Question about Pioneer SX-205 Receiver
It gives an overload message regardless of what l have turned on
  • 757 Answers
Check that the speaker wires are securely connected to the binding posts, and if you are using bare strand wire on them that there are no loose strands that can touch the chassis or other terminals or other wires.
Also check that your speakers are of a compatible Ohm rating for the unit. If you have any equalizer, tone controls or "bass boost" effects enabled, turn those off. They all require more amplifier power, thus possible overload can result.
Posted on Feb 08, 2010
Pioneer amplifier vsx-d512 overload message
This indicates the audio output stage in the receiver is loading down and triggering the overload protection circuit to kick in. Check the speaker wires for shorts, if okay! you will need a professional to assess the cost for repair.
Mar 31, 2012 | Pioneer Audio Players & Recorders
My Pioneer vsx-d308 keeps giving me an "overload" message and will not work
Do you guys know how to turn up front speakers on this amp????
Sep 02, 2010 | Pioneer VSX-D308 Receiver
Turn on, in a few seconds Flashing "OVERLOAD"
Overload  usually only appears if you have been using higher volumes for a period of time and this trips to protect your speakers and amplifier. Turning off your amplifier and leaving for a while and it automatically resets. other wise a would check your speaker cabling to see if any wires are  touching shorting out the circuit. Try removing you cables from your amp then turn on. If it turns on without Overload appearing the problem is between amp and speakers. Check your cables at both ends and while at it give them a clean then hook up everything ( Amp should be off) then turn on the amp and see if you get message. If you still get this message you could have  dry/ broken soldering on the inside and the amp is detecting a dc short in the system. This seem to a common thing these days. In which it will be a repair job.  Low impedance speakers or speakers that have a wide impedance swing when they are running at high volume can cause a amp to trip if it hasn't got enough current to drive low impedance speakers. Hope this has been of help.
Nov 17, 2009 | Pioneer VSX-455 Receiver
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
Overload message in technics model SA- EX400P-K I have an older Technics system. It has worked great for years but now I get overload whenever I turn it on. Have changed speaker wires but no use. Any...
The overload message is the old version of "protect" mode. This means that a problem has been detected in the output amp section and that section is shutdown to prevent further damage. Your unit uses amp-pacs. One or more are bad. These are marked RSN3305P and cost about $66 each.
Dan
Jul 15, 2008 | Audio Players & Recorders
Overload on Technics SA DA10
Cracked solder joints due to excessive heat cycling. Do not place in a shelf system. Top MUST be open for 1 ft. or better for proper convective cooling effect. Mine suffered same fate but repaired locally.
Feb 23, 2008 | Technics SA-DA10 Receiver
Pioneer SX-205 Receiver Logo
125 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
