The fuse for the headlights run both sides but I have ran into this before working on Fords and sometimes the hardshell connector (wiring harness) that plugs into the headlight bulb gets to hot or has had a bad connection and it melts the inside of this connector. This could be the reason for it not working properly. Also remember that when replaceing these halogen sealed bulbs you can not touch them with your hand while installing them as the oil from your skin will make the bulb blow when turned on. This may be things you already know or have tried, just thought I would give you a starting point that is not to bad to check out. Good luck, Roger
ITS PROBLY THE WIRES IM SURE ANY AUTO STORE WOULD BE ABLE TO HELP
