Question about HP OfficeJet 7410 All-In-One InkJet Printer
My printer will no longer print from the computer when I click on the print button.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    Hi, Please provide me the below info, inorder to fix this problem.
    Error message that you encounter while printing.
    Computer Operating system.
    Printer connected via USB (or) Ethernet cable (or) wireless. Regards, Rizwan
  • contratek
    contratek May 11, 2010
    some things to check
    is there a print icon in the lower right task bar ?
    Double click this ..is there print jobs in there?
    is the usb connected properly or have you tried another USB slot?
    delete and reinstall the printer and try a test page ?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
Print quality low
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Thanks
Michel
Computer Repair
Mar 15, 2011 | Brother MFC-6890CDW Printer
Poor printing quality
Feb 18, 2011 | Brother HL 2140 Laser Printer
HP Photosmart C 4600 Printer won't print
Jan 12, 2011 | HP Office Equipment & Supplies
Not printing correctly
Nov 12, 2010 | Dell P703w Printer
Printing the whole page black when printing
Nov 09, 2010 | Epson Stylus Color 760 InkJet Printer
My hp desk jet 5650 printer does't print test print
Oct 27, 2010 | Office Equipment & Supplies
How do I clean the print heads?
Oct 22, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Not printing chek
Printer not printing black issues looking printer head problem. check the following Steps for cleaning printer head :
Oct 13, 2010 | HP LaserJet 3600dn Printer
Printer Not printing red
Printer not printing red issues looking printer head problem. check the following Steps for cleaning printer head :
Oct 13, 2010 | HP Color LaserJet 2600n Printer
Printer not printing issues looking printer head problem. check the following Steps for cleaning printer head :
Oct 12, 2010 | Brother Office Equipment & Supplies
HP OfficeJet 7410 All-In-One InkJet Printer Logo
87 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
