Question about Zyxel Computers & Internet
How to configure port forwarding? - Zyxel Computers & Internet
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 15 Answers
Go to portforward.com
Posted on Mar 11, 2010
  • 2,260 Answers
Is there any computer connected to the router ?
If not then connect the computer to the router.
check the IP address and the default gateway of the router.
open the set up page of the router.
there you will find the place to place to open the ports on the router.
Click here for more information about roters and network
Posted on Feb 08, 2010
2 Suggested Answers
  • 561 Answers
SOURCE: How to configure port forwarding on router I need
put ur ip camera on dmz zone
Posted on Jun 17, 2010
My network configuration has a strict NAT setting this is likely to cause connectivity problems with other payers how do i address this issue
You need to look into port forwarding. You will need to go into your router/modem's configuration and open a port for the xbox. Do some research into port forwarding.
Feb 21, 2011 | Microsoft Xbox 360 Console
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
Nat settings on a linksys wireless router
NAT Configuration is also called Port Forwarding. You can simply open the ports by going to the router's setup page http://192.168.1.1 no username and password is admin. You can do it under Applications and Gaming tab, Port Range Forwarding.
Jun 20, 2009 | Linksys Wireless-G Broadband Router
Hangs with Bittorrent
That is because you need to open a port on router with the same number assigned to your torrent client.
You need to check port number on bittorrent configuration, then access router control panel typing router IP on internet explorer address bar and configure the router to open the port.
Read the following articles.
How to configure your router to allow fast BitTorrent downloads
Brian's BitTorrent FAQ and Guide: What ports does BitTorrent use
Slow Bit Torrent downloads? Router configuration tips.
Opening port BitTorrent |
forum.bittorrent.com / how to open firewall/router port
Guide to Open or Forward Ports for Utorrent and Azureus BitTorrent
Port Forwarding for the Netgear WGR614
Tweaking your system to get the most out of BitTorrent
Apr 13, 2009 | Computers & Internet
How to configure ports on my modem
U will have to learn port forwarding.............u didn't mention router ur using since differnt router have different settings.......goto http://192.168.1.1 and search for port forwarding settings. Me too had this prob before port forwarding speed 15~20Kbps download and after 197~208Kbps.
Good luck with port forwarding.
Jan 18, 2009 | Computers & Internet
Netopia routers2247NWG/slow download speed/
Actually the application may be games or any other software which it setted port is not open/accessable through your router and it will work by default ports and the speed or the performance is very slow- Try to configure proper port forwarding according to the application port settings check those ports are open after configuration
Hothawk
Jul 14, 2008 | Computers & Internet
Port Forwarding
Hello Just wondering If both are on the same work Group in the network settings. (Same Name) You probably did that already but if not give it a try and maybe your forwarding will resume and work properly. Hope so. Thanks
Jan 16, 2008 | Linksys EtherFast Cable/DSL Router
Inability access from other computers
You need to check with your router vendor on how to setup DMZ or Port Forwarding for your DCS-5220 in your router. (For Port Forwarding, please open BOTH HTTP Port and RTSP Port and select the Protocol as TCP for HTTP Port and select the Protocol as TCP/UDP(Both) for RTSP Port.
Nov 14, 2007 | D-Link DCS-5220 Network Camera
Configure the firewall
You can use the Virtual Server to forward an individual port to one of your computers. You cannot forward the same port to multiple computers. In order to configure the Virtual Server you need to know the IP address of the computer that needs the port opened and the service port number. The links below will help you find the IP address of your machine. If you don?t know which port needs to be opened, try checking the software manufacture?s support website for information on use behind firewall. Configuring the Virtual Server: Step 1 Access the device configuration by entering 192.168.0.1 in your web browser. Login with your username and password. The default username is admin and the password is blank. Step 2a If the port you need to forward is a common port, it will be under the predefined virtual server list at the bottom of the page. Click the pad and paper icon next to the virtual server entry you want to use. The Protocol Type and Service Port fields are preconfigured. Click the Enable radio button to use the virtual server. Enter the private IP address of the computer that will use the service port. Configure the Schedule as needed, then Apply your settings. Step 2b If the port you need to forward is not listed under the predefined virtual server list at the bottom of the page, you can create a new entry for your application. Click the Enable radio button to use the virtual server. Give your virtual server a name. Next, enter the private IP address of the computer that will use the service port. Then, select the Protocol Type and enter the Service Port. If you don?t know how to use Private and Public port assignment, then just enter the same port number in both fields. Configure the Schedule as needed and Apply your settings.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Computers & Internet Logo
187 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
