Question about Caroma 270W-RF Reflection Round Front Dual Flush Toilet - White
Whenever next door neighbours turn their taps on or flush their toilets we can hear loud noises. Can this be fixed?
  • 5,603 Answers
If it is the same building, it is NOT likely the problem of the sound can easily be fixed. The sound will telegraph through the structure.
Posted on Feb 08, 2010
Toilet stools whistle after flushing
This could be caused by the sound of water jetting into the water tank. Just open the tap to the water tank slightly more until the whistling stops. The flusher valve in the tank may be leaking, causing the water jet to open again and the whistling noise.
Apr 26, 2016 | Home
Loud squealing noise from water softener when toilet flushed
The unit may be in a regeneration cycle during the day. Reset to proper time of day.
It also sounds like you may need an air arestor installed on the plumbing in the house. When air becomes trapped in the plumbing lines it can cause the plumbing to "hammer" during periods of heavy usage. You would need to contact a plumber for proper placement of this device on your plumbing system.
RJ
Nov 28, 2013 | Valumax 5600SXT 30k Water Softner
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
Aug 25, 2012 | Kohler Santa Rosa K-3323-55 Innocent Blush...
I have a saniflow for toilet and when flushed it makes a whirring noise and gradually goes to a loud crunching noise at this point i turn power supply off when turned back on its ok till next flush !p
find water pressure regulator. it will have a bolt coming out of the top with a nut at the base of it.loosen nut. while toilet is being flushed, adjust bolt till noise stops. turn bolt clockwise to adjust.
Dec 17, 2011 | Taylor Home
I can hear a dripping of water but the washer is fine. The water tap is turned down low, I'm a female and not familiar with the makings of a toilet cistern how does the centre flushing mechanism come out....
Anytime that you have water dripping between flush cycles, it is caused by water leaking through the flush valve. Without being able to look at it I would recommend placing the entire flush valve assembly (flush ball/plunger and the valve seat (washer). The part is not expensive, although the labor may be. You could replace the flush ball or plunger (whichever type it is) yourself and that may correct the problem.
Nov 26, 2010 | Toto Aquia II Dual Flush Toilet
Toilet drains to a certain level every half hour then refills with a sqeaky noise,when flused it makes a very loud sqeaky noise.
May need to replace toilet flapper or entire flush valve. water is getting from the tank into the toilet which is causing this to happen.
Aug 31, 2010 | Toto Aquia II Dual Flush Toilet
We just installed a new one piece toilet from Neptune. It makes a loud noise when you flush it and after the water fills up. In addition, if you flush another toilet or turn on the washing machine it also...
Hello. I doubt that the installer would not install it properly. That said, the issue you are having makes me wonder if your bath drain plumbing is properly vented to the outdoors through the roof. Joe
May 07, 2010 | Neptune FB1602 Roma Elongated Front Toilet
The toilet makes a very loud, high pitched noise when flushed.
I recently had the same problem. to let you know I replaced the filler and the flapper to NO avail. I tried flushing with the water OFF and it still did it thought it was in the siphon so I removed the water going in there and it still made the sound. This AM it got to me so I was determined to be rid of the WHINE It only happens when the TOP is on that is when it hit me is the seal so great that the vacuum creates the whine I put the little rubber door stops, the one you use in door jams, on the four side and tada no more sound Hope this helps
Dec 26, 2009 | Toto Drake ADA Compliant Toilet with...
My saniflo toilet wont flush
I think a small plastic item has dropped into my saniflo toilet it keeps maing a loud noise evey few minutes. hat should I do
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Caroma 270W-RF  Reflection Round Front Dual Flush Toilet - White Logo
139 people viewed this question
Top Caroma Home Experts
john h
Ngoro
Ngoro
Are you a Caroma Home Expert? Answer questions, earn points and help others
