Question about Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor
Monitor power problem
My dell monitor 1707 fpt turn on and stay on for 10 seconds and then goes blank and green ligth stay on. how can i fixit?
    Guru:
  • Dell Master
  • 829 Answers
Hi ,
Kindly check when the display cable is removed from the system and monitor powered on do you get any "Out of Sync Error". Then the monitor is fine and issue with the system or Display card. Check if your system boots and also unscrew the system and clean the Display card and re-insert. If its an on board card then just do a preventive maintenance of your system as it can happen due to loose connections also.
Regards.
Posted on Feb 08, 2010
Monitor 1707fpt
I would suggest you try this to fix your problem. Go to Control Panel from the start menu if you are using Windows 7 and Windows Vista. Click on the Display Setting and adjust the screen resolution to the recommended Screen resolution. On the Display Setting at the top of the you should see number 1 and 2 with a large box ,on the right side of these boxes there is a menu that you can click on, these menu are {Detect and Identify} click on Detect first and then Identify. I hope this solves your problem.
Jan 05, 2014 | Dell Computers & Internet
Dell 1707FPt monitor doesn't display
Make sure you have the plug in tight or maybe your need a new monitor
Jan 13, 2010 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Dell E173FPc monitor worked fine yesterday. Today, the monitor only stays on for a split second and goes blank. The power light stays green. If we shut off the monitor using the power button and wait 10 to...
The power supply in the unit has died. This is a very common problem with this series of monitor after 2-3 years of use. If you can solder then you should be able to do the repair yourself. Check out our step by step repair guide posted on our site at: www.ccl-la.com Our guide gives parts values and location information as well as how to open the unit up. If you don't feel like doing the repair we also offer repair services, see our web site for details.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 31, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell 1704 FPt lcd monitor power button blinking green, no screen.
the only thing you can do, is to get a qualified service technician if you are not an electronic expert. because the problem is in your power supply and inverter board. due to heat pressure inside can damage components specially capacitors.
Aug 15, 2009 | Dell 1704FP LCD Monitor
Monitor will not stay on
HOw about the light on the tower? if its stedy green then the tower is ok then run a self test on monitor if it passes the monitor is also ok then unplug the power cable from the monitor and data cable also and press and hold the power button for 10 sec and then connect the monitor to the system
Jul 02, 2009 | Computers & Internet
Screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
May 23, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Jan 08, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Monitor Goes Blank after 30 mins....
http://www.electronicrepairguide.com/dell-e173fpb-lcd-monitor-repair.html
Dec 12, 2006 | Dell E173FPb 17" TFT LCD Monitor
Dell UltraSharp 1800FP 18.1" LCD Flat Panel Monitor Logo
237 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
