Question about IBM ThinkCentre S50 8183 - P4 3 GHz (8183D9U) PC Desktop
When i insert pendrive in my two three machines, machines get hang completly. i have tried same pen drive in other machine it works fine. I am using quick heal antivirus. please fix my problem its urgent My email id is pragthegem@gmail.com
    Guru:
  • IBM Master
  • 829 Answers
Hi.
Kindly first check if your mouse works fine with the USB port if it does not then the issue is with the USB port which can be replaced . This happens due to short in the USB port board.
Posted on Feb 08, 2010
Inserting by pen drive,pc is getting hang
hello....
Your pendrive hs virus files in it..... You have to format it first.. If you can go into my computer , right click the pen drive icon and format it... or put it in another PC and format and then use it...
Hope it will be useful
Aug 23, 2010 | Computers & Internet
Transcent 8gb pendrive formatting problem
Try the drive on different machines. If you get the same error on all machines, you'll have to format the drive to reset the File system
Aug 14, 2009 | Electronics - Others
Dell laptop gets hanged when the usb pendrive is inserted.
it could be that u have such little ram that when windows recognizes the pendrive its already busy but windows does this thing called auto play on usb devices like cameras memory card readers even flash drives just try leaning up your current windows install by removing startup programs through msconfig and just getting rid off all the spam delete your internet history thats hdd space that could be used elsewhere just stuff of that sort
Aug 10, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
AUTORUN.EXE & RECYCLE VIRUS
You need to do a low level format on the pen drive and the system drive. I have found by using programs like kill disk is the best way to get rid of a worm virus. A regurlar format will not work, unlike what they say to you. Kill disk will stop all running prorgrams on the drive. What it does it rights zero to the pen the drive. After that you need to do the same to your system drive. Otherwise you will be back to square one.
Aug 09, 2009 | Computers & Internet
System hang when i insert pen drive
solution..
1) Check The USB Port for Damaged, Bend Or Broken Pins.
2) Check The Pen Drive For Physical Damage.
3) Try The Pen Drive In another USB Port. (i.e. if u r using the pen drive in the FRONT PANEL USB PORT than try it in BACK PANEL USB PORT)
4) Try The Pen Drive In Another System.
5) Tye Another Pen Drive.
6) If All Above Is Fine Then Format The PEN DRIVE.
7) Try The PEN DRIVE now.
8) Is Issue Still Persists Then..
9) Uninstall the CHIPSET/MOTHERBOARD DRIVER COMPLETELY and then clear %temp% & prefetch files and Restart Your System.
10) Install The Latest CHIPSET/MOTHERBOARD DRIVER and ANY AVAILABLE FIRMWARE for the motherboard..
May 22, 2009 | IBM ThinkCentre S50 8183 - P4 3 GHz...
Pendrive detected but stil cant open
Try to insert it in every usb on your pc maybe its your usb port the problem!
Mar 22, 2009 | Computers & Internet
PLEASE INSERT A DISK INTO DRIVE(H): (pendrive problem)
1)I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also )I cannot format the pendrive. 2)when i double click on the removable disk,it says ''Please insert a disk into Drive E :'' 3)i used a pendrive format utility but the problem persists again. 4)i tried to format it using gnome also
Feb 13, 2009 | Sony 8GB Micro Drive (SUD8G) -24419 USB...
Pen drive is not working properly
try to replace the unit.
it is possibly faulty.
also you should note that pen disks are not as reliable as hard drives.
Jan 23, 2009 | Electronics - Others
PEN DRIVE ERROR
My 2gb hp pen drive showing please insert drive error. Also property showing free space 0 bytes. Please send me hp recovery tool or any equivalent tool to solve the same problem
Sep 26, 2007 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
