Question about ASUS P5SD2-X Motherboard
MACHINE_ CHECK_EXCEPTION EROR.. MEMORY DUMB TO DISK BLUESCREEN ERROR.. HOW TO FIX DIS PROBLEM?
    Guru:
  • 1,481 Answers
Need to format ur HD
u may lose all imp data on C: unless u have saved your data in another drive(D:, E: etc) other than C....get all details from my site FormatDisk page
www.sureshayyar.110mb.com
pls leave a feedback if u were able to fix it...
Posted on Feb 08, 2010
Bluescreen death
- Disconnect incompatible hardware
- Check and repair disk errors
- Perform System Clean-Up
- Fix Windows hidden errors with Reginout.
- Scan for Malicious Content
- Run System File Check Up
After performing these steps your problem will solved. Thanks
Feb 26, 2014 | Microsoft Windows XP Home Edition
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
Apr 15, 2013 | Kyocera Taskalfa 250ci Color Copier...
I have a Creative Live ! Optia AF Webcam. If i put the USB of the Webcam in the USB-Slot (1 of 4 USB-Slots and all tested), i get a Bluescreen Error and my Computer shuts down. Is my Webcam destroyed? The...
A bluescreen error is rarely a good sign, but sometimes it's fixable. Have you tried plugging the webcam into a different USB port? Also have you tried unplugging some unnecessary USB devices and then using the webcam? You may be draining too much power from the PSU with USB devices and the PC shuts down to prevent damage. Have you been able to test on a different computer to see if the problems happens there as well?
Mar 24, 2011 | Creative Labs WebCam Live!
An error code jfb0 Bus Eror - Data Parity Error Detected Parity Error The system is a Sun Blade 2000 What can I do to fix this
replace or remove whatever ram chip is faulty, that error refers to a crc check on ecc memory. Or you could just turn off ecc parity checking in the bios. But that simply defeats the object of having ecc memory in the first place
Feb 24, 2011 | SunBlade 150 (A41UPA19C256MBA) Server
Bad sectors of my hard drive
There's no concrete way, you can try these software:
May 27, 2009 | Western Digital WD Passport 250GB Portable...
Cant get passed a blue screen that says restart and press f8. I cant restart without pulling the power. F8 doesnt do anything for me all of the options go right back to the blue screen that says restart...
ok
u need recovery disk
then u hava to fix error on harddisk.
Blue sceen is error of harddisk or RAM memory but majority harddisk be eror give4s this error
So boot your lapto pwith your rercovery disk then go to recovery console and type "chkdsk /r"
May 07, 2009 | Dell Inspiron 6000 Notebook
PC Freezing constantly
Run the defrag on your hard drive then a test for errors on it.Let it fix any erors found as it runs . Then try to reinstall the antivirus software. If the defrag or the fix disk software keep going on and on and on then the hard drive is shot.
Jan 08, 2009 | Computers & Internet
Installing XP on HP m8120n
The Blue Screen of Death (also known as a stop error, BSOD, bluescreen, or Blue Screen of Doom) is an error screen displayed by some operating systems, most notably Microsoft Windows, after encountering a critical system error which can cause the system to shut down, to prevent damage.
Bluescreens on NT-based Windows systems can be caused by poorly written device drivers or malfunctioning hardware. In the Win9x era, incompatible DLLs or bugs in the kernel of the operating system could also cause bluescreens.
Bluescreens can also be caused by physical faults such as faulty memory, power supply issues, overheating of components, or hardware running beyond its specification limits. Bluescreens have been present in all Windows-based operating systems since Windows 3.1; earlier, OS/2 and MS-DOS suffered the Black Screen of Death, and early builds of Windows Vista displayed the Red Screen of Death after a boot loader error.
I hope it helps!!!
Dec 04, 2008 | MSI K8MM-V Motherboard
Blue screen - kmode exception not handled - ntoskrnl.exe
Did you install anything on your computer right before this happend to you??? Usually when this Dreaded Blue Screen comes up its a hardware issue, You may have installed Memory, USB, ECT... check that out and remove some of your memory first and see if that helps you out any. try also a F`12 or F8 start. see if that helps you out any, Get back to me if you have any other Questions Thanks Bear001
Jun 21, 2008 | IBM Think Centre A50 P4 (841923u) Network...
RE: Toshiba SAtellite Model 495200 running Home premium Vista, 64 bit Intel Core 2 Duo Processor T550, 4 gig of memory First computer I had for a week and it crashed with blue screen every 15...
Hi efash ,
Every bluescreen problem has a solution, but we need to know the "STOP (bluescreen) error" code to resolve the issue .This time when you get the bluescreen error , please note down the complete error code along with the STOP message on a piece of paper.
Once you have noted down the error, click on the link below and check the the solution .
http://aumha.org/a/stop.htm
GoodLuck :-)
Jun 05, 2008 | Toshiba Computers & Internet
ASUS P5SD2-X Motherboard Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
