Question about Samsung DVD-R155
Cant play Region 4
I have a Region 4 Samsung DVD R-155. I used the unlock code '76884' to make it multi-regional, i.e. No. 9. Now I cannot change it and I cannot play my Region 4 DVD's.
  • 1 more comment
  • minnie08 Feb 22, 2008
    Thank you so much for the help - I downloaded the firmware and flashed my player and YEEHAA it worked!!! I can play Region 4 again! I really appreciate your help.
    Can you now tell me if I can try the crack again or should I just leave well enough alone?
  • minnie08 Feb 24, 2008
    Thanks again. However I have flashed the DVD with the firmware update and got it back to Region 4. I tried re-cracking it and changed it to multi-region 9. When I played the Region 1 DVD, I got three pictures shaking around across the screen. I then changed it to Region 1 - the same thing happened. Then I tried to change back to Region 4 and it wouldn't do it again so I then re-flashed it and got it back to Region 4. Any clues as to why this is happening? The disc is OK as I have played it OK on my computer DVD.
  • Anonymous Mar 30, 2014
    want to unlock to play all region dvd
    Sergeant:
  • 280 Answers
Check Samsung web site for a firmware update. Don't know if this is your problem but the firmware may help.
Posted on Feb 22, 2008
  • coyotedave Feb 23, 2008
    I would try a firmware update. it's free and should make your player compatible to more formates
Want to unlock region codes on my Samsung vcr/dvd recorder model no dvd-vr375 so I can record here and it can be played in Canada
Do the following step to make your DVD player region free..
1.Turn machine on without disc inside
2.Press menu button
3.Enter region code (See below for list)
4.A highlighted 'region area number' will appear in the upper left corner (some players)
5.Press 9 to change the region number to multi-regional
6.Turn DVD off (remove power from mains)
next time when u power on the DVD ,it will be region free.
region 1 - 29334
2 - 38767 or, 5 7 5 3 8
3 - 56732
4 - 76884
5 - 53814
6 - 24462
ok
Jan 22, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
How do i unlock the region code
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jan 02, 2011 | Samsung DVD-VR375 DVD Recorder/VCR
I am trying to find a code to make the Samsung dvd vr370 region free.. Can you assist?
2/Press menu button
6/Turn machine off
R1 - 29334
R2 - 38767 or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Jun 10, 2010 | Samsung Televison & Video
Problems changing region code on Samsung DVD player VR 375
HELLO!
Give these a try!
Power ON
Press MENU
Enter code 57538
The current region code appears
For codefree/multi-region press 9
Press Open DVD door button
Power OFF and power ON
You could also try this!
Turn player on without disc inside Press MENU button
Enter your region code (See list below)
Highlighted 'region area number' will appear in the upper-left corner (on some players)
Press 9 to multi-region the machine
Turn machine off
Region 1 - 29334
Region 2 - 38767 (or 5 7 5 3 8)
Region 3 - 56732
Region 4 - 76884
Region 5 - 53814
Region 6 - 24462
Have a go and good luck! (:-)
Sep 11, 2009 | Samsung DVD-VR375 DVD Recorder/VCR
Region code 4 on Samsung DVD-VR355 player/recorder
I live in Australia and have two Samsung DVD/VCR player recorders, DVD-VR375 and DVD-VR355. I could only play Region 4 DVDs until I pressed DVD, with no DVD in the units, pressed Menu then 76884, then 9, inserted a Region 1 DVd and it played in both units.
Christina Weate
Jun 11, 2009 | Televison & Video
How to change region codes from only 4 to 2 & 4
1) Turn on the player with no disc in the tray
2) Press the Open/Close button to open the tray
3) Press the info button, the firmware version shows up (mine was 080220.13.B.1080PXKEG)
4) After the version info disappears, close the tray again by pressing the Open/Close button
5) At this point, it will show "no disc" at the top. Press the Info button again, and this will disappear.
6) Now type the code that applies for your region (R4 is 76884). A '4' will briefly show up at the top left corner
7) Now press 9, and 9 will show up in the top left corner
8) Power off the player, and turn it on again. You'll have a multi region player
Enjoy
Apr 18, 2009 | Samsung DVD-1080P8/XEU DVD Player
Setting the player to region free
Apologies everyone.......
The instructions for the DVD-P181 are actually correct as described in other posts but can be a bit confusing. Please allow me to clarify using my example;
With your DVD-P181 switched on, follow these instructions using your Remote Control;
1/ Press the <DVD> button
2/ Press <0><0><0><0><0> (this is 0, 5 times)
3/ Press <repeat> (careful not to press the <repeat A-B> button)
4/ Press <7><6><8><8><4> (ONLY if your player is currently region 4 - refer to the table below for other pre-set regions)
5/ The Region window should now appear on screen saying that your current region is Region 4 and asking what region you want to change it to.
6/ Press <0> for the new Region (0 is region-free)
7/ Press <Open/Close> button once (to open the tray)
8/ Press <Open/Close> button again (to close the tray
9/ Press <Power> button to turn the player off
Now, when you turn the player back on, you should be able to play DVD's from any region. Good luck everyone.
_______________________________________________
This table refers to Step 4. You need to choose the Region code which your machine is currently set to, to unlock the Region Menu which allows you to set the device to another region.
In my example, the DVD player was purchased in Australia is by default set to Region 4. The 5 digit number I needed was 76884.
5 digit code:
region 1 : 29334
region 2 : 37867
region 3 : 56732
region 4 : 76884
region 5 : 53814
region 6 : 24462
Dec 28, 2008 | Samsung DVD-M105 DVD Player
I have a Samsung DVD-VR370 DVD-VR375 HD Combo Region 4 player. I need the instructions to get it to play multi regional DVD's
By what I have researched the vr370 doesn't have much information on it by way of unlocking the system...I have the vr375 which is the modle able to record BOTH dvd and vcr formats. I changed my region 4 player a year ago, but had to have it repaired and lost the setting. I have, however, found what I used online, and it is now playing my region 1 discs again!
2/Press menu button
3/Enter your current region code (See below for list)
4/confirmation of the current 'region area number' will appear in the upper right corner of the TV screen (some players)
6/Turn machine off
R1 - 29334
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
I hope this helps :)
Dec 07, 2008 | Televison & Video
Trying to de code my samsung dvd/vr 355 to play multi regional dvd
samsung dvd vr355 hack (uk model only)
remove dvd
switch on
press dvd button
press menu
press 57538 (76884 for non uk)
a number will appear in top left corner i.e. 2
then press 9 for multiregion
press open
switch off
player should be multi region now
Hope this helps.
Thanks
Sep 13, 2008 | Televison & Video
Make my dvd regioncode free
Same steps, only the code is wrong:
They are as follows
Region 1 (US, Canada) - 29334
Region 2 (Europe, Middle East, Japan) - 38767
Region 3 (South East Asia, Hong Kong) - 56732
Region 4 (South America, Oceania) - 76884
Region 5 (Russia, India) - 53814
Region 6 (China) - 24462
And just press 9 to chose REGION FREE
Jul 03, 2008 | Samsung DVD-HD870 DVD Player
Samsung DVD-R155 Logo
258 people viewed this question
Henry  Thomas
Henry Thomas
