Question about Miele 24 in. G646SC Plus Free-Standing Dishwasher
Drain pump runs continuously
This started with wash programmes at end of wash cycle but a pre-wash would work fine. Pump would run for extended period then inlet/outlet light would come on.
I cleaned all filters, checked supply/drain hoses, checked the leak switch at in bottom tray and another pressure operated switch located back rh corner connected to filter sump(?) by black hose. All seemed servicable. But no real improvement in fault.
Any other switches etc I can check before reorting to the (very expensive) circuit board. Does anyone have a service manual and/or illustrated parts catalogue? or know where/how to obtain one?
Thanks in advance
  • 3 more comments
  • lotus2008 Feb 24, 2008
    I have the same problem. Mines a G640
    I have the same problem. Mine's a G640.
    I don't know where pressure switches are but mine pumps out fine but just won't stop trying to drain.
  • Bruce Wilmot Feb 24, 2008
    Hi gwshaw71
    The exact model is Type HG01 Model G646SCi Nr 22/45885686.
    Any assistance greatly appreciated.
    Sorry missed the bit about fault codes... how do I read them?
  • jesper mlb Aug 13, 2008
    I have the same problem on a Miele G647 SC Plus. Did you manage to solve this and if so what was the problem causing it to stall before the drying cycle? Thanks in advance.
  • 83 Answers
Which model do you have and is there any fault codes showing on unit? I have all of the service manuels for miele products.I am factory auth. for service on miele.
Posted on Feb 24, 2008
Zanussi zdt 6053 usually will not run full cycle (on any cycle) but stops with constant error beeps. But it is draining ok and sometimes goes full cycle (not often) Any ideas?
Could be anything!
If you suspect that there is a fault then it will be displayed by blinking LED "END OF CYCLE". As the display of failure in hexadecimal code it can flash up to max. 15 times than short pause and after that repeat fault code. You must to count the number of times the LED "END OF CYCLE" flash up.
Example from user manual: Anti-flood device is activated.
- continuous flashing of the indicator light of the running programme
- 3 intermittent audible signals
- 3 flashes of the END OF CYCLE indicator light
(which means "i30" fault code, the cycle is interrupted and the
drain pump switches on).
Possible causes:
Water leakage from the tub - sump and various connections
(pump, upper spray arm duct etc.); floating sensor blocked
mechanically; microswitch faulty; fill solenoid blocked
mechanically; circuit board faulty (solenoid triac short-circuited);
wiring faulty.
26226179-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Could be also:
To cancel a washing programme in progress:
- Open the dishwasher's door.
- Press the programme selection/cancel button for about 3 seconds,
until the indicator light of the running programme turns off and the
END OF CYCLE indicator light flashes, indicating that the running
programme has been cancelled and that the machine has
returned to setting mode. It is now possible to select another
washing programme. If a new washing programme will be
selected, check that there is detergent in the detergent dispenser.
NOTE: only during the drying phase, if the dishwasher's door will be opened and remains open for more then 30 seconds, the running programme will be automatically cancelled and the machine will return to setting mode. This will happen, always only during the drying phase, also when the machine is switched off by pressing the
On/Off button and remains switched off for more then 30 seconds.
Dado
Jun 26, 2016 | Zanussi Dishwashers
Hotpoint Ultima WF860T
Alarm
code Description of fault User
code Effect
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
Jan 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
My Zanussi WJD 1257 washer/dryer's drying cycle has started finishing early. No error codes. The wash cycle works fine but the drying cycle is simply stopping prematurely. You can set it to dry for 45...
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 01, 2013 | Zanussi Washing Machines
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
The washer floods at the end of the cycle the pump is working this i know because when i manualy lift the mushroom float it pumps out could it be that there is a membrane in the mushroom float that is...
I'm not entirely sure what you mean by "floods at the end of the cycle". Is water leaking from the washer and where from?
The mushroom float isn't a water level sensor to determine when the washer should pump out. It's a second level safety feature to prevent flooding if the washer overfills. The flow meter regulates the water level in the washer.
Your pump is obviously working and there is no blockage in the drain hose, etc as the water pumps out when you lift the mushroom float. It sounds like the pump isn't receiving a signal from the controller to pump out at the end of the wash cycle. Lifting the float bypasses the controller and runs the drain pump.
Please try the following simple test:
1. Switch the programme selector to "Off"
2. Empty a bucket of water into the bottom of the washer
3. Turn the programme selector to any wash cycle
4. Press and hold the Reset button (start/stop) for at least 3 seconds. The washer should drain.
Please try this test and let me know if the washer pumps out. Please can you also be a little more specific about how and where the washer is flooding.
Thanks,
BElectric
Mar 17, 2011 | Bosch 24 in. SGS43C12 Classixx...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
Whirlpool Roper Gets to Rinse then water runs but will not fill
The contacts for the outlet pump have fused together in the programmer so that as soon as you apply power the pump motor starts running.
Remove the power first
Quick check is to take off the back panel locate the pump and remove one of the supply leads
put some insulating tape around the end of the lead you have taken off in case it shorts out then put the power back on and try the machine, it should then fill and start to agitate .
If that works then you need a new programmer .
Turn off the power , replace the lead and then put the machine back on to drain out the water
Jun 05, 2009 | Roper RAS6233KQ Top Load Washer
Miele 24 in. G646SC Plus Free-Standing Dishwasher Logo
817 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
