Question about T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 system crash
The phone turns on but it has a big red x on the screen. if i reboot it will the red x go away?
  • 8 more comments
  • Anonymous May 20, 2008
    my sidekick 3 says it has a system crash and when i turn it on it has a big red x and it has some numbers in the top and it says assert failed
  • Anonymous May 21, 2008
    MY SIDE KICK TURNED ON ONCE AND HAD A RED BIG X THROW IT AND WHEN I TURNED IT OFF IT NEVER TURNED ON AGAIN
  • Anonymous Jun 14, 2008
    my pjone has a red x through it. how can i gett it to work again?
  • whoremouth Jun 28, 2008
    when i power the phone on a red x appears on the screen
  • djvtrix Jul 31, 2008
    my phone has a big r x over the danger start up sign.
    and it reads: SYSTEM CRASH @10007F54: evt1 AND EARLIER DEVICES ARE NOT SUPPORTED.
  • Anonymous Aug 05, 2008
    well when i turn it on it showa this big red X...then sum numbers,,,,,,but i rebooted lik 3 million times....and still no help...so what can i do now
  • Anonymous Sep 04, 2008
    im anthony
  • 11icewomen Oct 03, 2008
    Yeah, I have the stupid red X of death on my side kick with SYSTEM CRASH @10007f54: saying EVT1 and earlier devices are not supported. WILL SOMEONE PLEASE HELP!!!!!!!!!
  • Anonymous Apr 26, 2009
    i have a sidekick 2008 and it crashed what do i do!!!!
  • bobthesurfer May 08, 2009
    i hooked it up to charge and the screen immediately went black with a red x and error script along the right hand side. ive trouble shooted with it (@+1+0+r) and that didnt help. any other ideas?
Ok the exacct same thing happened to my phone... what i did was i kept taking out the battery, and seeing if my phone would work. there r few things that can happen everytime you take out the battery aand put it back in:
-it will show the menu button (the bottom left button on your phone) in black and white
-itll show the red x again
-the backlight might or might not turn on
-itll start up and work normally
these things will happen everytime u restart ur phone affterwards, and, usually, ur phone, even if it starts up, will go really slowly and eventually freeze, forcing u to repeaat the battery cycle.
after a while, it became worse, but, after fdoing thte battery thing over and over, it finally started up, and took me to a reboot screen, where it showed me a tiny clip art pic of a sidekick with a =P face that was broken. then it showed me the reboot screen, asking me if it wanted me to reboot, and, afercliking yes, it starteed working again
Posted on Mar 27, 2009
I had the exact same problem... what i did was take off the the battery and removed the micro sd memory card, sim card. Replaced the battery and it started up... it was amazing... chances are that my sd card had an infected file in it..
Posted on Dec 30, 2009
Posted on May 27, 2010
    President:
  • 625 Answers
Guest-
YOu can try a hard reset. with the unit powered on, pull the battery out. I have heard this working for some people.
Good luck
Posted on Jun 16, 2008
  • 76 Answers
The red X usually means you have a virus on your phone from the internet or an efected file you uploaded to ur phone. Hope this helps. =)
Posted on Feb 25, 2008
Sidekick 3 for AT&T?! PLEASEE HELP!
Press "menu" (the key with the 3 lines) and "L" - this will bypass the activation screen. You will need to do this every time you turn the phone on, though.
Jul 08, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick id big red x
check t-mobile support for firmware update.
If you can't get one from tmobile support you will most likely have to send this one in for service.
Jun 28, 2008 | T-Mobile Sidekick ID Cellular Phone
Tip
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all...
Device randomly reboots - T-Mobile Sidekick® II (all styles) / Sidekick® 3 (all styles) / Sidekick iD
  1. Check the device's battery level for at least two bars of strength.
  2. If the battery level is low, charge the battery.
  3. If the issue is not resolved, remove the back cover.
  4. Remove the battery.
  5. Wait 10 seconds.
  6. Press and hold the W key.
  7. While pressing down the W key, re-insert the battery.
    • The device restarts and after approximately 15 seconds, the 'Recovery' screen appears.
  8. Select the desired language.
  9. Select Reboot to restart the device.
on Dec 09, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3: System crash and big X, won't start up
HOW TO DO A MASTER RESET ON A SIDEKICK 3 NOTE: Performing this will restore your device back to factory defaults, meaning you'll loose everything on your sidekick!
1. Remove the battery and the SIM card from the device. 2. Flip the sidekick open; press and hold the letter 'r' on the keypad. 3. While holding the letter 'r', place the battery back in the device. DO NOT INSERT THE SIM CARD YET. 4. The sidekick will restart itself twice. Please make sure not to let the letter 'r' go until it has fully rebooted. 5. Once it has fully rebooted, remove the battery, re-insert the SIM card and battery and power up the device. 6. Once the device has fully rebooted, all prior information should be erased from the device and it should be restored back to the default factory settings.
Feb 06, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
when my sidekick 3 turns on it shows a screen that says " SYSTEM CRASH @10007F54" can anyone help me?
Jul 05, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Stuck
turn it on but beofre pressing button to turn it on, press and hold the l button then press the on button. Once yu see a sidekick icon that looks confused on yur screen, yu may let go and it will ask to reboot. And you do so. Hopefully this works for you.
Feb 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sk3
Firmware crashed. T-mobile needs to reload the OS into your device. Its "blank" or corrupt. Only way to bring the device back is to flash it
Jan 25, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 crsashes
The same thing happened to mine, so far what i do is do the hard reboot:
take the battery out, hold down w, while still holding the w put the battery back in. then scroll to reboot.
may take a few tries....
also this is an annoying and very temporary fix...get a new phone.
Jan 22, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3
Emulating a Hard Reset
The Sidekick 3 now will commit memory-resident DataStores to flash memory when the device is powered down or rebooted normally. This greatly reduces the incidence of "hard reset" resyncing of the device which enhances user experience, however it makes it more difficult for developers to test this functionality on the device. You can simulate a hard reset on the device two ways: 1) Yank the battery out of the device without shutting it down. This will force a hard reset of the device, but it's not recommended as this can also potentially corrupt files on the miniSD card if they're being written when this happens. 2) (recommended) Follow the steps below to clear the datastores off and simulate a hard reset:
- Reboot the device by pressing @+1+0
- IMMEDIATELY press and hold the 'R' key on the keyboard. Continue to hold the 'R' key down
- The device will reboot, and when the initial boot screen (the 4 face buttons animation shows) displays, the screen will clear and the device will reboot again.
- Let go of the 'R' key at this point, and the device will reboot with no datastores, and force a resync.
Jan 20, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick 3 has big red X on screen
You can try hard reset to see if that will clear it. With the unit powered on, pull the battery out.
Jan 13, 2008 | T-Mobile Sidekick® 3 Cellular Phone
T-Mobile Sidekick® 3 Cellular Phone Logo
973 people viewed this question
Top T-Mobile Cell Phones Experts
Starnley Johnwells
Starnley Johnwells
ismael castillo
Are you a T-Mobile Cell Phone Expert? Answer questions, earn points and help others
