Rinse Agent light and REGULAR WASH light, press REGULAR WASH button (press Delay Start button to test Cycle Countdown display alone). Cycle Countdown display will show ?88″ when REGULAR WASH button is pressed and ?8h? when Delay Start button is pressed. To start testing, press both the SCRUB WASH and DELICATE/ECONO buttons a second time. When testing has ended, Cycle Countdown display will show a fault using codes below. If more than one fault occurs, code numbers will be added together, (e.g./ ?6? = faults 2 + 4). 0 = No faults detected 2 = Heating fault 8 = NTC (temperature sensor) fault 1 = Aqua Sensor (?Sensotronic?) fault 4 = Filling fault F = Filling fault (display occurs during wash, not test) To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty. If water level switch (f1) has failed (opened), display will show fault code ?4″ and unit will continually fill and drain where testing won?t be completed. If flow switch (e5) has failed (opened), display will show ?0″, water won?t heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), display will show fault code ?8″ immediately and testing will end shortly after water has started circulating.
Aug 01, 2009 | Bosch SHU5315UC Dishwasher
Open Questions:
See all GE 24 in. Monogram ZBD6880KSS Stainless Steel Questions
GE 24 in. Monogram ZBD6880KSS Stainless Steel Built-in Dishwasher Logo
387 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
