Question about Acer Aspire 4730-4516 Notebook
Stockup at logo when booting
When booting it stockup at logo all parts are working properly
  • sarah brooks May 11, 2010
    I think you mean locks up right? Which logo (splash screen) is it locking up on. Is it Asprie splash screen or windows?
Are u using windows xp? Press F8 while booting then choose safe mode. Maybe there's a faulty software or driver then u need to remove it. Even viruses can be the cause. If this doesn't help, try cleaning or replacing the memory module or reformat your drive. this should fix it.
Posted on Feb 08, 2010
  • 44 Answers
That probably has to do with your harddrive. Where is it locking up? Is it locking up on aspire splash screen or on windows splash screen? This is important.
  • sarah brooks Feb 08, 2010
    It may not be windows it depends on where it is locking up.
  • 50 Answers
Instaal the operating system again, this is due to the corrupted windows.
Stockup snap
if you did not transport it vertically, you need to let it sit unplugged for a couple of days so the freon setttles.
Jan 18, 2015 | Motorola Mobility SLVR L7c Snap On...
How can I fix my phone which cannot boot ?
It sounds like you have corrupt kernel files that allow the system to boot properly. if your phone just sits at the boot logo then something is corrupt. You will have to find the phones OS firmware file online, and put the phone into Disk Mode/Advanced Mode, and either find software you can access the firmware through on your computer, or you will need to take the working firmware file you find online, load it onto a micro SD card and then load the firmware onto the phone from there.
To access this mode (Disk Mode) on your phone do this:
1.Power off your phone
2.Press together volume up + home button (little house)+ power button
3.When Samsung logo appears releases your fingers from the buttons.
4. You will then see a list of options you can select, SD card boot, or SD card firmware upgrade or something along those lines.
From there you can load the proper working firmware to your phone from an SD card, or from the vendors software that can access the phone on a root level.
If the above wasn't an issue, then you may just need to charge it fully and the boot, or leave it on your charger then boot up.
Apr 27, 2014 | Samsung GT B5510 Galaxy Pro Young Qwerty...
Blank screen with only the Acer logo on
try going into the bois of the computer by tapping f10 key on startup, then arrow over to advanced, arrow down to boot sequence and make sure boot from hard disc is first, you could change sequens by hitting enter jey or space bar
Feb 05, 2013 | Acer Computers & Internet
My laptop will not load, just flashes on and off
Can you still see the logo which you usually see when it was still working just fine?
There are two process right after you pressed on the power button.
1. POST
2. BOOT
POST (shows up the computer's logo//eg. ASUS, DELL) is the first process that the computer does. It checks all hardware parts in the computer - if the hardware parts in your computer have no problem then the computer proceeds to BOOT.
BOOT happens after the POST process. This is the final booting procedure. After POST or Pre Operating System Test. The computer loads up the operating system that's why you can see the Windows logo this time.
In fxing your issue, you have to identify which causing it. You will know that by knowing if the issue happens during POST or BOOT. If you can still see the computer's logo eg. ASUS, DELL or whatever computer you have then it's not a hardware problem.
If you see the logo and you don't see the windows logo, then it's a software issue.
Please observe that and let me know which part has the issue.
Thank you very much.
Carlo
Dec 20, 2012 | Computers & Internet
How do you replace the Dell logo at the back of your lid? I want to make my own physical image (probably glowing) and put it at the back of the screen but I'm not sure if it's possible to remove the native...
The Dell logo you see at the time booting is the logo of your motherboard manufacturer. It uses the image associated with the program that helps you in booting your computer. If you want to change it, you should have proper knowledge of computer programming and IT. All you need to do is to identify the proper programs associated with the Dell logo and then hack the corresponding .exe or .dll files and replace the image with your own one in correct image format.
Hope this helps,
Mrityunjay.
Apr 03, 2011 | Dell Latitude D610 Notebook
Stop at foxconn logo canot run
Go check the connection of the hard disk, try to remove the ide or sata cable and also power supply connection then connect again and reseat properly the ide/sata cable.
Restart your computer.
If this will not work, try removing the hard disk before booting up your computer and see if this go beyond the logo. If this goes beyond logo then hard disk is faulty. May need to partition and reformat thoroughly. Or replacement.
Jan 29, 2011 | Foxconn 45CM-S Core 2 Extreme/ 945GC/ FSB...
Hi, im kind of lost with this issue. I got a new pc with a mother board intel DG31PR, it works fine at least as far as i have tested. The problem is that i dont find how to remove the intel logo on the...
All this info can be found on the computer once she's up and running. Just go to System info under "Help" section.They know you didn't need to see that sticker for the info.
Aug 25, 2009 | Intel DG31PR Motherboard
Power on emachine T6420 and moniter is blank. The moniter soon loses contact with the computer. The fan run and power is OK there is no beep code.
If you mean after the computer performs the self test the screen goes blank and stays blank, eventually turning off you are having a hard drive problem. When the computer boots you should see an E-Machines logo and/or a self test on the screen. That is done by the motherboard as part of every boot up. After that the motherboard passes control to your boot device and loads your operating system. If your computer stops booting at that point, your boot device is not working properly. That could be caused by many things - virus, hardware failure, power outage. If you really mean you see nothing at all on the screen when you press the power button your computer simply is not working at all. Open the case, blow all the dust out of it and reseat all components you can, then try again.
Jun 05, 2009 | E-Machines eMachines Desktop PC
Dell dimension E310 wont boot
Go in bios and change the SATA mode to IDE or compaitibilty then check whether it is working or not
Feb 17, 2009 | Dell Dimension E310 PC Desktop
Acer Aspire 4730-4516 Notebook Logo
87 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
