Question about Sony NetMD Walkman MZ-NF810 Player/Recorder
Will not open/ operating manual?
Hi.
My disc drawer will not open when I push "open." what could be the problem?
Can I get a new instruction manual somehow?
Thanks
wboyle1@comcast.net
    Genius:
  • 1,019 Answers
if you have,nt got a disk jammed in it.
It could be a boken eject/open switch-Button-mechanism.
some are mechanically operated, some electrical.
Make sure you have fully charged batteries And Or A/C adaptor plugged In.
Mike @ Compurepair.
Posted on Feb 22, 2008
Dvd door will not open or close when eject/open button is pushed. I can open door and slide tray out by hand, howevery when disc is inserted in tray and pushed back in, system does not read disc as being...
The low humming sound is the motor that opens and closes the drawer. It is moving, but the movement is not being transferred to the door by a pulley, a belt or a gear, When you open the drawer completely, it should stop. When the drawer is closed completely it continues to run until the disc is in the proper position to play. As long as that motor is running the DVD will not work because the disc is not in the proper position,
Feb 03, 2018 | Panasonic PV-D734S DVD Player/VCR
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Hello, my Panasonic SA-HT70 has a problem with the DVD tray. The drawer opens and closes on its own and then it just says ERROR. There is no way to eject, play or change discs, I have tried all the...
This sounds like the timing for the drawer has beed knocked out of alignment...usually when someone pushes door in instead of pressing eject buttton...you can take top off to remove the discs...the timing can be realigned( assuming there are no broken parts). The best way to re-align the timing is top obtain the service manual. Here, it will give you detailed instructions on what marks to line up....you may be able to get a service manual from UED.net...They are a panasonic parts dist.
Jan 04, 2011 | Panasonic Home Theater System System
Sony cdp 350 compact disc player will not spin to read disc once drawer if closed, it will buzz a little then drawer will open. If disc is in player and using a screw driver on bottom to manually open and...
There's never been a better time to switch to Juniper. Right now, you can reap the rewards of being a part of the new network - in just a few days. Juniper EX Series switches are standards based, so implementing them with your existing network is easy and seamless. And the benefits are huge. At least a 30% reduction in capital expenditures. Increased efficiency. Less energy consumed. And a network that's easier to maintain and operate.
We'll work with you to find the most cost-effective solution for your specific needs. In return, you'll get a fully automated solution that readies your network for anything that lies ahead. You'll get your new switches in a couple of days - not in 6-8 weeks. And we'll be ready to provide any support you and your employees might need. Your network will be more streamlined, more efficient, and more cost-effective.
Dec 01, 2010 | Sony Audio Players & Recorders
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
The radio with a 6 disc changer stock wont eject cds in my 2001 ford windstar van with double sliding auto open/close doors
Hi
Thanks for using FixYa. Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open and remove the CD.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Oct 04, 2009 | 2001 Ford Windstar
The drawer in the tower for discs will not open I can hear the motor trying to open it but it seems stuck in
Unfortunately, the clutches are very unreliable in optical drives.
Check for a very small hole above or below the drawer. If you find one, take a standard paper clip, straighten it, push it into the hole. It may take several tries to find the manual release but there will be one if there is a hole at all. It may also take a firm push to release the drawer.
I am well-versed in repair of many things but have not had enough interest to see if the drawer clutch can be improved as I have two that are reluctant at best to open and seem to be only willing after several pushes of the eject button.   The things are cheap enough today that it probably isn't worth the effort to see if they can be restored to reliable operation. If someone else has doen this; give us some feedback as to whether this is worthwhile or not.
Feb 18, 2009 | Acer Aspire™ T180 PC Desktop
DMR-E50 won't eject disc.
Nope sorry no quicky fix here
Sep 19, 2006 | Panasonic DMR-E50 DVD Recorder
Sony NetMD Walkman MZ-NF810 Player/Recorder Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
