Question about Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher
Have a GU1500XTK whirpool,took apart and in the small round hole in the sump i found a small black round soild rubber disk,i dont know where it came from or where it goes..diagram only shows the other black flap.
  • 572 Answers
Its the check valve. it goes in a rectegular with the round edge first. its near the hole going to the pump
Posted on Feb 08, 2010
SUMP PLUG REMOVAL
Hi there
Well there is a few ways to remove a rounded sump plug and the best way will be to either drill a center hole [small] then let it drain out the oil, then drill out with a bigger one and use a easy out to un do it [ but when its out put some of the old oil back in to wash out any swarf ] replace new plug with new gasket washer but dont over tighten when replacing .
THE other way is to tap it with a screwdriver and hammer but only lightly and on the plug only. and do it after a run so the oil and sump plug are hot.
Mar 11, 2014 | 1993 Isuzu Amigo
Opening the PL-Z81 box after standing packaged for quite some time -I saw that the turntable had come apart and that there were four pieces - a silver dish (the turn table) --the rubber mat that sits on...
Ok! On the main part of the turntable should be a spindle, not the one in the middle! That if you put your finger on will turn. This is the motor. On the underside of the silver dish should be a flange. Place the belt round it and put the platter on the center spindle (the one in the middle). If the platter has a hole in it, grab the belt and pull it, while rotating the platter till you can see the motor spindle. Attach the belt to that. Put the rubber matt on and try it out.
The black piece is for 45's with big holes in them (jukebox ones).
PS if the platter hasn't a hole you will have to put the belt on the motor spindle first and then around the flange (try not to pull the belt to much).
Also some turntables pass the belt via a leaver that lifts the belt up and down for 45 and 33 speeds, others just change the motor speed.
Aug 23, 2010 | Audio Players & Recorders
Faucet is leaking .. i dont know how take it apart .. how do i take it apart???
Turn off the water,remove the little cap on the handle,it is a little hole in the front.use a delta allen key to loose the handle.Remove the retaining nut on top of the valve body.lift up the little (take notice how it is positioned,cause there is a small notch on the side to help you align it propertly)last remove the black rubber washer and the springs,Buy a complete repair kit ,not just the washers and springs.
Apr 13, 2010 | Delta Model 441: Signature Single Handle...
My VW GTI has an interior water leak. Can't find it, but the rear passenger side is full of water?
Two areas to check. The sunroof has several drains that can clog. Open the sunroof and look in the four corners. You will see small holes. Try flushing water down each one with like a cooking baster or spray bottle. If that won't clear a clog use a long wire but with a rounded end. You could cut rubber parts if the end was sharp. The second area is in the door panel area. Each door should have drains in the bottom. If they are clogged it will overflow into the interior. Also if that door has been serviced and the moisture barrier was not reinstalled correctly you will get some water leaking inside.
Feb 08, 2010 | 2003 Volkswagen GTI
Whirlpool Ultimate Care II drum does not spin.
Depending on your washing machine model, the drum and motor are connected by 2 plastice yellow circular pieces, with a black rubber washer in the middle with holes where the pegs or rods go into. The 2 plastic circular pieces have 3 pegs or rods if you will, that connect to the black rubber washer via 3 holes. Sometimes, one or both of the 2 plastic circular piece pegs get broken off or the rubber washer cracks and breaks apart, so that the motor will not turn the drum. If thats the case, you can purchase the 2 circular pieces and black washer piece as a set.
Jan 05, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Oil change
To drain the oil - all you have to do is remove the small (about 4" x 5") plastic rectangular cover which is situated towards the rear of the "plastic tray". It is secured by one hex head screw (about 8mm I think). This reveals the sump plug (hex head 17mm) on the side of the sump. Make sure you have a good big drip tray underneath as, due to the sump plug facing sideways, when the oil first runs out it shoots way over towards the side of the car. I found this to my cost the first time as I had positioned a container underneath the sump drain hole and the oil shot horizontally over the top of it and poured all over my driveway. Re the second half of your question, sorry - I dont know anything about the oil level sensor.
Nov 25, 2008 | 1999 BMW 318 ti
Broken O ring on fuel ports
Check with dealer incase part not available separately. Might have to purchase whole assembly or obtain from wrecker.
Oct 04, 2008 | 2006 Toyota Corolla
Primer button bowl brass bolt and plastic.
what is plastic ? all there should be is a bowl , then small round gasket , then brass nut . if it doesnt go on you must have disturbed the bowl gasket ( black round )
Sep 19, 2008 | Garden
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Whirlpool 24 in. GU1500XT - Multiple Color Built-in Dishwasher Logo
105 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
