I record my VHS tape, onto my SDHC card I play it back on my computer, but only get audio.
    Guru:
  • 829 Answers
Its because Windows Media Player Codecs are missing which you can get by downloading. You can try with VLC media player which is free.
Regards.
Posted on Feb 08, 2010
Testimonial: "Thank you for your help, VLC worked great"
Can I transfer video tapes onto CD's
A lot depends on what type of video tape you use and where do you want to play the DVDs (CDs are for audio recording only). If tape is compact VHS then you can buy a simple DVD Recorder VHS VCR combo player and transfer across easily provided you have the compact VHS cassette module.
http://www.gumtree.com.au/s-ad/reservoir/tv-dvd-players/lg-v271-vcr-dvd-player-combo-recorder-6-head-hi-fi-stereo/1073556241
For other type of video camera tapes you will have to try other methods like connect camera with tape to a DVD recorder and directly burn the DVDs. You can buy attachments and software for PC but I have found these very cumbersome to work with.
Mar 16, 2015 | Video Cameras
How to convert VCR to DVD
no easy way to do this unfortunately. You either need to connect your VCR to a DVD recorder and record it directly onto DVD or use a device such as this http://www.dx.com/p/easycap-usb-video-capture-adapter-5707 to connect your VCR to your computer and record it onto your computer that way.
Feb 23, 2015 | Zenith XBR616
How do I get vhs video onto my computer?
You need a TV capture card... the package includes connectors for VHS & other DV cameras, you also need of course a VHS player..
While the VHS player is playing your VHS tape... the computer can now record it via the TV capture card.
That's what I do... goodluck and don't forget to rate...
Feb 01, 2011 | KWorld DVD MAKER USB 2.0 (660448660114)
VHS to DVD: audio and visual dont match on playback
Hi, this is a problem with cramming too much info onto dvd.
For a good quality dvd, it needs to have about 1.5 to 2 hours of video on it. The more you put it the lower the quality it becomes. Don't forget though , it will never be better than the original.unless you have some specialist software to tidy up sound and flickers in the video.
So I would stick with one tape to one dvd if you want to keep the quality.
DVD's are cheap anyway, you can buy a spindle of 50 Verbatims for £10.
I hope this has helped you understand a little better, but if you need more assistance, then please ask.
Regards - Anthony
Feb 11, 2010 | Samsung DVD-VR375 DVD Recorder/VCR
Dubbing from VCR to DVD
Dont use xp mode. Here are the definitions:
SP is short for Standard Play. Standard play allows you to record information onto the tape the way it was intended, with no quality loss. By default, VCRs and camcorders will record your footage as standard play. On a standard VHS tape, recording footage in SP mode will yield 2 hours of video.
LP is short for Long Play. Long play allows you to record much more information at the expense of quality. It accomplishes this by reducing the speed the tape is run through the VCR. As the tape speed decreases, the quality will also decrease. You’ll notice this effect when comparing a tape recorded at LP versus one recorded at SP, especially after years of storage. The LP tape will appear more blurred, have more tracking and color issues than tapes recorded at SP. A VHS tape recorded at LP can hold roughly 4 hours of video.
EP/SLP is short for extended play. Extended play is similar to LP, but actually provides you even more recording time. EP was primarily used to document long, continuous events without the need to change video tapes every 2 hours. Due to the fact that the video is not of optimal quality, many times this setting was not used in order to preserve the quality of your footage. Tapes recorded at EP usually are the most problematic after years of storage, displaying a wide variety of tape damage symptoms including color loss, audio loss, frame skipping, and tracking issues.
Sep 02, 2017 | LG LH-C6235 System
Vhs tapes recorded to DVD+R's
try forwarding the tape to the end and then rewind to the start again, this can help to seat the tape correctly on the spindle . the audio track part of the tape is in a specific region on the tape so misalignment may be the issue with those cassettes.
also try to press the tracking up and down when playing the video
May 12, 2017 | Televison & Video
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
Recording from one vhs recorder to another.
If your plan is to copy a VHS movie to a blank VHS tape, the connections would require a 3 wire RCA connector/cable. The unit where the original movie will be played will be the player. Connect the yellow video RCA cable to the VIDEO OUT, the red & white to the AUDIO L/R OUT. On the 2nd unit designated as recorder, slip in the blank VHS tape. Connect the other end of the RCA 3 wire cable to yellow VIDEO IN, the red & white to the AUDIO L/R IN. Connect the RF OUT of the 2nd unit (recorder to the ANT IN of a TV set. Set the TV to either Channel 3 or 4 as the case may be.
If the recorder has a manual selector or via remote, pls verify that it is set to Video and not tuner (or channels) input.
Press Record on the recorder (2nd unit), press play on the 1st unit (player). The TV will serve as monitor to your copying progress.
Hope that this be of some help/idea. Pls post back how things turned out or shoould you need additional information.
Good luck and kind regards.
Nov 11, 2007 | Televison & Video
Adapter question
There are no such adapters that would allow 8mm, Hi8 and Mini DV tapes to be played in a VHS VCR. Only the old VHS-C tapes can fit and play in an adapter. There are several reasons why 8mm (or Hi8 and miniDV tapes) cannot be physically played in a VHS VCR: 1. 8mm (Hi8, miniDV) is a different format with different technical characteristics than VHS. These formats were never developed with the intention to be mechanically compatible with current VHS technology. 2. 8mm/Hi8 tapes are 8mm wide (miniDV is 6mm wide), while VHS tape is 1/2" wide, making it impossible for a VHS video head to read the taped information correctly. 3. 8mm/Hi8/miniDV tapes are recorded and played at different speeds than VHS, so even if the tapes could physically fit into a standard VHS VCR, the VCR still couldn't play back the tapes at their correct speeds. 4. 8mm/Hi8/minDV audio is recorded differently than VHS. 8mm/Hi8 audio is recorded in AFM HiFi mode, while miniDV audio is recording in 12-Bit or 16-Bit PCM digital audio format. So, even if the video could be played back in a VHS VCR, the audio could not be read properly. 5. 8mm/Hi8 video is of higher resolution than VHS and is recorded in a different bandwidth length (miniDV video is recorded digitally), so once again, a standard VCR still could not read the information correctly, even if the tape could fit into a VCR.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
Electro Med Services...
