Question about Proscan 26LB30QD 26 in. LCD HDTV
Can I cnnect my pc to view on my proscan 32 LCD
Is there a way to connect my pc to view on my proscan 32 LCD screen via a wireless connection?
  • Proscan Master
  • 12,061 Answers
Well I do, I mean I often connect up my PC & TV via my TV OUT, on my Video card, I hook it into my 2.4GHz Video AV "Sender" I simply use the PC's, Composite Output & the Stereo Out, audio, feed it into the Transmitter, & connect the Receiver to the TV's Composite IN & AV IN. Works great.
Posted on Feb 08, 2010
Sharp TV wont display computer screen
Looks like you have tried to connect two together, when either or both were in switched on condition. It is not advisable to connect any input, when the device is on. First, check for any changes in settings. Then, if these are ok, switch off TV manually, switch off power and just disconnect the TV from the mains outlet and leave it like that for 48 hours and retry.
Jul 30, 2012 | Proscan 32LB30QD 32 in. LCD TV
The screen to my 32" Proscan flat screen tv broke.
unless you have not mentioned your place its difficult. Better you find some importers,
otherwise contact the authorised service centre
Apr 09, 2011 | Proscan 32LB30QD 32 in. LCD TV
I have a 40 inch proscan lcd tv which i connected a dvd player to it but i would also like to connect a vcr player to but dont know how. I've tried several times but not sure how can you help?
Hello, There are two options for connecting the VCR, one of which must be connected to the VCR with a standard coaxial cable into the TV RF connection. The second is the direct connection as you have connected the DVD. The question is whether the connection is currently available and what kind of connection there?
Mar 06, 2011 | Proscan 32LB30QD 32 in. LCD TV
My proscan 32LB30QD won't power up. It worked
try this first:
Setup and Connection
The TV won't turn on Check your power cable connection.
• t can't view the Basic channels. Check the connection of the antenna cable
• t want to view cable channels. Register with your local cable company then connect their receiver to your TV.
• t want to view satellite channels. Setup your Satellite parabola antenna then connect your satellite receiver to the TV.
• Digital broadcasting is not functioning Check your antenna cable connection. Check if the digital channel selection is correctly
connected to your antenna cable.
Jun 15, 2010 | Proscan 32LB30QD 32 in. LCD TV
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
My Proscan 32LB30QD does not have Audio Out! Is there a way to connect a wireless headphone to this TV?
You can either see if your cable box (if you have one) has RCA outputs on the back or if you are using some sort of a VCR or DVD it should have audio outputs on the back. The only problem with the latter hookup is that you have to turn the vcr on if you want to hear thru the headphones.
Aug 07, 2009 | Proscan 32LB30QD 32 in. LCD TV
Proscan 32lb30Q. I need to hook up wireless
You can buy a digital to analogue converter that connects to your COAX digital output and then connects to you RCA jacks. They run around $75. The only problem I've encountered is the DVD does not work through the COAX output, just TV. I'm looking into it.
Jul 01, 2009 | Proscan 32LB30QD 32 in. LCD TV
New proscan 32 lcd tv. Won't work with sony wireless headphone
Try using the PROSCAN website customer support, to find the answer to you questions.www.oncorpus.com. You will need some type of adaptor from th coax output to the input of you system. For the wireless problem you may need two adapators one from the tv to you receivers and a sound output to wireless adapator. You can call them at their customer support telephone number 1-888-977-6722. I hope this information helps you with your problems.
Mar 31, 2009 | Proscan 32LA30Q Television
No signal from my dvd player
Can you tell me how to connect my dvd player to my 42 inch proscan hdtv ? There are no yellow,its blue and there are two rows of the same colors.
Feb 03, 2009 | Proscan 32LA25Q 32 in. LCD TV
Proscan 26LB30QD 26 in. LCD HDTV Logo
296 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
