ECS Green320 laptop , dead , no beep sounds good adapter. 19 volts reach mother board, the green light for AC indicator lights on but shut off when I press the Main Power switch.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 132 Answers
Remove battery , attach ac power , turn on , if the laptop still has problems you've at least ruled out battery fault , sounds like faulty hardware somewhere alright but where??
Posted on Feb 08, 2010
P 4M800PRO-M V1.0A ECS mother board does not beep ,it gives click sound . but some time it start and run good condition .and next restart ,mother broad doesn't start
Sounds like that board is on its way out. Had a good run too!
I'd seek out a complete system upgrade.
Small things you could try is reseating the RAM and testing it with a new power supply.
Hope this helps!
Sep 16, 2014 | Computers & Internet
Toshiba satellite L305-s5955 will not power up
If there is no power light and it can't charge your laptop, it is likely that the charger is dead. You need a new laptop charger. So try a new adapter to confirm the real issue.
There are two kinds of ac adapters for your toshiba l305-s5955
Toshiba Satellite L305 AC Adapter 75Watt 19V 3.95A
Toshiba Satellite L305 AC Adapter 90Watt 19V 4.74A
You should choose the right charger depending on your original adapter's specification. If the original one need 90w, you won't buy 75w that will bring damage to your laptop. If it needs 75w you can use 90w too.
Oct 14, 2012 | Toshiba Satellite L305-S5955, L305-S5956,...
The AC power indicator light does not torn on when the adapter is plugged. The adapter was tested and it puts out 19 volts. At first the prolem was intermittant, but now it is not working. The battery...
The AC adapter have two measure:
Output volt: 19 volts
Amp:
the Volt output can be tested and show 19V, but can`t leave the correct Amper.
I see these failure in anothers AC adapter. I measure the Volt and show 12 V, but don`t work the survellaince camera. I recommedn replace the adapter
Sep 14, 2011 | Computers & Internet
Power adapter is good, but Gatway MX6025 will not power on. It does power on briefly with battery installed. I've tested the ac adapter with a multimeter and it appears to be good. Green light on,...
Try to check with another adapter if possible.
The connector of the laptop might be damaged. so the battery is not charging and also not staring laptop on AC power. Check the ac connector of laptop.
Jun 08, 2011 | Gateway MX6025 Notebook
I have a Dell Latitude D610. The battery was dead (got the 4 blinking amber lights and the green light flashing once, then cycling), so I replaced the battery. The new battery has the lights on the bottom...
From the description, sounds like you have two failures, both concerning the mother board.
1. The connection to the motherboard for the battery is no longer good. Replace the mother board. The points of failure that you have given so far and has not fixed the issue. Battery fully charged, seated well, no change, mother board.
2. Laptop will come on with AC adapter attached but will not boot up; mother board. There is a built in test that you can run, from a powered down state press FN + Power button, this puts this into a diagnostic state. If it does not go into this diagnostic; mother board. The diagnostic is stored in the BIOS, which is a part of the mother board.
3. If the diagnostic runs note any error codes that it gives. They will be in the form off XXXX-XXXX or XXXX:XXXX, where the X's represent a letter or a number. These can be used for further trouble shooting.
Jul 24, 2010 | Dell Latitude D610 Notebook
I have no led light on my e1705 when i press it and nothing comes on
Things to check:
1. AC adapter cord, esp close to the brick. Does the green light come on the brick? If not, replace the adapter.
2. Reseat battery. Check the battery charge by depressing the battery indicator button on the battery. Does it have a good charge? If so, then it could be the connection to the mother board causing the issue. If not, then replace the battery.
3. If both the battery is good and the AC adapter is good then you are looking at a mother board issue.
May 21, 2010 | Dell Inspiron E1705 Notebook
Why won't it turn on?
Sounds like you need a new battery. When they go dead you will still see the green light but it will not turn on or only on for a second.
Sep 03, 2009 | Schiller Cardiovit At 2 Light Ecg Machine
Powerpack finr but laptop dead
how do you determine power is reaching motherboard ?if it is not turning on chk if u could hear any fan spinning if yes then ac adapter is working remove the battery and unplug the ac adapter and hold the power button for 10 sec and reconnect the ac adapter and turn on the laptop if not then remove the memory and turn on the laptop if u hear beeps then the mother board is fine
Aug 13, 2009 | Sony VAIO PCG-K35 Notebook
Laptop won't power up dies in the middle of movie-won't power up
You would probably be better off buying a new notebook. Not sure how tecnologically advanced you are but it seems you already did the troubleshooting yourself. But i am very interested in the a/c adaptor output. If the led on the adaptor is green that just means that it is getting power from the wall.
What did you mean by fluid leaking out?
It could be the mobo (motherboard) or it could be the connections from the power to the machine. If you want to put a new mobo in I have to warn you that taking apart a laptop is VERY difficult and I do not recommend this unless you are a PRO. This is just about the only link i can find to buy a new board. If you google your laptop model you will find out you definately are not alone with this problem
http://www.notebooksolutions.ca/zc/index.php?main_page=product_info&products_id=1183
Please don't forget to rate my response and let me know if there is anything else I can help you with.
Jan 08, 2009 | Computers & Internet
Dell inspiron b130
check if the ac adapter or charger has a green light on it. if not, replace the charger. for dell chargers, it should have a green light to indicate that the charger is getting power from the wall outlet. if the ac adapter is good, then you might need to replace the mother board as the ac port is integrated.
hope this resolves your problem.
Nov 12, 2007 | Dell INSPIRON 6000 CENTRINO...
Computers & Internet Logo
344 people viewed this question
David Payne
David Payne
