Question about Elite Sl 3000 Ul Sliding Gate Operator
My elite operator will only close part way, seems to only happen cold nights 52 degrees-F works well in the day time no matter the temperature, limit switches checks out ok, I disconnected the loop detector and the operator still will not close, disconnected the gate and run the operator still stalls to close without the gate load. Have not problems what so ever when opening.
  • 3 Answers
You will have to increase your force (sensitivity) settings on the p.c. board. Without knowing what type of board you have I can only guess. There should be a pod you can rotate with a screwdriver to increase the force. If it has an LCD readout with menus search the menus for force or obstruction, then increase it.
freddy51
Posted on Feb 08, 2010
Intermittent hard start problem
check the spark plug gaps here first make sure their 25th never mind what the book says make sure their 25th or you will have a job cold starting
Feb 25, 2015 | Cars & Trucks
This question for Sanyo PTAC HVAC for Hotel-Motel style unit.Hi, We have Sanyo PTAC STW 1223C2P,in real cold night, heat stripe in not working proper, on left side blow cold air, in center throw hot a
If you are saying this happens on a really cold night, the assumption is that on milder nights, it seems to work adequately.....If that's the case, there is a possibility that it is marginally sized in capacity to heat the space in which it is installed. If it has a "fresh air" damper setting, make sure that is closed completely, because that is air directly from outside the structure that is being brought in through the blower and adds more load to the space and makes the discharge air feel colder.
Dec 08, 2014 | Dryers
I'm using the Casio fx-115ES model. When i try to put in 52 Degrees, 10 minutes, I dont seem to be able to do this. I key in the numbers 52 then hit the "degree, minutes seconds" button and i get the...
When entering the information it only shows the degree symbol. If you press enter or type inthe formula, then the answer will show the Degree, Minutes, and seconds. It seems to be the way it was program by Casio. It still seems to work fine for entering that information
Aug 03, 2010 | Casio FX-115ES Scientific Calculator
The outgoing gate has a positive stop on it, but
Well it seems that their could be a limit switch problem. also if someone has replaced the limit switch they could have not connected the wires back up correctly. if your wiring and switch are correct than you have a bad circuit board. my opinion is to not even fix it and replace the whole opener with a gto-pto gp sl50 They are the most reliable opener out so far and come with all the features that elite charges extra for like a battery backup for instance.
Oct 24, 2009 | Elite Sl 3000 Ul Sliding Gate Operator
My refrigerater temp won't go below 55 degrees. Is there something to try befroe bringing the repair man out? The freezer seems to work fine.
The air door "cold control" may be obstructed or the air return may be obstructed. The air return takes the air from the refrigerator section and delivers it to the coil. It must be clear for the fridge to operate properly. The cold control is just a door flap that opens and closes and allows cold air to enter that part of the cabinet. Open the cold control more and see if that helps. You should feel more cold air coming from it. If you don't then there's an obstruction.
If you have a thermometer that goes below zero, place it in the freezer. It should read 0 to -5 degrees f. If it doesn't then there may be another problem.
Jul 08, 2009 | Sub-Zero 611 / O Bottom Freezer...
Freezer cold fridge 52 degrees
We have a Kenmore Coldspot Model # 106.8770687 and the freezer is cold and keeping things frozen, but seems to be frosting over and the refrigerator is warm at 40 to 50 degrees ... any help regarding what to check is helpful! Or a schematic / manual
Jun 14, 2009 | Kenmore Refrigerators
Auto-defrost not working at all
Unless equipped with special equipment most dehumidifiers will produce little if any water under 65-70 degrees. Many state operation down to 50-60 degrees but this was under lab conditions and therefore a marketing tool. The best performance is gained when the air temperature is above 70 degrees. The water you are finding is from melting frost, if you have a humidity problem you should be adding heat to the area to be dried, warm air holds much more moisture than cold and drying is much more effective if you can heat the area to around 80 degrees.
Mar 05, 2017 | Kenmore Dehumidifiers
Elite Sl 3000 Ul Sliding Gate Operator Logo
608 people viewed this question
Top Elite Home Security Experts
John
jr3261
Are you an Elite Home Security Expert? Answer questions, earn points and help others
