Question about Astar Trent PD-3070
Battery don´t work
Li-ion Battery charger don´t Work
Try finding thomsom dth 614 battery, is the same battery and the same dvd player one of this is a replic
Posted on Jul 31, 2009
    Genius:
  • 1,019 Answers
Replace the charger.
these are usually factory sealed units, and even if you can get the replacement components. probably not worth repairing.
You can purchase a universal charger, with variable voltage. usually between 19-24 Volts variable. ( On E-Bay )
Have you checked the fuse in the Plug?
if you have a multimeter, test that the charger is giving an output to the specified voltage. if it is then you have a motherboard fault, or charging board fault in the laptop itself.
Mike @ Compurepair.
Posted on Feb 22, 2008
    Problem Solver:
  • 9 Answers
Try to replace new battery charger.
Can I buy a battery charger for a ozito drill
yes
Search Results
Ozito Power X Change 18V Eco Battery Charger Tool ' Bunnings ...
https://www.bunnings.com.au > ... > Cordless Accessories > Batteries & Chargers The Ozito PXCG-120 18V Eco Charger can be used to charge any of the Power X Change battery packs and includes a charge indication. The Power X Change Eco Charger is a compact and portable design. Charge Time: 1.5Ah Battery - 2.0hours 2.0Ah Battery - 2.5hours 3.0Ah Battery - 4.0hours 4.0Ah Battery - 5.0hours
Batteries & Chargers available from Bunnings Warehouse
https://www.bunnings.com.au/our-range/tools/power-tools/.../batteries-chargers Compare. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. Ryobi One+ 14.4 - 18V Dual Chemistry Car Battery Charger. 79. Compare. Ryobi One+ 18V 1.5Ah Lithium+ Battery. Ryobi One+ 18V 1.5Ah Lithium+ Battery. 69. Compare. Bosch Blue 18V 3.0Ah Li-Ion Battery. Bosch Blue 18V 3.0Ah Li-Ion Battery. 119.‎Ozito Power X Change 18V ... · ‎Ozito Power X Change 18V Li ...
Dec 02, 2017 | Drills
DC B101 charger. Why doesn't it charge?
May be It can mean your LI ION battery is out of range by the deep discharged protection. !!! your charger is not defect and your battery also not in 80% of this cases you are certainly not the only one with this problem . i think your battery was or is new or for a long time not used have i right ? or it was long lay down in the stockroom by the store before it was selling as i know from experience it by the brand Hitachi its fast much allways going that way. in priority the little 10 volt batteries made of li-ion can have on stock for 5 years its out of range , but i send it back and for service they come back full loaded again and full of capacity. its fully under service and they know that problem, there are no costs as all people with Li Ion tools to sell should know this or asked by purchase by some companies to load it full before buying a new tool with li-ion batteries because it prevents a disappointment and a drive to the shop again.
Note to control it that way 80 % in case of this the charger is not defect ask someone or your dealer or friends to test that charger with a new or other functional or regular used Dewalt fitting li ion battery , then you know for shure that its realy not defect, but your battery can be boosted with a special cadex charger if its was little used but i have made in experienced an discovery (but only on Dewalt li ion batteries..because there are only 3 poles on Dewalt accu s to find its missing that special grooved protection circuits with multiple contacts inside on the li ion batteries as to find by all other regulary brands too find) used a simply auto charger 12 volts 4 amp placed + and - corresponding the pins + and - and for 20 seconds because its li-ion (always by unknown experiments wear safety glasses) under the load and repeat that 3 times on a 14,4 volt li ion battery and after i switched that battery fast after that short boost again in the original loader and if the lamp on the charger was again been continues red thats mean it was reborn new and accept its loading again in the official dewalt loader and it was be accepted from that time again without repeating the same problem after fully loading it again. its made me happy but only by Dewalt was this experiment functional simply + on + and - on -
Beware do not this on other brands like Panasonic Makita Hitachi or other Brands milwaukee to do this li ion action because its has no cure wasting not your time and do not experiment full on the separate cells it can made great explosions without electronic technical impossible because of complex protections that are marketing technical made ONLY by special CADEX chargers are used for it to boost it so it will be again fully functional again .
Li ION is not comparable with Nickel Cadmium or nickel metal hydride, the first must be trained for capacity and the second not but do not load nickel metal hydride batteries in the freezing cold most outside or in cellars the lasting life of that batteries is very short after that . the capaciti will loose and is not coming back and is very bad to boost., Nickel Cadmium is heavy and great instead of Nickel MH . and material is expensiver the only good improvement of NI MH is the weight and the building material, and no capacity memory if its used under normal temperatures. above 0 degrees .
Li-ION hold them as much on the charger change both fast after use will long last the life of the battery.
Oct 13, 2015 | Dewalt Drills
Battery charging
Only the Li-Ion batteries designed to work with the radio can be charged inside the radio. If you have Li-Ion rechargeable batteries such as those you can buy along side the
Alkalines in a store, the answer is no. This type would need to be charged in the style of charger made for recharging this brand/type of battery
Jan 25, 2014 | Motorola Walkie Talkies 2-Way Radio
Can you use 18v lithium battery in old 18v drill
Yes you can. On tools, 18 volts is 18 volts. Tools don't 'know' how the power is being created, either by Ni-Cad or Li-Ion means. Chargers are totally different. Most Li-Ion chargers can charge older Ni-Cad and some Ni-MH batteries but older Ni-Cad chargers will charge Li-Ion battery untill they overheat and sometimes start on fire because older chargers can't detect when the Li-Ion batteries are full.
Jan 14, 2013 | Black & Decker 18V Cordless Drill/Driver
I bought 2 P103 lithium batteries and they will not take a charge from my one + (p110) charger. I was informed that these components are all interchangeable. Will the P103s work with the blue 18v ryobi...
That is true the One+ 18V Li-Ion battery packs will work in any One+ 18V Ryobi tool. However the Lithium ion batteries will not charge in the original P110 NiCd charger. You will need one of the the new series Ryobi One+ 18V "dual chemistry" chargers for that. The will charge both types of battery packs.
Feb 18, 2011 | Ryobi Two 18V Lithium-Ion Batteries +...
Have 24v sds drill older type the one with the charging lights on 2 of the batteries will no longer charge just go to red on charger unit can they fixed
not sure on the charge well have to check out but contact a interstate battery shop thy can rebuild most batteries
Oct 12, 2009 | Bosch Drills
Sony DCR-VX1000E batteries
Li-Ion batteries cannot be charged efficiently with power supplies or NiCad chargers, they need a pulse charger dedicated to Li-Ion batteries. Also, there is a danger in charging with other sources as Li-Ion batts. will catch fire or explode if not charged properly. Please get a charger that is made for those batteries
Jun 19, 2008 | Sony Handycam CCD-TRV37 Camcorder
Charger for Li-ion battery
Ebay you can get one really cheap there just do a search for your model number.
Apr 07, 2008 | Olympus FE-230 Digital Camera
Is the battery that comes with the camera rechargeable?
Yes, the battery that comes with the C-7000 can be recharged. This battery is the Olympus LI-12B Lithium Ion battery and it can be recharged using the LI-10C battery charger. Both the battery and charger are included with the camera.
Sep 04, 2005 | Olympus C-7000 Zoom Digital Camera
Astar Trent PD-3070 Logo
169 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
