Question about Kenmore 54501 Dehumidifier
Whirlpool 50 pint dehumidifier
Starts to run, then begins screeching and smells like something is hot or burning...then shuts off
my whirlpool AD50G1 does the same thing.
fan runs but the compressor wont start. i think it might be a non resettable thermal overload fuse or a thermal breaker malfunction.
there should be a safety mechanism for shutting off the compressor if too much heat builds up so the system doesnt cause a fire. most systems have a fuse that must be replaced, or a breaker. in the latter a thermally sensitive spring disconnects power from the compressor and reconnects it when it cools down. an electric arc at that connection can damage the contacts and cause the breaker to shut off power and not turn the device back on. i am going to try to bypass that device, it is located under the plastic cover on the compressor tank body where the white and black wires go into it. usually there is an underlying problem, seized pump, dehumidifier fan seizure, or a loss of coolant / lubricant in the compressor reservoir.
if the compressor buzzes but does not cycle on, it is seized, get a new dehumidifier. if it does nothing, check other circuits, or bypass humidity sensor, tank switch, ect. to make sure another part / switch / sensor isn't making the compressor lose power.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 184 Answers
The problem just might be that your are trying to use this unit at a time of season that is cold weather. there is no humidity in the air so the unit is cycling on and off .there by the noise you hear. dehums work best when the temp is 65 degrees or higher and the humidity level is 60% or higher. and that means outside. in order to have humidity the water has to be heated up to the point that it starts to evaporate.
Posted on Mar 28, 2008
Make sure your still with in 5yr. warrenty on the sealed system if so then call out a Whirlpool warrenty certified tech. to condem the compressor and to call into Whirlpool for a replacement and to pay for the service.
Posted on Feb 25, 2008
Lifeguard, there are generally no user accessible safety items in dehumidifiers. You are likely describing the start relay which is used to 'boost' the compressor on starting. Jumping it will not help you. It sounds like the compressor is defective. Economically, there is no justification for servicing these units unless they require refrigerant gas or if the fan motor has seized, something you can readily determine. If you don't hear the compressor hum when it should, there is no service procedure available for these sealed units.
Posted on Feb 23, 2008
Icing up on a dehumidifier
The gas can pass through the pipework slowly by osmosis especially after several years use. However, check fans, heat exchangers etc first before condemning unit.
May 15, 2012 | Whirlpool Dehumidifier 40-Pint
I have a whirlpool dehumidifier (AD75UST0) and it appears to be 'dead'. is there a fuse or a reset?
No. I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. My unit slowly got less and less efficient, then it "stopped" coming on as if it was not working. Upon disassemble and inspection I found fan was no longer spinning. It tries to start then (actually the condenser coils begin to freeze, but no Fan) then it shuts down within 30 sec or so.
I am going to try a replacement Fan and fan start Capacitor (always replace in pairs).
Aug 19, 2011 | Whirlpool 75-Pint Dehumidifier
I just replaced the thermal fuse as described by several of your people for a fan motor on a Kenmore dihumidifier 580.54701400. The unit ran fine for about an hour and then stopped with a burning smell...
Your call on the $39 replacement replacing the whole thing.
did the TCO you put int have the same specs (temperature) as the one you replaced? I've replaced a lot of these and they'll keep running.
The burning smell points to a failing coil which creates the heat which opens the TCO. you already know how to get the motor coil out so I think the $39 options is better.
Oct 09, 2010 | Kenmore 54701 Dehumidifier
I have a whirlpool dehumidifier 70 pint and the fan runs but no longer collection of water...we have had it about 4 years.
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Oct 04, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Whirlpool dehumidifier does remove water
indicates a gas leak and there is insufficient gas in the system
Oct 19, 2017 | Whirlpool AD50USS Dehumidifier
Crosley dehumidifier does not collect water.
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 13, 2010 | Crosley 40-pint Dehumidifier
Kenmore 54501 Dehumidifier Logo
594 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
